Need help with controlling relays
So I am trying to make a home automation system where I can control 16 relays with my phone using esp rainmaker and an ir receiver with a esp32, and I have written this code, but when I turn it on, all the relays seem to be turned on. Please help
#include "RMaker.h"
#include "WiFi.h"
#include "WiFiProv.h"
#include <IRremote.h>
#include <Preferences.h>
Preferences pref;
const char *service_name = "PROV_1234";
const char *pop = "1234";
// define the Chip Id
uint32_t espChipId = 0;
// define the Node Name
char nodeName[] = "ESP32_Relay_8B";
// define the Device Names
char deviceName_1[] = "Switch1";
char deviceName_2[] = "Switch2";
char deviceName_3[] = "Switch3";
char deviceName_4[] = "Switch4";
char deviceName_5[] = "Switch5";
char deviceName_6[] = "Switch6";
char deviceName_7[] = "Switch7";
char deviceName_8[] = "Switch8";
char deviceName_9[] = "Switch9";
char deviceName_10[] = "Switch10";
char deviceName_11[] = "Switch11";
char deviceName_12[] = "Switch12";
char deviceName_13[] = "Switch13";
char deviceName_14[] = "Switch14";
char deviceName_15[] = "Switch15";
char deviceName_16[] = "Switch16";
//Update the HEX code of IR Remote buttons 0x<HEX CODE>
#define IR_Button_1   0x10
#define IR_Button_2   0x810
#define IR_Button_3   0x410
#define IR_Button_4   0xC10
#define IR_Button_5   0x210
#define IR_Button_6   0xA10
#define IR_Button_7   0x610
#define IR_Button_8   0xE10
#define IR_Button_9   0x110
#define IR_Button_10   0xFD0
#define IR_Button_11   0x910
#define IR_Button_12   0xDD0
#define IR_Button_13   0x490
#define IR_Button_14   0x90
#define IR_Button_15   0xC90
#define IR_Button_16   0x890
#define IR_All_Off    0xA90
#define IR_All_On     0x5D0
// define the GPIO connected with Relays and switches
static uint8_t RelayPin1 = 4;     //D4
static uint8_t RelayPin2 = 5;     //D5
static uint8_t RelayPin3 = 18;    //D18
static uint8_t RelayPin4 = 19;    //D19
static uint8_t RelayPin5 = 21;    //D21
static uint8_t RelayPin6 = 22;    //D22
static uint8_t RelayPin7 = 23;    //D23
static uint8_t RelayPin8 = 25;    //D25
static uint8_t RelayPin9 = 26;    //D26
static uint8_t RelayPin10 = 27;   //D27
static uint8_t RelayPin11 = 32;   //D32
static uint8_t RelayPin12 = 33;   //D33
static uint8_t RelayPin13 = 13;   //D13
static uint8_t RelayPin14 = 12;   //D12
static uint8_t RelayPin15 = 14;   //D14
static uint8_t RelayPin16 = 15;  //D15
static uint8_t wifiLed      = 2;  // D2
static uint8_t gpio_reset   = 0;  // Press BOOT for reset WiFi
int IR_RECV_PIN  = 35; // D35 (IR receiver pin)
// Relay State
bool toggleState_1 = LOW; //Define integer to remember the toggle state for relay 1
bool toggleState_2 = LOW; //Define integer to remember the toggle state for relay 2
bool toggleState_3 = LOW; //Define integer to remember the toggle state for relay 3
bool toggleState_4 = LOW; //Define integer to remember the toggle state for relay 4
bool toggleState_5 = LOW; //Define integer to remember the toggle state for relay 5
bool toggleState_6 = LOW; //Define integer to remember the toggle state for relay 6
bool toggleState_7 = LOW; //Define integer to remember the toggle state for relay 7
bool toggleState_8 = LOW; //Define integer to remember the toggle state for relay 8
bool toggleState_9 = LOW; //Define integer to remember the toggle state for relay 9
bool toggleState_10 = LOW; //Define integer to remember the toggle state for relay 10
bool toggleState_11 = LOW; //Define integer to remember the toggle state for relay 11
bool toggleState_12 = LOW; //Define integer to remember the toggle state for relay 12
bool toggleState_13 = LOW; //Define integer to remember the toggle state for relay 13
bool toggleState_14 = LOW; //Define integer to remember the toggle state for relay 14
bool toggleState_15 = LOW; //Define integer to remember the toggle state for relay 15
bool toggleState_16 = LOW; //Define integer to remember the toggle state for relay 16
// Switch State
bool SwitchState_1 = LOW;
bool SwitchState_2 = LOW;
bool SwitchState_3 = LOW;
bool SwitchState_4 = LOW;
bool SwitchState_5 = LOW;
bool SwitchState_6 = LOW;
bool SwitchState_7 = LOW;
bool SwitchState_8 = LOW;
bool SwitchState_9 = LOW;
bool SwitchState_10 = LOW;
bool SwitchState_11 = LOW;
bool SwitchState_12 = LOW;
bool SwitchState_13 = LOW;
bool SwitchState_14 = LOW;
bool SwitchState_15 = LOW;
bool SwitchState_16 = LOW;
IRrecv irrecv(IR_RECV_PIN);
decode_results results;
//The framework provides some standard device types like switch, lightbulb, fan, temperature sensor.
