Need help with lcd game pls help.
Hi.I found a code for a lcd game on the internet.There is a man running and blocks moving towards him and you have to jump over them.I tried to make the game more interesting by adding a power up
that will make the game slow down when the man touches it but i couldn’t.Can somebody please help me? you see that delay(50) line at the end of the code?i want the game to behave like it does when you replace this line with delay(500).this effect must last for 1 min.thanks.
this is the code:
#include <LiquidCrystal.h>
#define PIN_BUTTON 2
#define PIN_AUTOPLAY 1
#define PIN_READWRITE 10
#define PIN_CONTRAST 12
#define SPRITE_RUN1 1
#define SPRITE_RUN2 2
#define SPRITE_JUMP 3
#define SPRITE_JUMP_UPPER '.'
#define SPRITE_JUMP_LOWER 4
#define SPRITE_TERRAIN_EMPTY ' '
#define SPRITE_TERRAIN_SOLID 5
#define SPRITE_TERRAIN_SOLID_RIGHT 6
#define SPRITE_TERRAIN_SOLID_LEFT 7
#define HERO_HORIZONTAL_POSITION 1
#define TERRAIN_WIDTH 16
#define TERRAIN_EMPTY 0
#define TERRAIN_LOWER_BLOCK 1
#define TERRAIN_UPPER_BLOCK 2
#define HERO_POSITION_OFF 0
#define HERO_POSITION_RUN_LOWER_1 1
#define HERO_POSITION_RUN_LOWER_2 2
#define HERO_POSITION_JUMP_1 3
#define HERO_POSITION_JUMP_2 4
#define HERO_POSITION_JUMP_3 5
#define HERO_POSITION_JUMP_4 6
#define HERO_POSITION_JUMP_5 7
#define HERO_POSITION_JUMP_6 8
#define HERO_POSITION_JUMP_7 9
#define HERO_POSITION_JUMP_8 10
#define HERO_POSITION_RUN_UPPER_1 11
#define HERO_POSITION_RUN_UPPER_2 12
LiquidCrystal lcd(8,9,4,5,6,7);
static char terrainUpper[TERRAIN_WIDTH + 1];
static char terrainLower[TERRAIN_WIDTH + 1];
static bool buttonPushed = false;
void initializeGraphics(){
  static byte graphics[] = {
    // Run position 1
    B01100,
    B01100,
    B00000,
    B01110,
    B11100,
    B01100,
    B11010,
    B10011,
    // Run position 2
    B01100,
    B01100,
    B00000,
    B01100,
    B01100,
    B01100,
    B01100,
    B01110,
    // Jump
    B01100,
    B01100,
    B00000,
    B11110,
    B01101,
    B11111,
    B10000,
    B00000,
    // Jump lower
    B11110,
    B01101,
    B11111,
    B10000,
    B00000,
    B00000,
    B00000,
    B00000,
    // Ground
    B11111,
    B11111,
    B11111,
    B11111,
    B11111,
    B11111,
    B11111,
    B11111,
    // Ground right
    B00011,
    B00011,
    B00011,
    B00011,
    B00011,
    B00011,
    B00011,
    B00011,
    // Ground left
    B11000,
    B11000,
    B11000,
    B11000,
    B11000,
    B11000,
    B11000,
    B11000,
  int i;
  for (i = 0; i < 7; ++i) {
	  lcd.createChar(i + 1, &graphics[i * 8]);
  for (i = 0; i < TERRAIN_WIDTH; ++i) {
    terrainUpper[i] = SPRITE_TERRAIN_EMPTY;
    terrainLower[i] = SPRITE_TERRAIN_EMPTY;
void advanceTerrain(char* terrain, byte newTerrain){
  for (int i = 0; i < TERRAIN_WIDTH; ++i) {
    char current = terrain[i];
    char next = (i == TERRAIN_WIDTH-1) ? newTerrain : terrain[i+1];
    switch (current){
      case SPRITE_TERRAIN_EMPTY:
        terrain[i] = (next == SPRITE_TERRAIN_SOLID) ? SPRITE_TERRAIN_SOLID_RIGHT : SPRITE_TERRAIN_EMPTY;
      case SPRITE_TERRAIN_SOLID:
        terrain[i] = (next == SPRITE_TERRAIN_EMPTY) ? SPRITE_TERRAIN_SOLID_LEFT : SPRITE_TERRAIN_SOLID;
      case SPRITE_TERRAIN_SOLID_RIGHT:
        terrain[i] = SPRITE_TERRAIN_SOLID;
      case SPRITE_TERRAIN_SOLID_LEFT:
        terrain[i] = SPRITE_TERRAIN_EMPTY;
bool drawHero(byte position, char* terrainUpper, char* terrainLower, unsigned int score) {
  bool collide = false;
  char upperSave = terrainUpper[HERO_HORIZONTAL_POSITION];
  char lowerSave = terrainLower[HERO_HORIZONTAL_POSITION];
  byte upper, lower;
  switch (position) {
    case HERO_POSITION_OFF:
