Need help with combining 2 sketches
Hi There
We have got these 2 sketches working perfectly by themselves but cant seem to get them to work as one sketch.
* LDR and Arduino
* Reads an input from LDR, sends it to serial monitor and turns a LED off or on.
* Code by Joshua Lopez http://joshualopezarduino.blogspot.com/
// variables
int LDR_pin = 0; // analog pin 0 (connect LDR here)
int LDR_val = 0; // variable use to read input data
int LEDpin = 13; //This is the LED
// a threshold to decide when the LED turns on
int threshold = 500;
void setup(){
// declaration of pin modes
pinMode(LDR_pin, INPUT);
pinMode(LEDpin, OUTPUT);
// begin sending over serial port
void loop(){
// read the value on analog input
LDR_val = analogRead(LDR_pin);
// if value greater than threshold turn on LED
if (LDR_val < threshold) digitalWrite(LEDpin, HIGH); else digitalWrite(LEDpin, LOW);
// output 'LDR_val' value into the console
Serial.print("LDR = ");
Serial.print(LDR_val);
And
// RGB LED - Automatic Color Cycling
// Matthew L Beckler
// matthew at mbeckler dot org
int redPin = 11;
int bluePin = 10;
int greenPin = 9;
int redIn = 0;
int greenIn = 1;
int blueIn = 2;
int redVal;
int greenVal;
int blueVal;
  redVal = 255;
  greenVal = 255;
  blueVal = 255;
  update();
// This function updates the LED outputs.
void update()
  analogWrite(redPin, redVal);
  analogWrite(greenPin, greenVal);
  analogWrite(bluePin, blueVal);
// This function updates one of the color variables
// either getting brighter or getting dimmer.
// It also updates the outputs and delays for 10 milliseconds.
void color_morph(int* value, int get_brighter)
  for (int i = 0; i < 255; i++)
    if (get_brighter)
      (*value)--;
      (*value)++;
    update();
    delay(10);
  // start out at black (all off)
  color_morph(&redVal,   1); // transition to red
  color_morph(&greenVal, 1); // transition to yellow
  color_morph(&redVal,   0); // transition to green
  color_morph(&blueVal,  1); // transition to aqua
  color_morph(&redVal,   1); // transition to white
  color_morph(&greenVal, 0); // transition to violet
  color_morph(&redVal,   0); // transition to blue
  color_morph(&blueVal,  0); // transition to black (all off)
We would like the RGB Led to run the whole time independently from the LDR part.
If you could please help us that would be great.
Thank you
Even better if you could get it so that the red color of the RGB led comes on when the light sensor is darkened and stays on for a few seconds after light has returned, and RGB led should just cycles through the other colors otherwise.
This doesn't do what you think or want it to do, and could have unexpected effects - remove it.
Here is what we have tried
// variables
int threshold = 450;// a threshold to decide when the LED turns on
int redPin = 11;
int bluePin = 10;
int greenPin = 9;
int redIn = 0;
int greenIn = 1;
int blueIn = 2;
int redVal;
int greenVal;
int blueVal;
void setup(){
  redVal = 255;
  greenVal = 255;
  blueVal = 255;
  update();
pinMode(LDR_pin, INPUT);// declaration of pin modes
Serial.begin(9600);// begin sending over serial port
void update(){
    if (get_brighter)
      (*value)--;
      (*value)++;
    update();
    delay(10);
void loop(){
if (LDR_val > threshold) digitalWrite(LEDpin, HIGH); else digitalWrite(LEDpin, LOW);
if (LDR_val < threshold) digitalWrite(LEDpin, LOW); else digitalWrite(LEDpin, HIGH);
we will try removing pinMode(LDR_pin, INPUT); shortly
You could get rid of unnecessary braces.
  redVal = 255; // this could be done where "redVal" is declared.
  greenVal = 255; // this could be done where "greenVal" is declared.
  blueVal = 255; // this could be done..I'm sure you get the picture.
  update();
Hey thanks, we tried that but still nothing. Any more ideas?