static Switch my_switch1(deviceName_1, &RelayPin1);
static Switch my_switch2(deviceName_2, &RelayPin2);
static Switch my_switch3(deviceName_3, &RelayPin3);
static Switch my_switch4(deviceName_4, &RelayPin4);
static Switch my_switch5(deviceName_5, &RelayPin5);
static Switch my_switch6(deviceName_6, &RelayPin6);
static Switch my_switch7(deviceName_7, &RelayPin7);
static Switch my_switch8(deviceName_8, &RelayPin8);
static Switch my_switch9(deviceName_9, &RelayPin9);
static Switch my_switch10(deviceName_10, &RelayPin10);
static Switch my_switch11(deviceName_11, &RelayPin11);
static Switch my_switch12(deviceName_12, &RelayPin12);
static Switch my_switch13(deviceName_13, &RelayPin13);
static Switch my_switch14(deviceName_14, &RelayPin14);
static Switch my_switch15(deviceName_15, &RelayPin15);
static Switch my_switch16(deviceName_16, &RelayPin16);
void sysProvEvent(arduino_event_t *sys_event)
    switch (sys_event->event_id) {
        case ARDUINO_EVENT_PROV_START:
#if CONFIG_IDF_TARGET_ESP32
        Serial.printf("\nProvisioning Started with name \"%s\" and PoP \"%s\" on BLE\n", service_name, pop);
        printQR(service_name, pop, "ble");
#else
        Serial.printf("\nProvisioning Started with name \"%s\" and PoP \"%s\" on SoftAP\n", service_name, pop);
        printQR(service_name, pop, "softap");
#endif
        case ARDUINO_EVENT_WIFI_STA_CONNECTED:
        Serial.printf("\nConnected to Wi-Fi!\n");
        digitalWrite(wifiLed, true);
void write_callback(Device *device, Param *param, const param_val_t val, void *priv_data, write_ctx_t *ctx)
  const char *device_name = device->getDeviceName();
  const char *param_name = param->getParamName();
  if(strcmp(device_name, deviceName_1) == 0) {
    Serial.printf("Lightbulb = %s\n", val.val.b? "true" : "false");
    if(strcmp(param_name, "Power") == 0) {
        Serial.printf("Received value = %s for %s - %s\n", val.val.b? "true" : "false", device_name, param_name);
      toggleState_1 = val.val.b;
      (toggleState_1 == false) ? digitalWrite(RelayPin1, HIGH) : digitalWrite(RelayPin1, LOW);
      param->updateAndReport(val);
      pref.putBool("Relay1", toggleState_1);
  } else if(strcmp(device_name, deviceName_2) == 0) {
    Serial.printf("Switch value = %s\n", val.val.b? "true" : "false");
      toggleState_2 = val.val.b;
      (toggleState_2 == false) ? digitalWrite(RelayPin2, HIGH) : digitalWrite(RelayPin2, LOW);
      pref.putBool("Relay2", toggleState_2);
  } else if(strcmp(device_name, deviceName_3) == 0) {
      toggleState_3 = val.val.b;
      (toggleState_3 == false) ? digitalWrite(RelayPin3, HIGH) : digitalWrite(RelayPin3, LOW);
      pref.putBool("Relay3", toggleState_3);
  } else if(strcmp(device_name, deviceName_4) == 0) {
      toggleState_4 = val.val.b;
      (toggleState_4 == false) ? digitalWrite(RelayPin4, HIGH) : digitalWrite(RelayPin4, LOW);
      pref.putBool("Relay4", toggleState_4);
  } else if(strcmp(device_name, deviceName_5) == 0) {
      toggleState_5 = val.val.b;
      (toggleState_5 == false) ? digitalWrite(RelayPin5, HIGH) : digitalWrite(RelayPin5, LOW);
      pref.putBool("Relay5", toggleState_5);
  } else if(strcmp(device_name, deviceName_6) == 0) {
      toggleState_6 = val.val.b;
      (toggleState_6 == false) ? digitalWrite(RelayPin6, HIGH) : digitalWrite(RelayPin6, LOW);
      pref.putBool("Relay6", toggleState_6);
  } else if(strcmp(device_name, deviceName_7) == 0) {
      toggleState_7 = val.val.b;
      (toggleState_7 == false) ? digitalWrite(RelayPin7, HIGH) : digitalWrite(RelayPin7, LOW);
      pref.putBool("Relay7", toggleState_7);
  } else if(strcmp(device_name, deviceName_8) == 0) {
      toggleState_8 = val.val.b;
      (toggleState_8 == false) ? digitalWrite(RelayPin8, HIGH) : digitalWrite(RelayPin8, LOW);
      pref.putBool("Relay8", toggleState_8);
  } else if(strcmp(device_name, deviceName_9) == 0) {
      toggleState_9 = val.val.b;
      (toggleState_9 == false) ? digitalWrite(RelayPin9, HIGH) : digitalWrite(RelayPin9, LOW);
      pref.putBool("Relay9", toggleState_9);
  } else if(strcmp(device_name, deviceName_10) == 0) {
      toggleState_10 = val.val.b;
      (toggleState_10 == false) ? digitalWrite(RelayPin10, HIGH) : digitalWrite(RelayPin10, LOW);
      pref.putBool("Relay10", toggleState_10);
  } else if(strcmp(device_name, deviceName_11) == 0) {
      toggleState_11 = val.val.b;
      (toggleState_11 == false) ? digitalWrite(RelayPin11, HIGH) : digitalWrite(RelayPin11, LOW);
      pref.putBool("Relay11", toggleState_11);
      toggleState_12 = val.val.b;
      (toggleState_12 == false) ? digitalWrite(RelayPin12, HIGH) : digitalWrite(RelayPin12, LOW);
