Need help with frequency code
I am trying to create a drum tuner with arduino. For this small project i am using a arduino mkrzero and a microphone: MAX9814. I am still fairly new to coding and would like some help. I would like this code to be able to detect and display the peak frequency when i hit the drum.
I tried using the library AudioFrequencyMeter and it does display the frequency but it displaying a bunch of different ones. After the drum is hit, i want it to be able to display the peak frequency.
link for library: https://www.arduino.cc/en/Reference/AudioFrequencyMeter
Hi rob..
Would mind sharing the code you are using. I could take a look. If you prefer pm..
mugambi:
Hi rob…
Would mind sharing the code you are using. I could take a look. If you prefer pm…
Here’s the code.
#include <AudioFrequencyMeter.h>
AudioFrequencyMeter meter;
Serial.println(“started”);
meter.setBandwidth(70.00, 250); // Ignore frequency out of this range
meter.begin(A0, 45000); // Intialize A0 at sample rate of 45kHz
float frequency = meter.getFrequency();
if (frequency > 0)
Serial.print(frequency);
Serial.println(" Hz");
Something like this should work.
float currentFreq = 0.0;
float freq = 0.0;
float lastFreq = 0.0;
  Serial.println("started");
  float freq = meter.getFrequency();
  if (freq > 0)
    if(currentFreq>lastFreq)
      lastFreq = currentFreq; //store current maximum freq
      currentFreq=freq;
    if(currentFreq>freq) //maximum has been reached on decline
      lastFreq=currentFreq=0;
Corrected code
float freq = 0.0;
  if (freq > 0)
if(currentFreq<freq)
currentFreq=freq;
      currentFreq=freq;
      Serial.print(lastFreq);
I tried the updated code, it didnt seem to work. In the serial monitor it is only displaying 0 hz and it value doesnt change. i generated a sound of 160hz and it did not detect it, it was still showing as 0 hz.
You'd probably be better off looking for a FFT library for the mkrzero.
arduarn: You'd probably be better off looking for a FFT library for the mkrzero.
Do you have a link for the library?
robbarriga: Do you have a link for the library?
'fraid not.
mugambi:
Corrected code
float freq = 0.0;
if (freq > 0)
currentFreq=freq;
      currentFreq=freq;
Let me know how this code performs. I had missed something pretty obvious…updating current freq
mugambi:
It is working now, thanks for the update.
You are welcome.
