Need help with Modbus Communication
hello,
im trying to communicate a controller with RS485 Modbus RTU using Arduino Mega2560
#include <Wire.h>
#include <SimpleModbusMaster.h>
#include <SoftwareSerial.h>
////////// Prot information ////////////
#define baud 9600 //The speed at which the data is set at the device
#define timeout 100 //Check Scan Time OUT.
#define polling 100 //the scan rate.
#define retry_count 10 //Check 10 rounds
#define TxEnablePin 2 //Use pin 2 on the Arduino Mega 2560 board as a control pin for receiving-sending data.
#define TOTAL_NO_OF_REGISTERS 13 //Use 1 register numbers.
enum //Collect the number of registers in batches
PACKET1,
//PACKET2,
//PACKET3,
// PACKET4,
//PACKET2,
TOTAL_NO_OF_PACKETS //leave this last entry.
Packet packets[TOTAL_NO_OF_PACKETS]; //Bring information, information together
unsigned int regs[TOTAL_NO_OF_REGISTERS];
modbus_construct(&packets[PACKET1], 3, READ_INPUT_REGISTERS,30000,6,10); // The first 1 is the position of the device to be read / 512 Is the position value Register.
modbus_configure(&Serial1, baud, SERIAL_8N2, timeout, polling, retry_count, TxEnablePin, packets, TOTAL_NO_OF_PACKETS, regs); //Set the value according to the device used to read the value.
modbus_update(); //To bring the function modbus_update used
float RDSS;
RDSS = regs[10];
Serial.print("READ = ");
Serial.println(RDSS);
//Serial.println(regs[0]);
/Serial.println(regs[2]);
Serial.println(regs[3]);
Serial.println(regs[4]);
Serial.println(regs[5]);
Serial.println(regs[6]);
Serial.println(regs[7]);
Serial.println(regs[8]);
Serial.println(regs[9]);
Serial.println(regs[10]);
Serial.println(regs[11]);
Serial.println(regs[12]);
that is my code which i got from searching online for very long time and that is not working and giving me some random number
kindly help me out with this
Thank you