      pref.putBool("Relay12", toggleState_12);
  } else if(strcmp(device_name, deviceName_13) == 0) {
      toggleState_13 = val.val.b;
      (toggleState_13 == false) ? digitalWrite(RelayPin13, HIGH) : digitalWrite(RelayPin13, LOW);
      pref.putBool("Relay13", toggleState_13);
  } else if(strcmp(device_name, deviceName_14) == 0) {
      toggleState_14 = val.val.b;
      (toggleState_14 == false) ? digitalWrite(RelayPin14, HIGH) : digitalWrite(RelayPin14, LOW);
      pref.putBool("Relay14", toggleState_14);
  } else if(strcmp(device_name, deviceName_15) == 0) {
      toggleState_15 = val.val.b;
      (toggleState_15 == false) ? digitalWrite(RelayPin15, HIGH) : digitalWrite(RelayPin15, LOW);
      pref.putBool("Relay15", toggleState_15);
  } else if(strcmp(device_name, deviceName_16) == 0) {
      toggleState_16 = val.val.b;
      (toggleState_16 == false) ? digitalWrite(RelayPin16, HIGH) : digitalWrite(RelayPin16, LOW);
      pref.putBool("Relay16", toggleState_16);
void ir_remote(){
  if (irrecv.decode(&results)) {
      switch(results.value){
          case IR_Button_1:
            digitalWrite(RelayPin1, toggleState_1);
            toggleState_1 = !toggleState_1;
            my_switch1.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, toggleState_1);
            delay(100);
          case IR_Button_2:
            digitalWrite(RelayPin2, toggleState_2);
            toggleState_2 = !toggleState_2;
            my_switch2.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, toggleState_2);
            delay(100);
          case IR_Button_3:
            digitalWrite(RelayPin3, toggleState_3);
            toggleState_3 = !toggleState_3;
            my_switch3.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, toggleState_3);
            delay(100);
          case IR_Button_4:
            digitalWrite(RelayPin4, toggleState_4);
            toggleState_4 = !toggleState_4;
            my_switch4.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, toggleState_4);
            delay(100);
          case IR_Button_5:
            digitalWrite(RelayPin5, toggleState_5);
            toggleState_5 = !toggleState_5;
            my_switch5.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, toggleState_5);
            delay(100);
          case IR_Button_6:
            digitalWrite(RelayPin6, toggleState_6);
            toggleState_6 = !toggleState_6;
            my_switch6.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, toggleState_6);
            delay(100);
          case IR_Button_7:
            digitalWrite(RelayPin7, toggleState_7);
            toggleState_7 = !toggleState_7;
            my_switch7.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, toggleState_7);
            delay(100);
          case IR_Button_8:
            digitalWrite(RelayPin8, toggleState_8);
            toggleState_8 = !toggleState_8;
            my_switch8.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, toggleState_8);
            delay(100);
          case IR_Button_9:
            digitalWrite(RelayPin9, toggleState_9);
            toggleState_9 = !toggleState_9;
            my_switch9.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, toggleState_9);
            delay(100);
          case IR_Button_10:
            digitalWrite(RelayPin10, toggleState_10);
            toggleState_10 = !toggleState_10;
            my_switch10.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, toggleState_10);
            delay(100);
          case IR_Button_11:
            digitalWrite(RelayPin11, toggleState_11);
            toggleState_11 = !toggleState_11;
            my_switch11.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, toggleState_11);
            delay(100);
          case IR_Button_12:
            digitalWrite(RelayPin12, toggleState_12);
            toggleState_12 = !toggleState_12;
            my_switch12.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, toggleState_12);
            delay(100);
          case IR_Button_13:
            digitalWrite(RelayPin13, toggleState_13);
            toggleState_13 = !toggleState_13;
            my_switch13.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, toggleState_13);
            delay(100);
          case IR_Button_14:
            digitalWrite(RelayPin14, toggleState_14);
            toggleState_14 = !toggleState_14;
            my_switch14.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, toggleState_14);
            delay(100);
          case IR_Button_15:
            digitalWrite(RelayPin15, toggleState_15);
