Need Help With EEPROM 11AA040
I'm trying to read and write to a EEPROM, everything I try seems to fail. Anyone every used the UNI/O single wire EEPROM.
Link to the EEPROM
Code that I've tried for the writer.
#define SCIO_PIN 5
#define DEVICE_ADDRESS 0xA0
  pinMode(SCIO_PIN, OUTPUT);
  //send write enable
  writeEnable();
// Standby Pulse
sendStartHeader();
// Send Write Command
sendCommand(0x6C);
sendAck(true);
// Send Word Address MSB and LSB
sendByte(0x00);
sendAck(true);
sendByte(0x00);
sendAck(true);
// Send Data Bytes
sendByte(0x12);
sendAck(true);
sendByte(0x34);
sendAck(false);
delayMicroseconds(5);
void sendStartHeader() {
  sendStandBy();
  digitalWrite(SCIO_PIN, LOW);
  delayMicroseconds(10);
  sendByte(0x55);
  sendAck(true);
void sendStandBy() {
  digitalWrite(SCIO_PIN, HIGH);
  delayMicroseconds(600);
void writeEnable(){
  sendStartHeader();
  sendCommand(0x96);
  sendAck(false);
void sendAck(bool ack) {
  sendBit(ack);
  readBit();
void sendBit(bool bit) {
  digitalWrite(SCIO_PIN, bit ? HIGH : LOW);
  pinMode(SCIO_PIN, INPUT_PULLUP);
void sendCommand(byte command) {
  sendByte(DEVICE_ADDRESS);
  sendAck(true);
  sendByte(command);
void sendByte(byte data) {
  for (int i = 7; i >= 0; i--) {
    bool bit = data & (1 << i);
    sendBit(bit);
byte readByte() {
  byte data = 0;
    bool bit = readBit();
    data |= (bit << i);
  return data;
bool readBit() {
  bool bit = digitalRead(SCIO_PIN);
  return bit;
Code ive tried for the reader
#define SCIO_PIN 5
  // Standby Pulse
sendStandBy();
// StartHeader
sendStartHeader();
sendCommand(0x03);
sendByte(0x00);
sendAck(true);
sendByte(0x00);
sendAck(true);
// Read Data
byte data = readByte();
Serial.println(String(data, HEX));
sendAck(true);
data = readByte();
sendAck(true);
  sendByte(0x55);
  sendAck(true);
void writeEnable(){
  sendStandBy();
  sendStartHeader();
  sendCommand(0x96);
  sendBit(ack);
  readBit();
  sendAck(true);
  sendByte(command);
  sendAck(true);
    sendBit(bit);
byte readByte() {
  byte data = 0;
    data |= (bit << i);
  return data;
bool readBit() {
  return bit;
I've attempted this with a Arduino nano and a esp 32. Just keeps returning FF.
Maybe this link has more specific help...
https://forum.microchip.com/s/topic/a5C3l000000MVfYEAW/t351796?comment=P-2543122
Thanks for the reply however I have no idea where to even start with converting that to arduino code. I will play around with it and try.
I do not know how to translate datasheets into code, but the sequence starts on chapter 3 with creating the bus.
