I thought of using tow 1738 IR sensor so that I can detect entry and exit of people to a room. And can increment or decrement a register in arduino.
Working:
---IR Led1 : ---------->1st 1738
---IR Led2 : ----------->2nd 1738
So if the 1st led is blocked and then the 2nd, then we can label the motion as say "Entry" and viceversa "Exit"
But the problem I seem to have is 1738 needs to have bursts of 38 Khz signal. Is that correct?
For my application wouldn't a continuous 38 khz wave be required?
How robust do you need this to be? Doing this accurately with real people is difficult, because they come through doorways in groups, change their mind half way through, and stand in the doorway nattering. Unless you have a turnstile type system, I don't think it'll be feasible to get a really reliable figure. But if you only need to show something working with cooperative test subjects, that wouldn't be an issue.