            toggleState_15 = !toggleState_15;
            my_switch15.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, toggleState_15);
            delay(100);
          case IR_Button_16:
            digitalWrite(RelayPin16, toggleState_16);
            toggleState_16 = !toggleState_16;
            my_switch16.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, toggleState_16);
            delay(100);
          case IR_All_Off:
            all_SwitchOff();
          case IR_All_On:
            all_SwitchOn();
          default : break;
        //Serial.println(results.value, HEX);
        irrecv.resume();
void all_SwitchOff(){
  toggleState_1 = 0; digitalWrite(RelayPin1, HIGH); pref.putBool("Relay1", toggleState_1); my_switch1.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, toggleState_1); delay(100);
  toggleState_2 = 0; digitalWrite(RelayPin2, HIGH); pref.putBool("Relay2", toggleState_2); my_switch2.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, toggleState_2); delay(100);
  toggleState_3 = 0; digitalWrite(RelayPin3, HIGH); pref.putBool("Relay3", toggleState_3); my_switch3.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, toggleState_3); delay(100);
  toggleState_4 = 0; digitalWrite(RelayPin4, HIGH); pref.putBool("Relay4", toggleState_4); my_switch4.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, toggleState_4); delay(100);
  toggleState_5 = 0; digitalWrite(RelayPin5, HIGH); pref.putBool("Relay5", toggleState_5); my_switch5.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, toggleState_5); delay(100);
  toggleState_6 = 0; digitalWrite(RelayPin6, HIGH); pref.putBool("Relay6", toggleState_6); my_switch6.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, toggleState_6); delay(100);
  toggleState_7 = 0; digitalWrite(RelayPin7, HIGH); pref.putBool("Relay7", toggleState_7); my_switch7.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, toggleState_7); delay(100);
  toggleState_8 = 0; digitalWrite(RelayPin8, HIGH); pref.putBool("Relay8", toggleState_8); my_switch8.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, toggleState_8); delay(100);
  toggleState_9 = 0; digitalWrite(RelayPin9, HIGH); pref.putBool("Relay1", toggleState_9); my_switch1.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, toggleState_9); delay(100);
  toggleState_10 = 0; digitalWrite(RelayPin10, HIGH); pref.putBool("Relay2", toggleState_10); my_switch2.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, toggleState_10); delay(100);
  toggleState_11 = 0; digitalWrite(RelayPin11, HIGH); pref.putBool("Relay3", toggleState_11); my_switch3.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, toggleState_11); delay(100);
  toggleState_12 = 0; digitalWrite(RelayPin12, HIGH); pref.putBool("Relay4", toggleState_12); my_switch4.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, toggleState_12); delay(100);
  toggleState_13 = 0; digitalWrite(RelayPin13, HIGH); pref.putBool("Relay5", toggleState_13); my_switch5.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, toggleState_13); delay(100);
  toggleState_14 = 0; digitalWrite(RelayPin14, HIGH); pref.putBool("Relay6", toggleState_14); my_switch6.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, toggleState_14); delay(100);
  toggleState_15 = 0; digitalWrite(RelayPin15, HIGH); pref.putBool("Relay7", toggleState_15); my_switch7.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, toggleState_15); delay(100);
  toggleState_16 = 0; digitalWrite(RelayPin16, HIGH); pref.putBool("Relay8", toggleState_16); my_switch8.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, toggleState_16); delay(100);
void all_SwitchOn(){
  toggleState_1 = 1; digitalWrite(RelayPin1, LOW); pref.putBool("Relay1", toggleState_1); my_switch1.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, toggleState_1); delay(100);
  toggleState_2 = 1; digitalWrite(RelayPin2, LOW); pref.putBool("Relay2", toggleState_2); my_switch2.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, toggleState_2); delay(100);
  toggleState_3 = 1; digitalWrite(RelayPin3, LOW); pref.putBool("Relay3", toggleState_3); my_switch3.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, toggleState_3); delay(100);
  toggleState_4 = 1; digitalWrite(RelayPin4, LOW); pref.putBool("Relay4", toggleState_4); my_switch4.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, toggleState_4); delay(100);
  toggleState_5 = 1; digitalWrite(RelayPin5, LOW); pref.putBool("Relay5", toggleState_5); my_switch5.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, toggleState_5); delay(100);
