Hey guys so I am in the process of learning how to drive an 8x8 common anode matrix with 2xTLC5940 chip
Using a multiplexer (CD4051BE) to switch through rows and the super source driver (M54564P) to connect to the anodes
My idea is to use the atmega 328P chip to program but I am not so sure about where each pin of the TLC 5940 goes to what spot on the ATMEGA 328 chip and also where do I connect the A,B,C pins of the multiplexer to the ATMEGA chip.
I would appreciate the help, i am very new to electronics.
Here's a picture of what I am planning to do and the wiring I have done so far.
The CD4051 multiplexer is useless for that application. You need a demultiplexer instead, such as the 74HC238.
Be sure to take into account the voltage drop in the M54564P when you calculate the LED power supply voltage to use. Then calculate the power dissipation in the M54564P and in each TLC5940 to make sure they will not overheat.
