Hello,
I'm in need of some help with current draw for my electrical components on my robot.
First, see if I can do a quick rundown of my setup:
I have the 2 main lead-acid 12V (motorcycle size) batteries in series to provide power to the Sabertooth 2X25 motor driver that drives the main wheelchair DC motors (nothing else).
I have a seperate 12V 7Ah lead-acid battery dedicated to powering all my electronics.
The multimeter I'm using is an older Fluke 27 (still a great DMM). I don't believe it has rms or gives readings in rms. Does this mean I'm getting an average Amp reading?
When I first hook up the meter to read Amps DC to my dedicated electronics battery, I get a reading of 2.70A. After 5 minutes it goes down to 2.57A and after 10 minutes it reads 2.53A.
It seems to settle out or level of at 2.48A (after 30 minutes). Btw, why do the Amps drop down after some time?
I thought I would list the components that I had hooked up with their rated current draw, but when I was disconnecting one component at a time I noticed something that didn't seem right.
When I got to my Arduino Mega 2560 and disconnected the power from it (powering it through the barrel socket w/ 9VDC), the Amp consumption read 0.28A!?
This is a 2.2A draw from the Arduino Mega 2560. Interesting enough, I'm using a dedicated 9V voltage regulator rated at 2.2A...
Another interesting thing is when the reading leveled out at 2.48A and I turned my Stepper motor left & right the amps draw actually went down to about 2.11A (when in motion, then goes back to 2.48A when stopped)
Here is just a quick rundown of the components I have installed at the time of testing:
-Arduino Mega 2560
-Arduino motor shield R3 (to drive stepper), also disconnected this but didn't make a big difference. I did add a small heatsink on the motor shield IC a while back and noticed the heatsink was a bit hot..
-RC receiver Spektrum AR600
-Servo for the head tilt up and down. Getting a bit of servo buzz, which I'm working to resolve. The reading of 2.48A was without the buzz.
-(x4) Parallax PING sensors
-(x2) Parallax PIR Motion sensors
-Rear 80mm exhaust fan
-Also have 6 voltage regulators getting different volts from the 12V battery:
-(x3) 5V, 3A regulators (1 is dedicated to the RC receiver, 1 is not connected & other goes to the 5V terminal screw block)
-(x1) 6V, 1.5A regulator dedicated to powering my stepper motor.
-(x2) 9V, 2.2A regulators (1 is dedicated to the Arduino Mega 2560, and other goes to the 9V terminal screw block)
Any help, suggestions would greatly be appreciated, especially on the 2.2A draw from the Arduino Mega 2560
Thomas
