Need help with ESP8266
Hello everyone. I would like to ask how to fix this code in order to control the pwm ESP8266 using the slider made in the MIT APP?
#include <ESP8266WiFi.h>
const char* ssid = "1234567890";
const char* password = "1234567890";
WiFiServer server(80);
const byte R1 = 2;
  pinMode(R1, OUTPUT);
  digitalWrite(R1, LOW);
  delay(10);
  Serial.print("Conecting to");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  server.begin();
  Serial.print("Use this URL to connect:");
  Serial.print("http://");
  Serial.print(WiFi.localIP());
  Serial.println("/");
  WiFiClient client = server.available();
  if (!client) {
    return;
  while (!client.available()) {
    delay(1);
  String request = client.readStringUntil('/r');
  client.flush();
  client.println("Content-Type: text/html");
  client.println("");
  client.println("<!DOCTYPE HTML>");
  client.println("<html>");
  if (request.indexOf("/On") != -1) {
  digitalWrite(R1, HIGH);
  else if (request.indexOf("/Off") != -1) {
Your sketch has no reference to PWM.
Your sketch has no reference to a slider or HTML creating one.
I wrote how to fix it... Where to start. It is not clear to me how the ESP should receive the signal from the slider and send it to the LED
If the communication must be done by a MIT app inventor App.
MIT App-inventor offers a WiFi module which can be used to send / receive data from / to the MIT App and your ESP8266
But there is an easier way to make this work.
Your ESP8266 can act as a little webserver that provides a simple website with control elements like buttons etc.
here is one example-code that uses the ESPUI-library
#define dbg(myFixedText, variableName) \
  Serial.print( F(#myFixedText " "  #variableName"=") ); \
  Serial.println(variableName);
#define dbgi(myFixedText, variableName,timeInterval) \
  do { \
    static unsigned long intervalStartTime; \
    if ( millis() - intervalStartTime >= timeInterval ){ \
      intervalStartTime = millis(); \
      Serial.println(variableName); \
  } while (false);
#include <DNSServer.h>
#include <ESPUI.h>
const byte DNS_PORT = 53;
IPAddress apIP(192, 168, 4, 1);
DNSServer dnsServer;
#if defined(ESP32)
#include <WiFi.h>
#else
#endif
const byte    OnBoard_LED = 2;
const char *home_ssid     = "your ssid";
const char *home_password = "your password minimum 8 characters";
//const char* AP_ssid = "ESPUI";
//const char* AP_password = "espui";
const char* AP_hostname = "espui";
uint16_t statusLabel_ID;
uint16_t button1_ID;
uint16_t ClickCounter = 0;
void PrintFileNameDateTime() {
  Serial.println( F("Code running comes from file ") );
  Serial.println( F(__FILE__) );
  Serial.print( F("  compiled ") );
  Serial.print( F(__DATE__) );
  Serial.print( F(" ") );
  Serial.println( F(__TIME__) );
// easy to use helper-function for non-blocking timing
boolean TimePeriodIsOver (unsigned long &startOfPeriod, unsigned long TimePeriod) {
  unsigned long currentMillis  = millis();
  if ( currentMillis - startOfPeriod >= TimePeriod ) {
    // more time than TimePeriod has elapsed since last time if-condition was true
    startOfPeriod = currentMillis; // a new period starts right here so set new starttime
    return true;
  else return false;            // actual TimePeriod is NOT yet over
void BlinkHeartBeatLED(int IO_Pin, int BlinkPeriod) {
  static unsigned long MyBlinkTimer;
  pinMode(IO_Pin, OUTPUT);
  if ( TimePeriodIsOver(MyBlinkTimer, BlinkPeriod) ) {
    digitalWrite(IO_Pin, !digitalRead(IO_Pin) );
void buttonCallback(Control* sender, int type) {
  Serial.print("ID: ");
  Serial.print(sender->id);
  Serial.print(" ");
  Serial.print(sender->label);
  switch (type) {
    case B_DOWN:
      Serial.println(" Button DOWN");
    case B_UP:
      Serial.println(" Button UP");
      ClickCounter++;
      ESPUI.updateControlValue(statusLabel_ID, String(ClickCounter) );
void connectToWiFi() {
#if defined(ESP32)
  WiFi.setHostname(AP_hostname); // xxy
#else
  WiFi.hostname(AP_hostname);
#endif
  // try to connect to existing network
  WiFi.begin(home_ssid, home_password);
  Serial.print("\n\nTry to connect to existing network");
  Serial.print(" named #");
  Serial.print(home_ssid);
  Serial.println("#");
    uint8_t timeout = 10;
    // Wait for connection, 5s timeout
    do {
      BlinkHeartBeatLED(OnBoard_LED, 100);
      Serial.print(".");
      timeout--;
    } while (timeout && WiFi.status() != WL_CONNECTED);
    // not connected -> create hotspot
    if (WiFi.status() != WL_CONNECTED) {
      Serial.print("\n\n no connection to SSID #");
      Serial.println("#\n Creating hotspot");
      WiFi.mode(WIFI_AP);
      delay(100);
      WiFi.softAPConfig(apIP, apIP, IPAddress(255, 255, 255, 0));
#if defined(ESP32)
      uint32_t chipid = 0;
      for (int i = 0; i < 17; i = i + 8) {
        chipid |= ((ESP.getEfuseMac() >> (40 - i)) & 0xff) << i;
#else
      uint32_t chipid = ESP.getChipId();
#endif
      char ap_ssid[25];
      snprintf(ap_ssid, 26, "ESPUI-%08X", chipid);
      WiFi.softAP(ap_ssid);
      Serial.print("SSID #");
      Serial.print(ap_ssid);
      timeout = 5;
      do {
        Serial.print(".");
        timeout--;
      } while (timeout);
  dnsServer.start(DNS_PORT, "*", apIP);
  Serial.println("\n\nWiFi parameters:");
  Serial.print("Mode: ");
  Serial.println(WiFi.getMode() == WIFI_AP ? "Station" : "Client");
  Serial.print("IP address: ");
  Serial.println(WiFi.getMode() == WIFI_AP ? WiFi.softAPIP() : WiFi.localIP());
  Serial.println("type this IP-adress into your browser to connect to the GUI of your ESP");
void defineGUI() {
  statusLabel_ID = ESPUI.label("Number of Clicks", ControlColor::Turquoise, "0");
  // statusLabel_ID     : number that is used to identfy the GUI-element
  // .label             : the type of the GUI-element
  // "Number of Clicks" : the text that describes the GUI-element
  // ControlColor::Turquoise : explains ITSELF
  // "0" initial VALUE shown on the element (will be updated on runtime)
  button1_ID = ESPUI.button("Push Button 1", &buttonCallback, ControlColor::Peterriver, "I'm Button 1 click me");
  // "Push Button 1": show text "Push Button 1" as the description of the GUI-Element
  // &buttonCallback:  ampersand-symbol '&' followed by the NAME of the callback-function
  //                   that shall be executed if a user clicks on the button in his browser
  //                   the ampersand-symbol tells the compiler use ADRESS of the named function to execute the function
  // ControlColor::Peterriver: explains ITSELF
  // "I'm button 1 click me" text shown on the button ITSELF
  Serial.println("Setup-Start");
  ESPUI.setVerbosity(Verbosity::VerboseJSON);
  PrintFileNameDateTime();
  connectToWiFi();
  defineGUI();
  //.begin("Title-String"); loads and serves all files from PROGMEM directly.
  ESPUI.begin("I am the website created by the ESPUI-Demo");
  BlinkHeartBeatLED(OnBoard_LED, 500);
  dnsServer.processNextRequest();