Any more ideas?
Yeah, plenty.
How about you tell us what the difference is between what your sketch is doing now, and what you want it to do?
You're the guys with the hardware.
Something from your code you may want to think about (reformatted for easier reading):
When we combine the two, The RGB LED works consistently , but the light sensor stops working when it is combined with the RGB code.
We want the RGB LED to work consistently but also be able to use the light sensor as a switch.
What does this do?
const int LDRpin = 0; // analog pin 0 (connect LDR here)
const int LEDpin  = 13; //This is the LED
const int redPin = 11;
const int bluePin = 10;
const int greenPin = 9;
int redVal   = 255;
int greenVal = 255;
int blueVal  = 255;
  update();
void update()
void color_morph(int& value, int get_brighter)
    if (get_brighter)
      value--;
      value++;
    update();
    delay(10);
  int LDRval = analogRead(LDRpin);
  if (LDRval > threshold)
  Serial.println(LDRval);
  color_morph(redVal,   1); // transition to red
  color_morph(greenVal, 1); // transition to yellow
  color_morph(redVal,   0); // transition to green
  color_morph(blueVal,  1); // transition to aqua
  color_morph(redVal,   1); // transition to white
  color_morph(greenVal, 0); // transition to violet
  color_morph(redVal,   0); // transition to blue
  color_morph(blueVal,  0); // transition to black (all off)
Hey still not working. Have a look at this blog. It should give you a better idea of what we are working on.
http://interactivearduino.wordpress.com/wp-admin/
I think it probably is working, just not as fast as you may want it.
have you thought about something like:
    if (get_brighter)
      value--;
      value++;
    update();
    //    delay(10);
  int LDR_val = analogRead(LDR_pin);
I don't really recommend this exact approach, because different values of "LDR_val" will affect your morph speed, but it's a step in the right direction.
Your right the code above is working there's just around a 15 sec delay between when the LDR is covered and the LED comes on.
int redVal   = 255;
int greenVal = 255;
int blueVal  = 255;
  update();
void update()
    if (get_brighter)
      value--;
      value++;
    update();
    delay(10);
How would we go about speeding this up to the speed it was at when the codes weren't merged?
Also in the code you don't recommend
    if (get_brighter)
      value--;
      value++;
    update();
    //    delay(10);
it says that LDR_pin wasn't declared in this scope.
Call it "LDRpin" then, or whatever it was called at the top of the sketch.
When I said I don't recommend it, I mean it will work, and it will be as quick as you want, but it isn't really a very pretty solution.
But sometimes, prettiness is over-rated.
If you're not interested in printing the value read from the LDR, then this method needs you to put the delay(10) back in, but then it will not change the morph rate as the value read from the LDR changes.
Hey we have a similar problem; we're wanting to combine 2 sketches but are having difficulty;
the two sketches are:
 * Ardrumo sketch
 * Use with the Ardrumo software here:
 * http://code.google.com/p/ardrumo/
 * This is designed to let an Arduino act as a drum machine
 * in GarageBand (sorry, Mac OS X only).
#define LEDPIN     13     // status LED pin
#define PIEZOTHRESHOLD 5  // analog threshold for piezo sensing
#define PADNUM 6          // number of pads
int val;
  pinMode(LEDPIN, OUTPUT);
  Serial.begin(57600);   // set serial output rate
  // Loop through each piezo and send data
  // on the serial output if the force exceeds
  // the piezo threshold
  for(int i = 0; i < PADNUM; i++) {
    val = analogRead(i);
    if( val >= PIEZOTHRESHOLD ) {
      digitalWrite(LEDPIN,HIGH);  // indicate we're sending MIDI data
      Serial.print(i);
      Serial.print(",");
      Serial.print(val);
      digitalWrite(LEDPIN,LOW);
And
// Example 04: Fade an LED in and out like on
// a sleeping Apple computer
// Copy and paste this example into an empty Arduino sketch
#define LED   9 // the pin for the LED
int i = 0;      // We'll use this to count up and down
  pinMode(LED, OUTPUT); // tell Arduino LED is an output
void loop(){
  for (i = 0; i < 255; i++) { // loop from 0 to 254 (fade in)
    analogWrite(LED, i);      // set the LED brightness
    delay(10); // Wait 10ms because analogWrite
               // is instantaneous and we would
               // not see any change
  for (i = 255; i > 0; i--) { // loop from 255 to 1 (fade out)
Thanks!
