Need help with conditional DI/O and using Serial monitor to set conditions
I think, you should check if serial available first.
  if (Serial.available() > 0) {
    incomingByte = Serial.read();
    if (incomingByte == '1') {
      Read = 1;
Than you need to cast "char" received via serial to integer, or you can use an example, when value just set.
Not tested.