      upper = lower = SPRITE_TERRAIN_EMPTY;
    case HERO_POSITION_RUN_LOWER_1:
      upper = SPRITE_TERRAIN_EMPTY;
      lower = SPRITE_RUN1;
    case HERO_POSITION_RUN_LOWER_2:
      lower = SPRITE_RUN2;
    case HERO_POSITION_JUMP_1:
    case HERO_POSITION_JUMP_8:
      lower = SPRITE_JUMP;
    case HERO_POSITION_JUMP_2:
    case HERO_POSITION_JUMP_7:
      upper = SPRITE_JUMP_UPPER;
      lower = SPRITE_JUMP_LOWER;
    case HERO_POSITION_JUMP_3:
    case HERO_POSITION_JUMP_4:
    case HERO_POSITION_JUMP_5:
    case HERO_POSITION_JUMP_6:
      upper = SPRITE_JUMP;
    case HERO_POSITION_RUN_UPPER_1:
      upper = SPRITE_RUN1;
    case HERO_POSITION_RUN_UPPER_2:
      upper = SPRITE_RUN2;
  if (upper != ' ') {
    terrainUpper[HERO_HORIZONTAL_POSITION] = upper;
    collide = (upperSave == SPRITE_TERRAIN_EMPTY) ? false : true;
  if (lower != ' ') {
    terrainLower[HERO_HORIZONTAL_POSITION] = lower;
    collide |= (lowerSave == SPRITE_TERRAIN_EMPTY) ? false : true;
  byte digits = (score > 9999) ? 5 : (score > 999) ? 4 : (score > 99) ? 3 : (score > 9) ? 2 : 1;
  terrainUpper[TERRAIN_WIDTH] = '\0';
  terrainLower[TERRAIN_WIDTH] = '\0';
  char temp = terrainUpper[16-digits];
  terrainUpper[16-digits] = '\0';
  lcd.setCursor(0,0);
  lcd.print(terrainUpper);
  terrainUpper[16-digits] = temp;
  lcd.setCursor(0,1);
  lcd.print(terrainLower);
  lcd.setCursor(16 - digits,0);
  lcd.print(score);
  terrainUpper[HERO_HORIZONTAL_POSITION] = upperSave;
  terrainLower[HERO_HORIZONTAL_POSITION] = lowerSave;
  return collide;
void buttonPush() {
  buttonPushed = true;
void setup(){
  pinMode(PIN_READWRITE, OUTPUT);
  digitalWrite(PIN_READWRITE, LOW);
  pinMode(PIN_CONTRAST, OUTPUT);
  digitalWrite(PIN_CONTRAST, LOW);
  pinMode(PIN_BUTTON, INPUT);
  digitalWrite(PIN_BUTTON, HIGH);
  pinMode(PIN_AUTOPLAY, OUTPUT);
  digitalWrite(PIN_AUTOPLAY, HIGH);
  attachInterrupt(0/*PIN_BUTTON*/, buttonPush, FALLING);
  initializeGraphics();
  lcd.begin(16, 2);
void loop(){
  static byte heroPos = HERO_POSITION_RUN_LOWER_1;
  static byte newTerrainType = TERRAIN_EMPTY;
  static byte newTerrainDuration = 1;
  static bool playing = false;
  static bool blink = false;
  static unsigned int distance = 0;
  if (!playing) {
    drawHero((blink) ? HERO_POSITION_OFF : heroPos, terrainUpper, terrainLower, distance >> 3);
    if (blink) {
      lcd.setCursor(0,0);
      lcd.print("Press Start");
    delay(250);
    blink = !blink;
    if (buttonPushed) {
      playing = true;
      distance = 0;
    return;
  advanceTerrain(terrainLower, newTerrainType == TERRAIN_LOWER_BLOCK ? SPRITE_TERRAIN_SOLID : SPRITE_TERRAIN_EMPTY);
  advanceTerrain(terrainUpper, newTerrainType == TERRAIN_UPPER_BLOCK ? SPRITE_TERRAIN_SOLID : SPRITE_TERRAIN_EMPTY);
  if (--newTerrainDuration == 0) {
    if (newTerrainType == TERRAIN_EMPTY) {
      newTerrainType = (random(3) == 0) ? TERRAIN_UPPER_BLOCK : TERRAIN_LOWER_BLOCK;
      newTerrainDuration = 2 + random(10);
      newTerrainDuration = 10 + random(10);
  if (buttonPushed) {
    if (heroPos <= HERO_POSITION_RUN_LOWER_2) heroPos = HERO_POSITION_JUMP_1;
  if (drawHero(heroPos, terrainUpper, terrainLower, distance >> 3)) {
    playing = false;
    lcd.setCursor(0,1);
    lcd.print("#yolo");
    if (heroPos == HERO_POSITION_RUN_LOWER_2 || heroPos == HERO_POSITION_JUMP_8) {
    } else if ((heroPos >= HERO_POSITION_JUMP_3 && heroPos <= HERO_POSITION_JUMP_5) && terrainLower[HERO_HORIZONTAL_POSITION] != SPRITE_TERRAIN_EMPTY) {
      heroPos = HERO_POSITION_RUN_UPPER_1;
    } else if (heroPos >= HERO_POSITION_RUN_UPPER_1 && terrainLower[HERO_HORIZONTAL_POSITION] == SPRITE_TERRAIN_EMPTY) {