Hey Groove,
Thanks heaps for your help. There are some videos on our blog of the final project.
Keep up the good work looking after us Noobs.
@HALarduino - so where's the combined code?
Hey Groove,
We don't know how to combine the Ardrumo Sketch and the fading LED sketch successfully. We were wondering if you knew?
We're trying it ourselves but any input would be helpful.
Thanks
I combined them and it kind of worked,
BUT we want the LED to fade in and out continuously independently of whether the piezo buzzers are hit.
This is the Code we've got but the LED fades in and out only when you hit the piezo- and you can't get a sound/any reaction from the piezo again until the light has faded back out.
 * Ardrumo sketch
#define PADNUM 3          // number of pads
#define LEDAPPLE   9 // the pin for the LED
int val;
  pinMode(LEDAPPLE, OUTPUT); // tell Arduino LED is an output
      Serial.print(i);
      Serial.print(",");
      Serial.print(val);
    analogWrite(LEDAPPLE, i);      // set the LED brightness
You haven't said what "worked" means in this context, so until that is clear to all, it isn't really possible to help.
"Have a look at the "Blink without delay" tutorial" is usually what I say at this point.
Sorry!!
What I meant by it 'kind of works' last time was:
-the LED faded in and out but only when a piezo buzzer was hit, and we wanted it to go regardless of the piezo buzzers activity.
Ok, I went through the blink without delay tutorial.
The LED blinks continuously which is what we want- but it stops the Ardrumo sketch working.
So we have no sound coming out when the piezo sensors are hit.
This is the combined sketched I tried but no sound came out:
/* Blink without Delay
 Turns on and off a light emitting diode(LED) connected to a digital
 pin, without using the delay() function.  This means that other code
 can run at the same time without being interrupted by the LED code.
 The circuit:
 * LED attached from pin 13 to ground.
 * Note: on most Arduinos, there is already an LED on the board
 that's attached to pin 13, so no hardware is needed for this example.
 created 2005
 by David A. Mellis
 modified 8 Feb 2010
 by Paul Stoffregen
 This example code is in the public domain.
 http://www.arduino.cc/en/Tutorial/BlinkWithoutDelay
// constants won't change. Used here to
// set pin numbers:
const int ledPin =  13;      // the number of the LED pin
// Variables will change:
int ledState = LOW;             // ledState used to set the LED
long previousMillis = 0;        // will store last time LED was updated
// the follow variables is a long because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long interval = 100;           // interval at which to blink (milliseconds)
  // set the digital pin as output:
  pinMode(ledPin, OUTPUT);
 * Ardrumo sketch
int val;
      Serial.print(i);
      Serial.print(",");
      Serial.print(val);
  // here is where you'd put code that needs to be running all the time.
  // check to see if it's time to blink the LED; that is, if the
  // difference between the current time and last time you blinked
  // the LED is bigger than the interval at which you want to
  // blink the LED.
   if(currentMillis - previousMillis > interval) {
    // save the last time you blinked the LED
    // if the LED is off turn it on and vice-versa:
    if (ledState == LOW)
      ledState = HIGH;
      ledState = LOW;
    // set the LED with the ledState of the variable:
    digitalWrite(ledPin, ledState);
Could that be because there's nothing in that sketch that would actually cause anything to make a sound?
