Need Help with Database /EEprom(RFID)
hello everyone !,
I am fairly new to Arduino , but i am very keen in learning more about Arduino,At the moment I am trying to build a project using Parallax RFID reader and servo where there are four users( RF ID cards) and the servo acts as a gate , I was interested in making a Table or sort of a database to keep the record of the 4 users . I have already managed to write the code for the reader and the servo to work but I was just wondering if it was possible to create a table and make changes in the table which would automatically make changes in the code. When i say changes, i mean giving access or denying access.
I do apologise, if my statements don’t make any sense , please be gentle with me :slight_smile:
I would be extrememly grateful If anyone could give me heads up and hints to get started.
Much appreciated
Thanks
No.
Yes.
You have to define what you want to do. In these sorts of system there is normally an enroll mode. This can store a token in EEPROM either to replace an existing entry or create a new one. For access you need to search this table to see if the card you have is in the table.
This is the sort of thing I do in this project:-
RFID Sequencer
The code is on the site and you need small sections of it, hope you can find what you are looking for.
Really Appreciate ur reply.
I do understand quite a bit of what you said , And your project was a very good reference as well .However It would be nice if you could direct me to something of a much smaller scale or a link to an example maybe ?
I also wanted to know if it was possible to do this using arrays but I haven't got any clue on to how to write a file using arrays and I have referred to couple of books but Didnt find a proper solution , hope you can direct me to some where.
Many thanks
Saving the token in memory is done by this:-
void saveToken(int point){ // saves the token in EEprom memory at point
    EEPROM.write(point, (tokensOnBoard[0] >> 24) & 0xff);
    EEPROM.write(point+1, (tokensOnBoard[0] >> 16) & 0xff);
    EEPROM.write(point+2, (tokensOnBoard[0] >> 8) & 0xff);
    EEPROM.write(point+3, tokensOnBoard[0] & 0xff);
This takes the 4 byte long int tokensOnBoard[0] and splits it up into 4 bytes and stores it in EEPROM at an address passed into it called point.
This:-
int matchToken(unsigned long token){
   int i = 0;
   boolean found = false;
   while( found == false && i < 1000){
     if( EEPROM.read(i) == ((token >> 24)& 0xff) &&  EEPROM.read(i+1) == ((token >> 16)& 0xff)
             &&  EEPROM.read(i+2) == ((token >> 8)& 0xff) &&  EEPROM.read(i+3) == (token & 0xff) ){
               found = true;
           if(!found) i +=4; // move on to the start of the next entry
   if(found) return i; else return -1;
searches the EEPROM memory for a match of a token passed into it.
This:-
int findFreeEntry(){
   int i = 0;
     if( EEPROM.read(i) == 0xff && EEPROM.read(i+1) == 0xff && EEPROM.read(i+2) == 0xff && EEPROM.read(i+3) == 0xff ) found = true;
     if(!found) i +=4;
searches the EEPROM memory for a free entry. It returns the address of the next free entry in the data base or -1 if the memory is full.
