I am trying to add PitcgBend to this scetch. I have spent many hours trying but I end with errors or without pitch bend.
I have two pots and one switch. One pot gives note number and switch press will play it. the second pot should add PB value.
You can probably tell that I have no clue what i am doing.
#include <MIDI.h>
const int switchPin = 2; // The switch is on Arduino pin 2
const int middleC = 33; // Middle C (MIDI note value 60) is the lowest note we'll play
byte note = 0; // The MIDI note value to be played
byte pitch = 0;
int val = 0; // value from the analog input0
int val2 = 1; // value from the analog input1
int lastNotePlayed = 0; // note turned on when you press the switch
int lastSwitchState = 0; // state of the switch during previous time through the main loop
int currentSwitchState = 0;
pinMode(switchPin, INPUT);
MIDI.begin(1);
MIDI.sendProgramChange(12,1);
val2 = analogRead(1); //pitch bend value
pitch = val2;
val = analogRead(0); //note number
note = val/8;
currentSwitchState = digitalRead(switchPin);
if (currentSwitchState == 1) {
if (lastSwitchState == 0) {
noteOn(0x90, note, 0x40);
lastNotePlayed = note;
else {
if (lastSwitchState == 1) {
noteOn(0x90, lastNotePlayed, 0x00);
lastSwitchState = currentSwitchState;
void noteOn(byte cmd, byte data1, byte data2) {
Serial.print(cmd, BYTE);
Serial.print(data1, BYTE);
Serial.print(data2, BYTE);
delay(100);
void pitchBend(byte data1, byte data2) {