      heroPos = HERO_POSITION_JUMP_5;
    } else if (heroPos == HERO_POSITION_RUN_UPPER_2) {
      ++heroPos;
    ++distance;
    digitalWrite(PIN_AUTOPLAY, terrainLower[HERO_HORIZONTAL_POSITION + 2] == SPRITE_TERRAIN_EMPTY ? HIGH : LOW);
  delay(50);
I would have thought that the last thing you want to use in an interactive game is the delay() command because it stops anything happening until the delay() is complete. Is that what you want ?
If you need the game to remain fluid, just slower, then you need to consider using millis() for timing as in
Several things at the same time
where do you put the command then?
rohitpolisetti1:
There is not a single command that you use instead of delay(), rather you save the millis() value at the time that the start action happens, such as the game running slower. Then, each time through loop(), check whether the required wait period has elapsed by subtracting the start time from the millis() value now.
If the period has elapsed then act accordingly and maybe save the start time for the next activity. If not, then go round loop() again, perhaps taking other actions and/or reading inputs, but don't block the free running of loop().
The "Several things at the same time" thread illustrates this principle well.
i tried this
if (buttonPushed) {
millis();
currentMillis= millis();
if (currentMillis)= 30000; {
its not working
its not working
No surprise there.
You need to save the time from millis() that the wait started in an unsigned long variable. Let's call it timeStarted
Each time through loop() test whether the current value of millis() minus the start time is greater than the required period
if (millis() - startTime >= requiredPeriod)
If it is then the wait period is over so do what you need. If not, then go round loop() again
DO NOT use delay() as part of this code as it makes using mills() a waste of time.
how to i make the game appear slower after it reaches the time limit?
What, exactly, needs to appear slower ?
The whole thing or only part of it ?
only the blocks moving towards the man.
not the man and the score counter.
I have not looked at the code in detail but you need to control the speed each aspect of the game using millis() then you can change the speed of any of the elements. Did you look at the "Several things at the same time" thread ?
yes,but my code was wrong
i think it is easier to just slow down the whole thing.
if you have time can you please modify my code?
i've tried but i dont know which part of the code i must delay.
I am afraid that I don't.
As an experiment try increasing the delay() at the end of the loop() function. That is NOT the proper way to do it but may give you a clue as to where to implement millis() timing using the principles outlined above
rohitpolisetti1:
To slow down the game down in some cases you could preplace
 delay(50);
With code like:
 if (CheckSomeCondition()) delay(500);
 else delay(50);
and then write an additional function named "CheckSomeCondition()" that:
  • checks for collisions
  • checks for the time since the last collision was detected
But I'm afraid, the game then becomes rather unplayable if you set a delay that lasts longer than the human reaction time.
Although pressed buttons will also be detected during delay() because the sketch is using an interrupt handler to handle button interrupts, the hero figure will not move immediately when the button is pressed, but with a half second delay then.
And if the speed of the game changes back instantly from slow running to fast after one minute without any previous warning, the hero will most likely crash into the next obstacle within the fraction of a second.
