Hi:
What I am working on is driving a 12vdc gear motor using an Arduino Uno r3 and a Arduino Motor Shield.I am new to Arduino and I am having a problem getting this to do what I want it to do.
Basicly what it needs to do is: when a start button is pressed the motor should rotate clockwise from home position (limit swith A) aprox. 180 deg. until it hits (limit switch B).Then the motor brakes and motor rotates counterclockwise until it hits (limit switch A) and then it stops motor and waits until the start button is pressed again.
The way I have the limit switches wired up is on a breadboard with a 10k resistor from the +5vdc then a leed going to the proper pin on the Arduino then a leed going to the pin on limit switch marked (com) then a leed from ground to the pin on limit switch marked (no).All on same row of breadboard.
What happens is: I press the start button and the motor starts rotating it hits (limit switch B) and motor stops like it should.But it does not reverse direction.If I release the arm on (limit switch B) then motor starts up in reverse and runs until it hits (limit switch A) and it stops like it should.Then if I press start button it starts up again with same results.
IF anyone can see whats wrong it would be greatly appreciated.
const int buttonPin = 2;
const int swPin = 4;
const int swPinb = 7;
const int motor = 12;
const int brake = 9;
pinMode(buttonPin, INPUT);
pinMode(swPin, INPUT);
pinMode(swPinb, INPUT);
pinMode(motor, OUTPUT);
pinMode(brake, OUTPUT);
int swbState = digitalRead(swPinb); // Reads state of switch B
int swState = digitalRead(swPin); // Reads state of switch A
int buttonState = digitalRead(buttonPin); // Reads state of start button
if (buttonState == 0 ) { // Reads start button if pressed then continues with sketch
digitalWrite(motor, HIGH); // Sets motor to turn clockwise
digitalWrite(brake, LOW); // Turns off motor brake
analogWrite(3, 255); // Runs motor at max rpm
if(swState == 0){// Turns motor clockwise until it hits switch A
digitalWrite(brake, HIGH); // Brakes motor
digitalWrite(motor, LOW); // Sets motor to turn counterclockwise
analogWrite(3, 123); // Runs motor at half speed
if(swbState == 0){ // Motor runs ccw until it hits switch B
digitalWrite(brake, HIGH); // Stops motor
Serial.print("BUTTON: ");
Serial.print(buttonState);
Serial.print("swPin: ");
Serial.print(swState);
Serial.print("swbpin: ");
Serial.println(swbState);