  toggleState_6 = 1; digitalWrite(RelayPin6, LOW); pref.putBool("Relay6", toggleState_6); my_switch6.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, toggleState_6); delay(100);
  toggleState_7 = 1; digitalWrite(RelayPin7, LOW); pref.putBool("Relay7", toggleState_7); my_switch7.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, toggleState_7); delay(100);
  toggleState_8 = 1; digitalWrite(RelayPin8, LOW); pref.putBool("Relay8", toggleState_8); my_switch8.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, toggleState_8); delay(100);
  toggleState_9 = 1; digitalWrite(RelayPin9, LOW); pref.putBool("Relay1", toggleState_9); my_switch1.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, toggleState_9); delay(100);
  toggleState_10 = 1; digitalWrite(RelayPin10, LOW); pref.putBool("Relay2", toggleState_10); my_switch2.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, toggleState_10); delay(100);
  toggleState_11 = 1; digitalWrite(RelayPin11, LOW); pref.putBool("Relay3", toggleState_11); my_switch3.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, toggleState_11); delay(100);
  toggleState_12 = 1; digitalWrite(RelayPin12, LOW); pref.putBool("Relay4", toggleState_12); my_switch4.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, toggleState_12); delay(100);
  toggleState_13 = 1; digitalWrite(RelayPin13, LOW); pref.putBool("Relay5", toggleState_13); my_switch5.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, toggleState_13); delay(100);
  toggleState_14 = 1; digitalWrite(RelayPin14, LOW); pref.putBool("Relay6", toggleState_14); my_switch6.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, toggleState_14); delay(100);
  toggleState_15 = 1; digitalWrite(RelayPin15, LOW); pref.putBool("Relay7", toggleState_15); my_switch7.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, toggleState_15); delay(100);
  toggleState_16 = 1; digitalWrite(RelayPin16, LOW); pref.putBool("Relay8", toggleState_16); my_switch8.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, toggleState_16); delay(100);
void getRelayState()
  toggleState_1 = pref.getBool("Relay1", 0);
  digitalWrite(RelayPin1, !toggleState_1);
  delay(200);
  toggleState_2 = pref.getBool("Relay2", 0);
  digitalWrite(RelayPin2, !toggleState_2);
  delay(200);
  toggleState_3 = pref.getBool("Relay3", 0);
  digitalWrite(RelayPin3, !toggleState_3);
  delay(200);
  toggleState_4 = pref.getBool("Relay4", 0);
  digitalWrite(RelayPin4, !toggleState_4);
  delay(200);
  toggleState_5 = pref.getBool("Relay5", 0);
  digitalWrite(RelayPin5, !toggleState_5);
  delay(200);
  toggleState_6 = pref.getBool("Relay6", 0);
  digitalWrite(RelayPin6, !toggleState_6);
  delay(200);
  toggleState_7 = pref.getBool("Relay7", 0);
  digitalWrite(RelayPin7, !toggleState_7);
  delay(200);
  toggleState_8 = pref.getBool("Relay8", 0);
  digitalWrite(RelayPin8, !toggleState_8);
  delay(200);
  toggleState_9 = pref.getBool("Relay1", 0);
  digitalWrite(RelayPin9, !toggleState_9);
  delay(200);
  toggleState_10 = pref.getBool("Relay2", 0);
  digitalWrite(RelayPin10, !toggleState_10);
  delay(200);
  toggleState_11 = pref.getBool("Relay3", 0);
  digitalWrite(RelayPin11, !toggleState_11);
  delay(200);
  toggleState_12 = pref.getBool("Relay4", 0);
  digitalWrite(RelayPin12, !toggleState_12);
  delay(200);
  toggleState_13 = pref.getBool("Relay5", 0);
  digitalWrite(RelayPin13, !toggleState_13);
  delay(200);
  toggleState_14 = pref.getBool("Relay6", 0);
  digitalWrite(RelayPin14, !toggleState_14);
  delay(200);
  toggleState_15 = pref.getBool("Relay7", 0);
  digitalWrite(RelayPin15, !toggleState_15);
  delay(200);
  toggleState_16 = pref.getBool("Relay8", 0);
  digitalWrite(RelayPin16, !toggleState_16);
  delay(200);
    pref.begin("Relay_State", false);
    // Set the Relays GPIOs as output mode
    pinMode(RelayPin1, OUTPUT);
    pinMode(RelayPin2, OUTPUT);
    pinMode(RelayPin3, OUTPUT);
    pinMode(RelayPin4, OUTPUT);
    pinMode(RelayPin5, OUTPUT);
    pinMode(RelayPin6, OUTPUT);
    pinMode(RelayPin7, OUTPUT);
    pinMode(RelayPin8, OUTPUT);
    pinMode(RelayPin9, OUTPUT);
    pinMode(RelayPin10, OUTPUT);
    pinMode(RelayPin11, OUTPUT);
    pinMode(RelayPin12, OUTPUT);
    pinMode(RelayPin13, OUTPUT);
    pinMode(RelayPin14, OUTPUT);
    pinMode(RelayPin15, OUTPUT);
    pinMode(RelayPin16, OUTPUT);
    pinMode(wifiLed, OUTPUT);
    // Write to the GPIOs the default state on booting
    digitalWrite(wifiLed, LOW);
    irrecv.enableIRIn(); // Enabling IR sensor
    Node my_node;
    my_node = RMaker.initNode(nodeName);
    //Standard switch device
    my_switch1.addCb(write_callback);
    my_switch2.addCb(write_callback);
