Hello!
I assembled the backlight of the PC case on six Arduino NANO controllers using WS2812B tapes. In order for the case backlight to be synchronized with the Razer and Logitech peripherals, I used the KeyboardVisualizer program and firmware for WS2812B_LEDStrip_Arduino.ino controllers
Everything works perfectly. But when i`m turn on the computer, until Windows and KeyboardVisualizer program starts up, the backlight does not light up. The controllers do not turn on the diodes until they receive a signal on the COM port.
Please help me add a code so that when power is applied to the controllers, they power on diodes with a smooth cyclic color change when there is no signal at the COM port.
Link to the project KeyboardVisualizer
WS2812B_LEDStrip_Arduino.ino code:
| WS2812B (NeoPixel) Serial Controlled LED Strip Driver |
| for use with Keyboard Visualizer VCUI |
| Adam Honse (calcprogrammer1) 12/9/2016 |
#ifdef __AVR__
#include <avr/power.h>
#endif
#define PIN 6
#define LEDS 30
#define PACKET_SZ ( (LEDS * 3) + 3 )
// Parameter 1 = number of pixels in strip
// Parameter 2 = Arduino pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
// NEO_KHZ800 800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
// NEO_KHZ400 400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
// NEO_GRB Pixels are wired for GRB bitstream (most NeoPixel products)
// NEO_RGB Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(LEDS, PIN, NEO_GRB + NEO_KHZ800);
// IMPORTANT: To reduce NeoPixel burnout risk, add 1000 uF capacitor across
// pixel power leads, add 300 - 500 Ohm resistor on first pixel's data input
// and minimize distance between Arduino and first pixel. Avoid connecting
// on a live circuit...if you must, connect GND first.
unsigned char serial_buffer[PACKET_SZ];
unsigned int head = 0;
unsigned int start;
unsigned int checksum_1;
unsigned int checksum_0;
strip.begin();
strip.show();
if( Serial.available() )
serial_buffer[head] = Serial.read();
if( head >= (PACKET_SZ - 1) )
start = 0;
checksum_1 = head;
checksum_0 = head - 1;
head = 0;
start = head + 1;
checksum_1 = head;
if( head == 0 )
checksum_0 = PACKET_SZ - 1;
head++;
if( serial_buffer[start] == 0xAA )
unsigned short sum = 0;
for( int i = 0; i < checksum_0; i++ )
sum += serial_buffer[i];
if( start > 0 )
for( int i = start; i < PACKET_SZ; i++ )
//Test if valid write packet
if( ( ( (unsigned short)serial_buffer[checksum_0] << 8 ) | serial_buffer[checksum_1] ) == sum )
noInterrupts();
for( int i = 0; i < LEDS; i++ )
int idx = start + 1 + ( 3 * i );
if( idx >= (PACKET_SZ - 1) )
idx = idx - PACKET_SZ;
strip.setPixelColor(i, strip.Color(serial_buffer[idx], serial_buffer[idx+1], serial_buffer[idx+2]));
strip.show();
interrupts();
Thank You!
