Thought I’d add my work here,
I have it running of Serial1, and Accessing the MEGA through Serial.
The manufacturer has a 8051 type microcontroller in from of this device which they use to control and config the RC522 using custom Command Codes, I spent ours trying to get it to work with the RC522 datasheet only to realize I must use the manufacturers ‘User Manual’
Heres some code that works:
unsigned char command, devnull;
unsigned int returnLength;
Serial.println(“Waiting for Card\n”);
Serial1.begin(9600);
Serial1.write(0x02); //Send the command to RFID, please refer to RFID manual
void loop() // run over and over
if (Serial1.available())
Serial.print("\n\rCARD SERIAL: “);
for (unsigned int i=0; i<4 ;i=i){
//Serial.print(“2”);
if (Serial1.available()) {
//Serial.print(”\n\ri is: “);Serial.print(i);Serial.print(” ");
Serial.print(Serial1.read(),HEX); //Display the Serial Number in HEX
i++;
Serial.println("\n\rRead Card Make…");
Serial1.write(0xAB);Serial1.write(0x02);Serial1.write(0x01);
Get_Reply();
void Get_Reply() {
while (!Serial1.available());
devnull = Serial1.read();
returnLength = Serial1.read() - 1;
for (unsigned int i=0;i< returnLength;i=i){
//Serial.print("\n\ri is: “);Serial.print(i);Serial.print(” “);
i++;
if (Serial.available()){
command = Serial.read();
switch ( command ){
case ‘1’:
Serial.println(”\n\rRead Card Make…");
case ‘2’:
Serial.println("\n\rRead Card Serial…");
Serial1.write(0xAB);Serial1.write(0x02);Serial1.write(0x02);
case ‘3’:
Serial.println("\n\rRead Card DATA…");
Serial1.write(0x0A);
Serial1.write(0x03);
Serial1.write(0x04);
Serial1.write(0x00,HEX);
Serial1.write(0xFF);
