I try to make midi on stm32f103c8t6 blue pill with one potentiomter, how can i make to wotk with 16 buttons note?
Library:
Here is the code i use:
#include <Arduino.h>
#include <USBComposite.h>
USBMIDI midi;
const uint8 pot_pin = 5;
const uint8 threshold = 1;
const unsigned int midi_channel =
5; // this might show up as channel 6 depending on start index
const unsigned int cc_command = 0; // bank select command
unsigned int old_value = 0;
unsigned int new_value = 0;
// product id taken from library example
USBComposite.setProductId(0x0031);
pinMode(pot_pin, INPUT);
midi.begin();
int temp = analogRead(pot_pin); // a value between 0-4095
new_value = temp / 32; // convert to a value between 0-127
// If difference between new_value and old_value is grater than threshold
if (new_value > old_value && new_value - old_value > threshold ||
new_value < old_value && old_value - new_value > threshold) {
midi.sendControlChange(midi_channel, cc_command, new_value);
// Update old_value
old_value = new_value;
// Wait 50ms before reading the pin again
delay(50);
