I've recently purchased this device:
And would like to ask help to connect it to Arduino.
Would be nice if somebody could guide me in the right direction.
Thanks.
Thanks.
It's a typical I2C wiring; here's a similar example. You will still need to chase down the software libraries to interface with each of your specific sensors.
Some tutorials will show a level shifter, but you do not need a level shifter with this board as it already has one.
Thanks for link.
Looks like it explains it better than any I found.
Here's photo of my Arduino and Sensors.
So hopefully I didn't mess with power!?
According to this now I have to choose to connect other things to analog or digital pins.
Still need to figure out what are they.
I would appreciate any help.
Yours follows the "classic" (as Adafruit describes it) wiring. SDA to analog pin 4 and SCL to analog pin 5.
Thanks,
That's only for Gyro?
That's for all three chips; no more wiring needed. I2C devices have a built-in address that your code (or more specifically the library to interface with the chips) will report when it's communicating with a specific chip.
Right about to test magnetometer with this tutorial - https://www.loveelectronics.co.uk/Tutorials/8/hmc5883l-tutorial-and-arduino-library
Do I need any resistors between SDA and VCC, and SCL and VCC?
Got it working:
Setting scale to +/- 1.3 Ga
Entered scale was not valid, valid gauss values are: 0.88, 1.3, 1.9, 2.5, 4.0, 4.7, 5.6, 8.1
Setting measurement mode to continuous.
Raw: -93 -68 482 Scaled: -85.56 -62.56 443.44 Heading: 3.77 Radians 216.17 Degrees
Raw: -93 -69 477 Scaled: -85.56 -63.48 438.84 Heading: 3.78 Radians 216.57 Degrees
Raw: -94 -68 483 Scaled: -86.48 -62.56 444.36 Heading: 3.77 Radians 215.88 Degrees
Chagrin thank you very much for help. That's a good start for me.
Understood all logic, so should be able to get data from all sensors and use it in my app.
P.S. hopefully I didn't need any resistors, as I was running it without them.
That message about being invalid, always seems to occur.
I think that might happen due to connection/disconnection of sensor.
I was holding everything in hands - so few times sensor disconnected and shown following error few times through log.
Hello, i bought that same module
can you put your code on the forum?
i dont understand how to adress the chip from the links given on this page
do you have any datasheet ?
thx
Sorry for delay, didn't see message updates.
Following code works with compass:
(it was copied from somewhere on internet,
don't remember the author)
#include <Wire.h>
#include <HMC5883L.h>
HMC5883L compass;
Wire.begin();
Serial.println("Serial started.");
compass = HMC5883L();
Serial.println("Setting scale to +/- 1.3 Ga");
int error = compass.SetScale(1.3); // Set the scale of the compass.
if(error != 0) // If there is an error, print it out.
Serial.println(compass.GetErrorText(error));
Serial.println("Setting measurement mode to continuous.");
error = compass.SetMeasurementMode(Measurement_Continuous); // Set the measurement mode to Continuous
// Retrive the raw values from the compass (not scaled).
MagnetometerRaw raw = compass.ReadRawAxis();
// Retrived the scaled values from the compass (scaled to the configured scale).
MagnetometerScaled scaled = compass.ReadScaledAxis();
// Calculate heading when the magnetometer is level, then correct for signs of axis.
float heading = atan2(raw.YAxis, raw.XAxis);
// Correct for when signs are reversed.
if(heading < 0)
heading += 2*PI;
// Convert radians to degrees for readability.
float headingDegrees = heading * 180/M_PI;
// Output the data via the serial port.
Output(raw, scaled, heading, headingDegrees);
void Output(MagnetometerRaw raw, MagnetometerScaled scaled, float heading, float headingDegrees)
Serial.print("Raw:\t");
Serial.print(raw.XAxis);
Serial.print(" ");
Serial.print(raw.YAxis);
Serial.print(" ");
Serial.print(raw.ZAxis);
Serial.print(" \tScaled:\t");
Serial.print(scaled.XAxis);
Serial.print(" ");
Serial.print(scaled.YAxis);
Serial.print(" ");
Serial.print(scaled.ZAxis);
Serial.print(" \tHeading:\t");
Serial.print(heading);
Serial.print(" Radians \t");
Serial.print(headingDegrees);
Serial.println(" Degrees \t");
