need help with communication serie
firstly, im using cable db9 for this serial communication...
void setup(){
void loop(){
Serial.println("Hello");
im testing this code and its all ok..but when im testing the code below, its not functionned..can someone give me a help on this please...
pinMode(13, OUTPUT);
if (Serial.available() > 0)
int incoming = Serial.read();
if ((char)incoming == '1')
digitalWrite(13, HIGH);
Serial.println("On");
else if ((char)incoming >= '2')
digitalWrite(13, LOW);
Serial.println("Off");
im using cable db9 and max 232 for make my wiring...when im using USB cable,there is no problems...
show how you make the db9<->max232<->arduino schema...
this is the link where i found the circuit...i make this wiring for my serial...avrprogrammers.com -
try with this schema while it talks about pin 15 and 16 of the max232.
I dont use the capacitor between VCC and Ground on the left bottom of the schema.
its fonctionned now...thanks a lot for ur help..
the problems just the ground...thanks
