Need help with INA and MOSFFET circuit
I'm working on a project, which is based on custom built board designed around Atmega2560.
I did not designed the schematics or the PCB some other guy did it and I'm asked to program it.
When the PCB arrived at my end it was all assembled except for the current sensor part. I then soldered current sense resistors and found out that whenever I power up the board it shows a short circuit condition.
The MOSFET used are dual N channel MOSFET FDS6990A those are driven by MOSFET driver TC4468
Here's a zoomed in connection for one channel of it, there are 16 different channels like this
How do you mean "shows a short circuit condition"?
Is this what the power supply indicates?
What are you using as the power supply?
Can you please post a SCHEMATIC, if a PCB has been designed and made, then there must be a properly drawn schematic.
You circuit does not show gnd or power supplies or other needed components.
Did you have a part in designing the PCB?
Usually you get a prototype made and running before going to PCB.
Can you please post an image of your PCB, it needs to be an EXPORTED jpg from what ever CAD was used to design the pattern.
Can you please tell us your electronics, programming, arduino, hardware experience?
Do you have a DMM?
Thanks.. Tom.. :grinning: :+1: :coffee: :australia:
PS. Sorry for all the questions, but you have the project in front of you we don't.
Which INA?
Hello @TomGeorge glad to have your reply. It's the third or fourth post in which I have got your reply. It's always been helpful to have your valuable inputs!
  1. I have a test bench power supply. "Shows short circuit condition" - meaning, the voltage on test bench power supply is set to 24V DC it drops to 7V DC and the LED labelled as 'CC' glows up. The PCB has pilot indication for all the three power outputs namely 12V, 5V and 3V of these only 12V is on when powered up rest of two goes OFF
  2. I have a dual channel test bench regulated power supply the one with seven segment display with adjustable output voltage. For this only single channel is in use (It can be configured as dual channel or independent)
  3. Unfortunately, they sent me the Altium files and I'm not able to open it myself as I do not have Altium but I viewed it on online viewer. I have asked them to send me the PDF for both the schematics and PCB and it should be here by today late evening
  4. I had lil part in designing the PCB, but the INA current sensor part is not designed by me at all. And by part means I only inspected the designing process over zoom call
  5. I had told them about the prototype which we even made but that time the design was using ACS712, but it didn't give the desired output and so the designed was switched from ACS712 to INA226 (INA226 have an acute shortage going on rn)
  6. Give me lil time till I get those PDFs and I'll be uploading schematics as well as the PCB PDF file here
  7. Speaking about my experience in electronics, I won't say I'm an expert but I'm good enough experienced to understand whatever you will be suggesting me in next replies.
  8. Have 3 DMM, actually 2 DMM and 1 AMM. 1 of the DMM I just bought yesterday! :smiley:
Sorry, INA226 that's the one
Fine mate , will wait to see what you get.
The pinout of the 226 and 217 are different, I hope they changed the footprint on the PCB when they change it.
A schematic of how they put the inboard regulators would be good when you get the info.
What was the current limit set to on the powersupply?
Can the online viewer export the pattern and schematic as jpg, probably not.
Have you got a copy of the prototype circuit?
Thanks for the great info.. Tom.. :grinning: :+1: :coffee: :australia:
Are you connecting 24V to the INA226 V+in terminal? If so there is only the 0.1Ω shunt resistor between 24V and ground. At 24V that would be 240 Amps.
They have changed the footprints for sure. I haven't soldered the INA ICs yet just the resistors and today I removed it back again to check. without those resistors everything works fine I manually tried shorting the resistor pads (it is possible bcoz the pads are big enough) but it doesn't show the short circuit now. My guess, it might happen only if all of the resistors are in place. Now, I'm putting back each resistor one by one and check the PCB each time to isolate the location (bcoz that's the only way I can think of right now :grimacing:)
Speaking about the regulators the board uses LM2596-12 for 12V and LM2596-5 for 5V and AMS1117-3.3 for 3.3V volts.
I didn't set any current on the Power supply. But when I turn it on it shows me 0.03-0.04 Amps on the current display. I was too scared to increase it (the current knob is at 11 o'clk)
I haven't got the schematics yet :frowning:
No...No....No.....
12V the Pumps are powered by 12V. Look in the image I have shared
On your schematic, where was your PS connected when you had the short circuit?
if you mean pumps by PS those are attachable and removable with FRC cable connector
Power supply, where was the +V and the -V connected when you had the short?
on the power input of the PCB
I got the schematics but some how the uploading never goes beyond 0%
:frowning: :frowning:
I see no free-wheel diodes across the inductive load(s), I'd expect that for any motor or motor-containing device like a pump.
Can you link to datasheets for the actual hardware (like PSU, pump, etc)? We only know anything about the hardware you have if you tell us, and "pump" isn't much information.
What format are they and how big are they?
Tom... :grinning: :+1: :coffee: :australia:
they are in pdf format. 132KB :frowning:
That should be okay if you drag and drop into the text box.
Still same issue :frowning:
But I solved the problem. Apparently there was a track passing below one of the resistor which had a worn out masking and it shorted with the Resistor body somehow. I covered it with insulation tape and put back the resistor and its working fine now.
I would still like to have your opinion on the schematics as soon as I'm able to upload them. Right now, Idk why but the uploading process doesn't progress beyond 0% :frowning:
Good to hear.
How are you uploading?