    my_switch3.addCb(write_callback);
    my_switch4.addCb(write_callback);
    my_switch5.addCb(write_callback);
    my_switch6.addCb(write_callback);
    my_switch7.addCb(write_callback);
    my_switch8.addCb(write_callback);
    my_switch9.addCb(write_callback);
    my_switch10.addCb(write_callback);
    my_switch11.addCb(write_callback);
    my_switch12.addCb(write_callback);
    my_switch13.addCb(write_callback);
    my_switch14.addCb(write_callback);
    my_switch15.addCb(write_callback);
    my_switch16.addCb(write_callback);
    //Add switch device to the node
    my_node.addDevice(my_switch1);
    my_node.addDevice(my_switch2);
    my_node.addDevice(my_switch3);
    my_node.addDevice(my_switch4);
    my_node.addDevice(my_switch5);
    my_node.addDevice(my_switch6);
    my_node.addDevice(my_switch7);
    my_node.addDevice(my_switch8);
    my_node.addDevice(my_switch9);
    my_node.addDevice(my_switch10);
    my_node.addDevice(my_switch11);
    my_node.addDevice(my_switch12);
    my_node.addDevice(my_switch13);
    my_node.addDevice(my_switch14);
    my_node.addDevice(my_switch15);
    my_node.addDevice(my_switch16);
    //This is optional
    RMaker.enableOTA(OTA_USING_PARAMS);
    //If you want to enable scheduling, set time zone for your region using setTimeZone().
    //The list of available values are provided here https://rainmaker.espressif.com/docs/time-service.html
    // RMaker.setTimeZone("Asia/Shanghai");
    // Alternatively, enable the Timezone service and let the phone apps set the appropriate timezone
    RMaker.enableTZService();
    RMaker.enableSchedule();
    //Service Name
    for(int i=0; i<17; i=i+8) {
      espChipId |= ((ESP.getEfuseMac() >> (40 - i)) & 0xff) << i;
    Serial.printf("\nChip ID:  %d Service Name: %s\n", espChipId, service_name);
    Serial.printf("\nStarting ESP-RainMaker\n");
    RMaker.start();
    WiFi.onEvent(sysProvEvent);
    WiFiProv.beginProvision(WIFI_PROV_SCHEME_BLE, WIFI_PROV_SCHEME_HANDLER_FREE_BTDM, WIFI_PROV_SECURITY_1, pop, service_name);
#else
    WiFiProv.beginProvision(WIFI_PROV_SCHEME_SOFTAP, WIFI_PROV_SCHEME_HANDLER_NONE, WIFI_PROV_SECURITY_1, pop, service_name);
#endif
    getRelayState(); // Get the last state of Relays
    // Read GPIO0 (external button to reset device
    if(digitalRead(gpio_reset) == LOW) { //Push button pressed
        Serial.printf("Reset Button Pressed!\n");
        // Key debounce handling
        delay(100);
        int startTime = millis();
        while(digitalRead(gpio_reset) == LOW) delay(50);
        int endTime = millis();
        if ((endTime - startTime) > 10000) {
          // If key pressed for more than 10secs, reset all
          Serial.printf("Reset to factory.\n");
          RMakerFactoryReset(2);
        } else if ((endTime - startTime) > 3000) {
          Serial.printf("Reset Wi-Fi.\n");
          // If key pressed for more than 3secs, but less than 10, reset Wi-Fi
          RMakerWiFiReset(2);
    delay(100);
    if (WiFi.status() != WL_CONNECTED)
      //Serial.println("WiFi Not Connected");
      digitalWrite(wifiLed, false);
      //Serial.println("WiFi Connected");
    ir_remote(); //IR remote Control
Is toggleState initialized correctly? Is this code what you want?
Hello iystreem186
I did made a small code review and I´ve found alot of code dublicates.
Do you have experience with programming in C++?
The task can easily be realised with an object.
A structured array contains all the information, such as the pin addresses for the I/O devices, as well as the information for the timing.
A single service takes care of this information and initiates the intended action.
The structured array makes the sketch scalable until all I/O pins are used up without having to adapt the code for the service.
It is cool stuff, isn´t it?
Hi!
I'm playing with OP code to learn something.
Following the suggestion of @paulpaulson I did in this way:
#define NUM_RELAYS 16
struct INFOS
  const char deviceName[8];
  const uint8_t relayPin;
  bool relayState;
  uint16_t irCode;
INFOS info[NUM_RELAYS] =
  {"Relay1", 4, LOW, 0x10},
  {"Relay2", 5, LOW, 0x810},
  {"Relay3", 18, LOW, 0x410},
  {"Relay4", 19, LOW, 0xC10},
  {"Relay5", 21, LOW, 0x210},
  {"Relay6", 22, LOW, 0xA10},
  {"Relay7", 23, LOW, 0x610},
  {"Relay8", 25, LOW, 0xE10},
  {"Relay9", 26, LOW, 0x110},
  {"Relay10", 27, LOW, 0xFD0},
  {"Relay11", 32, LOW, 0x910},
  {"Relay12", 33, LOW, 0xDD0},
  {"Relay13", 13, LOW, 0x490},
  {"Relay14", 12, LOW, 0x90},
  {"Relay15", 14, LOW, 0xC90},
  {"Relay16", 15, LOW, 0x5D0}
Now how I can put this objects in an array?
