I have a project where i have a arduino and a rotary encoder with a button and i'm coding a menu system. I have the 2 of the three menus, i cant get the code to go to the 3 menu.
the flow of my program is kind of 2D array where certain spots at the end of the row navigate up and down to other rows.
main loop is these functions
encoder();
that reads the dial and moves the menu across the row
menushow();
takes the dial number and displays the menu option
debounce is on a interrupt and calls menuaction()
that has a list of actions to do depending on where in the "array" you are in
the code to get to the effectmenu is here, which is the part doesnt work, yet other navigating code works
if(whichmenu == 1 && menuspot == 7 )
whichmenu=3;
how the menu array looks for reference
menu 1 (dimensions): 1, 2, 3, 4, 5, 6, 7, 8, 9
menu 2 (sounds) : 1, 2, 3, 4, 5, 6, 7, 8, 9
menu 3 (effects) : 1, 2, 3, 4, 5, 6, 7, 8, 9
where whichmenu variable is the rows
and menuspot is the columns
Here is the code, I deleted some of the functions/codes that dont have anything to do to make it easier to navigate.
#include <Encoder.h>
#define ENCODER_OPTIMIZE_INTERRUPTS
Encoder myEnc(0, 5);
long oldPosition = 0;
long newPosition = 0;
#include <Wire.h>
#include "Adafruit_LEDBackpack.h"
#include "Adafruit_GFX.h"
Adafruit_7segment myDisplay = Adafruit_7segment();
const int buttonPin = 1;
int buttonState = 0;
int ledState = HIGH;
int lastButtonState = LOW;
int menuspot=1;
int lastposition;
int whichmenu=1; //1 dimension 2 sounds 3 effects
int portalledpin=6;
// shift register stuff //do not touch
int SER_Pin = 10; //pin 14 on the 75HC595
int RCLK_Pin = 11; //pin 12 on the 75HC595
int SRCLK_Pin = 12; //pin 11 on the 75HC595
#define number_of_74hc595s 1
#define numOfRegisterPins number_of_74hc595s * 8
boolean registers[numOfRegisterPins];
myDisplay.begin(0x70);
pinMode(portalledpin, OUTPUT);
pinMode(buttonPin, INPUT_PULLUP);
pinMode(9, INPUT); // battery pin
pinMode(SER_Pin, OUTPUT);
pinMode(RCLK_Pin, OUTPUT);
pinMode(SRCLK_Pin, OUTPUT);
allregisterHIGH();
writeRegisters();
attachInterrupt(0, debounce, FALLING);
digitalWrite(6, HIGH);
encoder();
menushow();
allregisterHIGH();
writeRegisters();
void encoder()
newPosition = myEnc.read()/4;
if(newPosition>oldPosition)
menuspot++;
allregisterHIGH();
writeRegisters();
if(newPosition<oldPosition)
menuspot--;
allregisterHIGH();
writeRegisters();
if(whichmenu==1 && menuspot>7){menuspot=1;}//dimension menu
if(whichmenu==1 && menuspot<1){menuspot=7;}//dimension menu
if(whichmenu==2 && menuspot>9){menuspot=1;}//sound menu
if(whichmenu==2 && menuspot<1){menuspot=9;}//sound menu
if(whichmenu==3 && menuspot>7){menuspot=1;}//effect menu
if(whichmenu==3 && menuspot<1){menuspot=7;}//effect menu
oldPosition=newPosition;
void menushow()
switch(whichmenu)
case 1: dimensionmenu();
case 2: soundsmenu();
case 3: effectsmenu();
default:myDisplay.print(6666, DEC);
myDisplay.writeDisplay();
void menuaction()
//--------------- Dimension menu -------------------------//
if(whichmenu == 1 && (menuspot==1 || menuspot==2 || menuspot==3 || menuspot==4 || menuspot==5 ))
digitalWrite(portalledpin, HIGH);
if(whichmenu==1 && menuspot==6)
whichmenu=2;
whichmenu=3;
//-------------------- Sound Menu ----------------------------//
if(whichmenu == 2 && menuspot == 1)
//action
else if(whichmenu == 2 && menuspot == 2)
//action
else if(whichmenu == 2 && menuspot == 3)
//action
else if(whichmenu == 2 && menuspot == 4)
//action
else if(whichmenu == 2 && menuspot == 5)
//action
else if(whichmenu == 2 && menuspot == 6)
//action
else if(whichmenu == 2 && menuspot == 7)
//action
else if(whichmenu == 2 && menuspot == 8)
//action
else if(whichmenu == 2 && menuspot == 9)
whichmenu=1;
// default action
if(whichmenu==3 && menuspot==7)
whichmenu=1;
separate page for the debounce function
long lastDebounceTime = 0;
long debounceDelay = 50;
void debounce() {
int reading = digitalRead(buttonPin);
if (reading != lastButtonState) {
// reset the debouncing timer
lastDebounceTime = millis();
if ((millis() - lastDebounceTime) > debounceDelay) {
buttonState = reading;
buttonState = digitalRead(buttonPin);
if (buttonState == LOW)
menuaction();
lastButtonState = reading;
menu display codes
void dimensionmenu()
switch(menuspot)
case 1: //menu page 1
case 2: //menu page 2
case 3: //menu page 3
case 4: //menu page 4
case 5: //menu page 5
case 6: //go to sound menu
case 7: //go to effects menu
default: //default menu page
void soundsmenu()
switch(menuspot)
case 5://menu page 5
case 6: //menu page 6
case 7: //menu page 7
case 8: //menu page 8
case 9: go to back to previous menu
void effectsmenu()
switch(menuspot)
case 7: // got to previous menu
default: // default manu
Thank you in advance for anyone that can help. I apologize if i posted this in the wrong area or if i posted it in the wrong area. Feel free to ask me any questions.
PS i also included the original code no edits as attachments
debounce.ino (1.47 KB)
debug.ino (816 Bytes)
FEATHER_Teensy_Encoder_Basic_and_seven_segment_V5.ino (6.08 KB)
menus.ino (2.49 KB)
shift_out.ino (961 Bytes)
words.ino (648 Bytes)
