I am creating an Arduino project using two ESP8266 and two loras SX1278 to create a communication channel between the two ESP8266. I would like to secure the communication by including an encryption library to the code, however, I am a beginner in this matter. Therefore, in this case, what encryption algorithm is recommended? (I was thinking of AES or SHA but I am not sure which one is suitable for the project) and also I need guidance on how to integrate it in the code I am working on which is the following: (The two ESP8266 have the same code)
You have to define what is "suitable". Forum members can't do that for you.
Pick one and follow the library examples to get started. They all work (or should work) if used properly, but none are certified to be cryptographically secure, by any modern definition.
As you learn how to use the libraries, you will gain a better idea of what might be best for your project.
Please do not duplicate your questions as doing so wastes the time and effort of the volunteers trying to help you as they are then answering the same thing in different places.
Please create one topic only for your question and choose the forum category carefully. If you have multiple questions about the same project then please ask your questions in the one topic as the answers to one question provide useful context for the others, and also you won’t have to keep explaining your project repeatedly.
Repeated duplicate posting could result in a temporary or permanent ban from the forum.
Could you take a few moments to Learn How To Use The Forum
Is there "really" any good reason to encrypt the data or are you just wanting to do so? Encryption takes energy and is almost always unnecessary, especially when battery operation is needed.
Often a simple obfuscation algorithm can be used rather than true encryption. Project builders should concern themselves with physical device security as having ones weather station stolen is more likely than a neighbor listening-in on your windspeed and temperature.
I have used Speck encryption because it can be very lightweight on processing requirements. It's not an extremely secure code, just "good enough" and that is what it was designed for.
That's the question. What are the chances someone is really out there with nefarious intentions of snooping on your little Arduino project? Why would they care? Why would they bother? Or is this just in case your tin foil hat falls off?