Node my_node;
Initially I was thinking I could pass infos to first object in this way:
static Switch my_switch[NUM_RELAYS];
my_switch[0](info[0].deviceName, &info[0].relayPin);
But I have this compiling errors:
For info[0].deviceName:
 a value of type "const char *" cannot be used to initialize an entity of type "Switch [0]"
For &info[0].relayPin:
too many initializer values
expression list treated as compound expression in initializer [-fpermissive]
Thanks in advance.
Best regards.
Hi, @iystreem186
Did you write your code in stages?
Have you bits of code that check each piece of hardware INDIVIDUALLY and proves you have the control you need?
You have a lot of code there to suddenly find the response from the relays you have.
Thanks.. Tom.. :smiley: :+1: :coffee: :australia:
Hi!
Here my version of OP code.
There's a compiling error that I don't know how to solve.
If someone can help me I will be grateful.
src/main.cpp: In function 'void setup()':
src/main.cpp:179:62: error: expression list treated as compound expression in initializer [-fpermissive]
     Switch my_switch[i](info[i].deviceName, &info[i].relayPin);
src/main.cpp:179:62: error: array must be initialized with a brace-enclosed initializer
#include "RMaker.h"
#include "WiFi.h"
Preferences pref;
struct INFOS
  bool relayState;
  uint16_t irCode;
static uint8_t wifiLedPin      = 2; // D2
void all_SwitchOn();
void all_SwitchOff();
      #else
      #endif
      digitalWrite(wifiLedPin, true);
  for(byte i = 0; i < NUM_RELAYS; i++)
    if(strcmp(device_name, info[i].deviceName) == 0)
        info[i].relayState = val.val.b;
        digitalWrite(info[i].relayPin, info[i].relayState);
        pref.putBool(info[i].deviceName, info[i].relayState);
void ir_remote()
  if (irrecv.decode())
      if(irrecv.decodedIRData.command == info[i].irCode)
        info[i].relayState = !info[i].relayState;
        my_switch[i].updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, info[i].relayState);
        delay(100);
        // Serial.println(results.value, HEX);
    if(irrecv.decodedIRData.command == IR_All_Off)
      all_SwitchOff();
    else if (irrecv.decodedIRData.command == IR_All_On)
      all_SwitchOn();
    irrecv.resume();
    info[i].relayState = LOW;
void all_SwitchOn()
    info[i].relayState = HIGH;
    info[i].relayState = pref.getBool(info[i].deviceName, 0);
  delay(200);
  Node my_node[NUM_RELAYS];
    pinMode(info[i].relayPin, OUTPUT);
    my_node[i] = RMaker.initNode(nodeName);
    my_switch[i].addCb(write_callback);
    my_node[i].addDevice(my_switch[i]);
  pinMode(wifiLedPin, OUTPUT);
  digitalWrite(wifiLedPin, LOW);
  // This is optional
  // If you want to enable scheduling, set time zone for your region using setTimeZone().
  // The list of available values are provided here https://rainmaker.espressif.com/docs/time-service.html
  // Service Name
  for(int i = 0; i < 17; i = i + 8)
  RMaker.start();
  #else
  #endif
  if(digitalRead(gpio_reset) == LOW)     // Push button pressed
    delay(100);
      delay(50);
      RMakerWiFiReset(2);
  delay(100);
    // Serial.println("WiFi Not Connected");
    digitalWrite(wifiLedPin, false);
    // Serial.println("WiFi Connected");
  ir_remote();   // IR remote Control
Best regards.
i dont think so
to be honest I am not good when it comes to c++
thanks for the suggestion
Hi @J-M-L!
Please could you help me fix this compiling error?
Thanks in advance.
Best regards.
the statement definitely cannot start with Switch as this would be a new definition of a variable
usually when you don't initialise the instance (call the constructor) at definition time you would have a begin() or init() method where you can provide the necessary information. Something like
my_switch[i].init(info[i].deviceName, &info[i].relayPin);
where is the Switch class defined ? can you create switch instances without passing anything as you do here
and have a method to pass the name and pin later ?
otherwise you have to create a new instance and copy
my_switch[i] = Switch(info[i].deviceName, &info[i].relayPin);
(given the compiler did not complain for the array, I would try first the latter option)
Thanks for your attention!
I don't have experience with this library/framework I'm just trying help OP.
I'm following examples but all I can find is like OP code. There's no example using array.
