Need help with masking bits
Why isn't this masking allowed? outdata previously declared as type 'word' (16 bit, same as unsigned int)
outdata = outdata & B0000000111111100;
results in compile error: 'B0000000111111100' was not declared in this scope
yet this compiles okay outdata = outdata & 0x01FC;
Have you ever tried typing out 65536 variations of Bxxxxxx? I'm amazed they got as far as 256!
If you find "B0000000111111100" to be more understandable / legible than "0x01FC", put this in your Sketch...
define B0000000111111100 (0x01FC)
I am shifting this out into two 8 bit shift registers to control 9 LEDs turning on/off (with 7 bits for stuff yet to be defined). I plan to AND in 0s to turn them off, and OR in 1s to turn them on. They can be turned off/on independently of each other based on what is happening with other inputs, etc. Having a huge field of defines is thus not helpful. Being able to show the masking in binary makes it easier to follow as I code it. As it is, I have the binary in the code, I am now going thru commenting those out and adding the line a 2nd time as the hex equivalent.
Seems like something is lacking compiler-wise if bit manipulation can't be done both ways.
How do you think the B00000000 to B11111111 constants are defined?
Hex is easy enough to convert in your head to binary - only 16 symbols.
Long binary constants are a PITA - easy to lose where you are.
What's wrong with 0b0000000111111100 notation?
Just whining I guess. Was kinda on a roll, now having to go back & make a bunch of tweaks to fix those.
Here's another question regarding timing:
I am writing what's basically a big sequencer, driving a low level signal out and watching for it to come back on another pin for a couple of mS (need 2mS min contact time for example). I'm figuring if I do this:
  unsigned long currentMicros = micros();  // see how long its been
  if (currentMicros - previousMicros >= interval) // more than our 0.1mS interval? (100uS)
    // save the last time we okayed time updates
    previousMicros = currentMicros;
    tenth_mS_interval = tenth_ms_interval+1;
  // do stuff on 0.1mS intervals, 1mS intervals, ets.
That would allow 1600 operations between intervals, correct? 100uS/62.5nS = 1600 and I could control/time stuff with 0.1mS timing if needed?
0b0000111100001111 - that's what I was after - didn't know it was 0b at the start that I needed. Thanks. Didn't see that in the reference section.
That's a very good way to code an interval timer.
