Hi, Im trying to display temperature values from the LM335, using arduino uno and a 16x2 lcd.
the code i use for scale the values of the analog input is:
temperatura = ((5.0/1024.0)/0.01)*adctemp) -273.0;
But I got high and wrong values, also if i increase the sensor temperature with a lighter,
the number displayed on the lcd goes down, same happens if i only read the analog input of the Lm335
the value on the lcd goes down. I have read a lot of topics and examples about the connection and im sure
im using the correct configuration (center pin node to R2.2k +v and to arduino analog input, right pin GND)
Can somebody help me please?
Thank you!