This class is defined here in this way:
class Switch : public Device
    public:
        Switch()
            standardSwitchDevice("Switch", NULL, true);
        Switch(const char *dev_name, void *priv_data = NULL, bool power = true)
            standardSwitchDevice(dev_name, priv_data, power);
        void standardSwitchDevice(const char *dev_name, void *priv_data, bool power)
            esp_rmaker_device_t *dev_handle = esp_rmaker_switch_device_create(dev_name, priv_data, power);
            setDeviceHandle(dev_handle);
            if(dev_handle == NULL){
                log_e("Switch device not created");
Removing Switch from setup the error changes to:
src/main.cpp:179:55: error: no match for call to '(Switch) (const char [8], const uint8_t*)'
OK - so there is a constructor that does take no param and initialise the Switch with default parameters ("Switch", NULL, true)
just replace the buggy line by this
and you should be good to go
Unfortunately no. :neutral_face:
/rainMaker/rainMaker.ino: In function 'void setup()':
/rainMaker/rainMaker.ino:179:47: error: invalid conversion from 'const void*' to 'void*' [-fpermissive]
/home/fernandogarcia/.arduino15/packages/esp32/hardware/esp32/2.0.2/libraries/RainMaker/src/RMakerDevice.h:77:44: note:   initializing argument 2 of 'Switch::Switch(const char*, void*, bool)'
exit status 1
Compilation error: invalid conversion from 'const void*' to 'void*' [-fpermissive]
I had assumed the parameters were right
change
struct INFOS
  bool relayState;
  uint16_t irCode;
into
struct INFOS
  const char * deviceName;
  bool relayState;
  uint16_t irCode;
as you don't need a modifiable deviceName and you'll get directly a const char pointer
my_switch[i] = Switch(info[i].deviceName, &(info[i].relayPin));
You INFOS structure is probably redundant with the Switch class, you don't need to keep the name and PIN number in both and I assume the class maintains the switch state as well...
You could want to subclass the Switch class and and the irCode as a new instance variable
on second thoughts I would rewrite that Switch class thingy, it's weird on how you need to duplicate things
Same problem.
   delay(200);
In file included from /home/fernandogarcia/.arduino15/packages/esp32/hardware/esp32/2.0.2/libraries/RainMaker/src/RMakerNode.h:4,
from /home/fernandogarcia/.arduino15/packages/esp32/hardware/esp32/2.0.2/libraries/RainMaker/src/RMaker.h:5,
from /rainMaker/rainMaker.ino:1:
No way to me, I'm completely lost. A pull request to up stream could be welcome. :slight_smile:
I tried many things following your edited advice but with no luck.
Thanks for your time.
Looking for this example it's declared in similar way but I don't know why it doesn't work with array.
static Switch my_switch;
static int gpio_switch = 16;
  my_switch = Switch("Switch", &gpio_switch);
this might be because of
try removing the const
It did the trick! Thank you for your help.
Now the problem is make the rainMaker work even with basic example.
I have lots of errors.
E (575) esp_rmaker_device: Failed to allocate me����y for Device Switch
[     1][E][RMakerDevice.h:100] standardSwitchDevice(): Switch device not created
E (19) esp_rmaker_fctry: NVS Flash init failed
E (19) esp_rmaker_core: Failed to initialise storage
[    24][E][RMaker.cpp:75] initNode(): Node init failed
E (21) esp_rmaker_device: Failed to allocate memory for Device Switch
[    33][E][RMakerDevice.h:100] standardSwitchDevice(): Switch device not created
E (35) esp_rmaker_device: Device handle cannot be NULL
[    45][E][RMakerDevice.cpp:48] addCb(): Callback register error
E (45) esp_rmaker_node: Node or Device/Service handle cannot be NULL.
[    57][E][RMakerNode.cpp:10] addDevice(): Device was not added to the Node
E (58) esp_rmaker_device: Failed to allocate memory for Service Time
E (65) esp_rmaker_time_service: Failed to create Time Service
[    75][E][RMaker.cpp:131] enableTZService(): Timezone service enable failed
E (77) esp_rmaker_schedule: Couldn't allocate schedule_priv_data
[    88][E][RMaker.cpp:122] enableSchedule(): Schedule enable failed
E (89) esp_rmaker_scenes: Couldn't allocate scenes_priv_data
[    99][E][RMaker.cpp:154] enableScenes(): Scenes enable failed
@iystreem186 can you try the code below?
#include "RMaker.h"
#include "WiFi.h"
Preferences pref;
char nodeName[] = "ESP32_Relay_16";
struct INFOS
  uint8_t relayPin;
  bool relayState;
  uint16_t irCode;
      #else
      #endif
void ir_remote()
        delay(100);
      all_SwitchOff();
      all_SwitchOn();
    irrecv.resume();
void all_SwitchOn()
  delay(200);
  Node my_node;
    my_node.addDevice(my_switch[i]);
  // This is optional
  //RMaker.setTimeZone("America/Sao_Paulo");
  //RMaker.enableScenes();
  RMaker.start();
  #else
  #endif
  // Service Name
    delay(100);
      delay(50);
      RMakerWiFiReset(2);
  delay(100);
