Need Help with GSM SIM900a, it will not work with power dc only usb power
Please help here, i'm working on a small project with Network Shield, Arduino Uno and GSM SIM900a modules.
My goal is very simple, I have an address parameter sent with phone number and type message. Once received, it filters the parameter and send sms.
The code is working IF ONLY CONNECTED via USB, if I want to connect with DC (5v 2A) it wont work and doesn't send any message (sms). I already tried connecting the power directly to the GSM not from Arduino but still the same.
Any help really appreciated. Thanks.
#include <SoftwareSerial.h>
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xED};
const char mobileno[13] = "";
const char txtmessage[30] = "";
EthernetServer server(80);
SoftwareSerial SIM900A(7,8);
String readString = String(30);
char phone[13] = "";
char txt[30] = "";
String mobile_ = "";
String msg_ = "";
String mobile_msg;
String data;
int start;
int ind1; // - locations
int ind2;
String currentLine = "";
String tweet = "";
String current_tweet = "";
boolean readingTweet = false;
  // GSM
  SIM900A.begin(9600);
  delay(100);
  //SIM900A.begin(38400);
  Serial.println ("SIM900A Ready");
  delay(100);
  Serial.println ("Type s to send message or r to receive message");
  // ETHERNET
  Ethernet.begin(mac);
  server.begin();
  Serial.println("Server is at");
  Serial.println(Ethernet.localIP());
  if (Serial.available()>0){
    switch(Serial.read())
      case 's':
        SendMessage("09277324510", "Message here...");
      case 'r':
        RecieveMessage();
  if (SIM900A.available()>0){
    Serial.write(SIM900A.read());
  // Create a client connection
  if (client) {
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        //read char by char HTTP request
        if (readString.length() < 100) {
          //store characters to string
          readString += c;
          //Serial.print(c);
        //if HTTP request has ended
        if (c == '\n') {
          Serial.println(readString); //print to serial monitor for debuging
          //now output HTML data header
             if(readString.indexOf('?') >=0) { //don't send new page
               client.println("HTTP/1.1 204 Zoomkat");
               client.println();
               client.println();
             else {
          client.println("HTTP/1.1 200 OK"); //send new page
          client.println("Content-Type: text/html");
          client.println();
          client.println("<HTML>");
          client.println("<HEAD>");
          client.println("<TITLE>HOVER - GSM Server</TITLE>");
          client.println("</HEAD>");
          client.println("<BODY>");
          client.println("<H1>GSM</H1>");
          client.println("</BODY>");
          client.println("</HTML>");
          delay(1);
          //stopping client
          client.stop();
          ///////////////////// control arduino pin
          Serial.println("client disconnected.");
          Serial.println("Data from server captured in readString:");
          Serial.print(readString); //prints readString to serial monitor
          //parse readString for data
          start = readString.indexOf("?phone");  //finds a unique start location
          ind1 = readString.indexOf('=', start+2);  //finds location of first -
          ind2 = readString.indexOf("&d", ind1+1 );   //finds location of second -
          data = readString.substring(ind1+1, ind2);   //captures data String
          Serial.print("my data is: ");
          Serial.println(data);
          mobile_msg = data;
          int n = data.toInt();  //convert data into a number
          Serial.print("my number is: ");
          Serial.println(n);
          Serial.println("End of readString");
          Serial.println("==================");
          readString=""; //clear readString variable
          data=""; //clear data variable
          readString="";
          // SENDING SMS
          mobile_ = mobile_msg.substring(0,11);
          mobile_.toCharArray(phone,13);
          msg_ = mobile_msg.substring(16,18);
          msg_.toCharArray(txt,30);
          Serial.println( "------------------" );
          Serial.println( "READING TXT: " );
          Serial.println( txt );
          //if(txt == "01"){
             // SendMessage( phone , "You have a Visitor!" );
            //}else{
                SendMessage( phone , "Message here..." );
 void SendMessage(char mobile_number[13], char txt_message[100])
    Serial.println ("Sending Message...");
    SIM900A.println("AT+CMGF=1");    //Sets the GSM Module in Text Mode
    delay(2000);
    Serial.println ("Set SMS Number");
    SIM900A.println(String("AT+CMGS=\"") + mobile_number + String("\"\r"));
    delay(2000);
    Serial.println ("Set SMS Content");
    SIM900A.println( txt_message );// Messsage content
    delay(2000);
    Serial.println ("Finish");
    SIM900A.println((char)26);// ASCII code of CTRL+Z
    Serial.println ("Message has been sent!");
 void RecieveMessage()
  Serial.println ("SIM900A Membaca SMS");
  //delay (2000);
  SIM900A.println("AT+CNMI=2,2,0,0,0"); // AT Command to receive a live SMS
  Serial.write ("Unread Message done!");
Please post photos of you boards and connections.
Sorry for the late reply. I don't know if I'm attaching the right photo. It's an actual pic with what I'm working now.
I also tried putting them separate power source both Arduino Uno and SIM900a but still the same. I didn't work perfectly unlike Arduino Uno powered via usb and the SIM900a gets from pins 5v and GND.
