Need help with datalogger from Arduino libraries
I have the code to log data from sensors that is on the SD Library and I also have a code for a Geiger counter but I don't know how to implement my Geiger code into the datalogger code.
The DataLogger code
  SD card datalogger
 This example shows how to log data from three analog sensors
 to an SD card using the SD library.
 The circuit:
 * analog sensors on analog ins 0, 1, and 2
 * SD card attached to SPI bus as follows:
 ** MOSI - pin 11
 ** MISO - pin 12
 ** CLK - pin 13
 ** CS - pin 4 (for MKRZero SD: SDCARD_SS_PIN)
 created  24 Nov 2010
 modified 9 Apr 2012
 by Tom Igoe
 This example code is in the public domain.
#include <SPI.h>
#include <SD.h>
const int chipSelect = 4;
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Serial.print("Initializing SD card...");
  // see if the card is present and can be initialized:
  if (!SD.begin(chipSelect)) {
    Serial.println("Card failed, or not present");
    // don't do anything more:
    return;
  Serial.println("card initialized.");
  // make a string for assembling the data to log:
  String dataString = "";
  // read three sensors and append to the string:
  for (int analogPin = 0; analogPin < 3; analogPin++) {
    int sensor = analogRead(analogPin);
    dataString += String(sensor);
    if (analogPin < 2) {
      dataString += ",";
  // open the file. note that only one file can be open at a time,
  // so you have to close this one before opening another.
  File dataFile = SD.open("datalog.txt", FILE_WRITE);
  // if the file is available, write to it:
  if (dataFile) {
    dataFile.println(dataString);
    dataFile.close();
    // print to the serial port too:
    Serial.println(dataString);
  // if the file isn't open, pop up an error:
  else {
    Serial.println("error opening datalog.txt");
The Geiger counter code
#include <SD.h>
#include <SPI.h>
#define LOG_PERIOD 15000     //Logging period in milliseconds, recommended value 15000-60000.
#define MAX_PERIOD 60000    //Maximum logging period
unsigned long counts;             //variable for GM Tube events
unsigned long cpm;                 //variable for CPM
unsigned int multiplier;             //variable for calculation CPM in this sketch
unsigned long previousMillis;      //variable for time measurement
void tube_impulse(){               //procedure for capturing events from Geiger Kit
  counts++;
void setup(){                                               //setup procedure
  counts = 0;
  cpm = 0;
  multiplier = MAX_PERIOD / LOG_PERIOD;      //calculating multiplier, depend on your log period
  Serial.begin(9600);                                    // start serial monitor
 // uncommennt if you have time-out problem to connect with Radiation Logger
 //  delay(2000);
 //  Serial.write('0');                                      // sending zero to avoid connection time out with radiation logger
 //  delay(2000);
  pinMode(2, INPUT);                                   // set pin INT0 input for capturing GM Tube events
  digitalWrite(2, HIGH);                                 // turn on internal pullup resistors, solder C-INT on the PCB
  attachInterrupt(0, tube_impulse, FALLING);  //define external interrupts
void loop(){                                               //main cycle
  if(currentMillis - previousMillis > LOG_PERIOD){
    cpm = counts * multiplier;
        Serial.print(cpm);                              // send cpm data to Radiation Logger
        Serial.write(' ');                                // send null character to separate next data
    counts = 0;
