Need help with INT output to LCD
I am using OneWire to get temp input and trying to output the value on the LCD screen. So when I output the value using Serial.print(val) it is correct but if I use lcd.print(val) it comes up as a CHAR.
for example:
int val = 70;
Serial.print(val); // outputs 70 to the console
lcd.print(val); // outputs F to the LCD.
I am very new to this and the code i have is all basically found in forums and examples.
here is the loop function I have so far.
Any help is greatly appreciated!!
  int HighByte, LowByte, TReading, SignBit, Tc_100, Tf_100, Fract;
  float Whole;
  digitalWrite(13, HIGH);  //light the debug LED
  OneWireReset(TEMP_PIN);       // reset
  OneWireOutByte(TEMP_PIN, 0xcc); // skip ROM code
  OneWireOutByte(TEMP_PIN, 0x44); // perform temperature conversion, strong pullup for one sec
  OneWireOutByte(TEMP_PIN, 0xbe); // Read scratchpad code (temperature in this case)
  LowByte = OneWireInByte(TEMP_PIN);
  HighByte = OneWireInByte(TEMP_PIN);
  TReading = (HighByte << 8) + LowByte;
  SignBit = TReading & 0x8000;  // test most sig bit
  if (SignBit) // negative
    TReading = (TReading ^ 0xffff) + 1; // 2's complement the answer
  Tc_100 = (6 * TReading) + TReading / 4;    // multiply by (100 * 0.0625) or 6.25
  Whole = Tc_100 / 100;  // separate off the whole and fractional portions
  Fract = Tc_100 % 100;
  if (SignBit) // If its negative
     lcd.printIn("-");
  if (Fract < 10)
     //lcd.printIn("0");
  //lcd.print("C\n");
  Tf_100 = ((Tc_100 * 9) / 5) + 3200;
  Whole = Tf_100 / 100;  // separate off the whole and fractional portions
  Fract = Tf_100 % 100;
     lcd.printIn("-");
  lcd.clear();
  lcd.print(Whole);
  Serial.print(Whole);
  if (Fract < 10)
     //lcd.printIn("0");
  //lcd.print(Fract);
  //scroll entire display 20 chars to left, delaying 50ms each inc
  //lcd.leftScroll(20, 50);
  delay(2000);      // 2 second delay.  Adjust as necessary
  //lcd.clear();
The library you are using does not print numbers, but you can do this:
char buf[6]; // int has up to 5 digits plus terminating 0
int val;
// code here sets val
lcd.printIn(itoa(val, buf, 10));
Also, there is code in this thread that prints floating point values that works with the library you are using: http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1207226548
or you can use the LiuquidCrystal library that has the same print capability as Serial.
yeah that bit of code did just the trick! thanks for all the other information too!
