Hi everyone.
Thanks so much to all those who have helped me here this week, and sorry to be posting so much but you've allowed me to create something so awesome! Thank you so much!
I just need one final thing that I can't seem to work out.
I think I need to use some sort of switch case? I want the last section of the code to be in a loop started by StartButton, and the top half to be what runs when the arduino starts up.
This is the section I need to start AND LOOP FOREVER when StartButton = HIGH
//KEEP THIS AT BOTTOM - EASY DRIVER CONTROL SET UP//
if(StartButton == HIGH) {
int i;
digitalWrite(dirpin, LOW); // Set the direction. LOW = to motor, HIGH = away
for (i = 0; i<Distance; i++) // DISTANCE PER LOOP 22500 is the length of the track
digitalWrite(steppin, LOW); //
digitalWrite(steppin, HIGH); //
delayMicroseconds(800); //Speed - max of 800
delay(1000)
digitalWrite(TimerPin, HIGH)
delay(1000)
digitalWrite(TimerPin, LOW)
delay(1000)
StepCounter++;
else (StartButton == LOW); {
Distance = 0;
Here is the whole sketch, I think I need a switch case somewhere in here, but im not sure what to do or how to do it, could someone please help me know how and where to put it? OR if I'm wrong and there is an easier way to do this, please let me know!
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
int Distance = 0;
int StepCounter = 0;
// this constant won't change:
const int SpeedControlButton = 50;
const int DistanceControlButton = 48;
const int ExposureControlButton = 46;
const int DirectionControlButton = 44;
const int ShutterControlButton = 42;
const int dirpin = 52;
const int steppin = 53;
const int TimerPin = 40;
const int StartButton = 7;
// Variables will change:
int SpeedControlCounter = 0; // Counter for the Speed Button
int DistanceControlCounter = 0; // Counter for the Distance Button
int ExposureControlCounter = 0; // Counter for the Exposure Button
int DirectionControlCounter = 0; // Counter for the Direction Button
int ShutterControlCounter = 0;
int StepSpeed = 0;
int SpeedButtonState = 0; // current state of the button
int DistanceButtonState = 0;
int lastSpeedButtonState = 0; // previous state of the button
int lastDistanceButtonState = 0;
pinMode(SpeedControlButton, INPUT);
pinMode(DistanceControlButton, INPUT);
pinMode(ExposureControlButton, INPUT);
pinMode(DirectionControlButton, INPUT);
pinMode(ShutterControlButton, INPUT);
pinMode(dirpin, OUTPUT);
pinMode(steppin, OUTPUT);
pinMode(TimerPin, OUTPUT);
pinMode(StartButton, OUTPUT);
lcd.begin(16, 2);
// SPEED CONTROL BUTTON READING//
// read the pushbutton input pin:
SpeedButtonState = digitalRead(SpeedControlButton);
// compare the buttonState to its previous state
if (SpeedButtonState != lastSpeedButtonState) {
// if the state has changed, increment the counter
if (SpeedButtonState == HIGH) {
// if the current state is HIGH then the button
// wend from off to on:
SpeedControlCounter++;
Serial.println("Speed, Up");
Serial.print("number of button pushes: ");
Serial.println(SpeedControlCounter);
lcd.clear();
lcd.println("Speed Up");
lcd.println(SpeedControlCounter);
if(SpeedControlCounter == 5) SpeedControlCounter =0;
// if the current state is LOW then the button went from on to off:
Serial.println("off");
// Delay a little bit to avoid bouncing
delay(50);
// save the current state as the last state,
//for next time through the loop
lastSpeedButtonState = SpeedButtonState;
///DISTANCE CONTROL BUTTON READING
DistanceButtonState = digitalRead(DistanceControlButton);
if (DistanceButtonState != lastDistanceButtonState) {
if (DistanceButtonState == HIGH) {
DistanceControlCounter++;
Serial.println("Distance, Up");
Serial.println(DistanceControlCounter);
lcd.clear();
lcd.println("Distance, Up");
lcd.println(DistanceControlCounter);
if(DistanceControlCounter == 5) DistanceControlCounter =0;
delay(50);
lastDistanceButtonState = DistanceButtonState;
//Control Section//
//SPEED CONTROL//
if (SpeedControlCounter == 1) StepSpeed = 800;
if (SpeedControlCounter == 2) StepSpeed = 2000;
if (SpeedControlCounter == 3) StepSpeed = 4000;
if (SpeedControlCounter == 4) StepSpeed = 10000;
if (SpeedControlCounter == 5) StepSpeed = 100000;
//DISTANCE CONTROL//
if (DistanceControlCounter == 1) Distance = 10;
if (DistanceControlCounter == 2) Distance = 25;
if (DistanceControlCounter == 3) Distance = 45;
if (DistanceControlCounter == 4) Distance = 100;
if (DistanceControlCounter == 5) Distance = 22500;
int i;
delay(1000)
delay(1000)
delay(1000)
StepCounter++;
Distance = 0;
THANK YOU SO MUCH!
