need help with my code ,thx
hey guys,
I am practicing on the millis() function. I wrote my code like this:
#include<Wire.h>
int ini = 0;
unsigned long pre_timer = 0;
unsigned long cur_timer;
void i2c_read()
Wire.beginTransmission(0x5A);
Wire.write(0x80);
Wire.endTransmission(false);
Wire.requestFrom(0x5A, 32);
while(Wire.available()) // slave may send less than requested
int c = Wire.read(); // receive a byte as character
Serial.print(c);
Wire.endTransmission();
pinMode(11, OUTPUT);
pinMode(6, OUTPUT);
TCCR2A = ((1 << WGM21) | (1 << COM2A0));
TCCR0A = ((1 << WGM01) | (1 << COM0A0));
TCCR2B = (1 << CS20); //8MHz
TCCR0B = ((1 << CS01) | (1 << CS00));
TIMSK2 = 0;
TIMSK0 = 0;
OCR2A = 0; //change to 3 for 2KHz
OCR0A = 11;
Wire.begin(); // join i2c bus (address optional for master)
Serial.begin(9600); // start serial for output
cur_timer = millis();
if(ini == 0)
Serial.print(cur_timer);
if((cur_timer - pre_timer) >1000)
ini = 1;
Serial.print(“hello”);
Serial.print(“hello_2”);
Serial.print(“not_hello”);
Serial.print(“delay”);
I am doing some I2C practice too, so there are some extra clk generation and I2C read function in the code,
I thought the extra code won’t do anything harm but I am wrong, with those code, I can only see the serial printed :
0
hello2
delay
It seems the loop ends after the first try. but if I remove the extra code, it just works fine.
Can anyone help me find out the conflict please? Thx
What code do you consider "the extra code"?
void i2c_read()
Wire.write(0x80);
Serial.print(c);
and
pinMode(6, OUTPUT);
TIMSK2 = 0;
TIMSK0 = 0;
OCR0A = 11;
If I remove these two part, it just worked.
Since you never call i2c_read(), that is not the problem code. Messing with the timers, without implementing a timer callback routine probably is. Why are you doing that?
PaulS:
I am trying to read from a I2C chip, and I need to generate 2 clk for the chip. that’s why I used Timer 0 and 2.
and I need to generate a delay before I start to read from that chip, that is why I wrote this code.
can you explain more about the timer callback routine please?
gzanta:
What does
TIMSK0 = 0;
do?
If it switches off Timer0 interrupts it probably stops millis() from working.
Please use the code button </>
so your code looks like this
and is easy to copy to a text editor
…R
Robin2:
What does
TIMSK0 = 0;
do?
…R
Thanks for the reply,
TIMSK0 is the Timer/Counter Interrupt Mask Register, I deleted that line, and it still not working .
IT seems the timer parts caused the problem,since I removed the I2C part and it didn’t help.
Yes, you messed up timer0 and the millis() function is not working. There is more wrong than TIMSK0=0.
You have changed the mode from the default mode (Fast PWM to 255 with TCCR0A = ((1 << WGM01) | (1 << WGM00)) and you need to have the overflow interrupt enabled TIMSK0 = (1<<TOIE0)
You did get the prescaler = 64 correct. TCCR0B = ((1 << CS01) | (1 << CS00))
cattledog:
THX, seems that’s the reason, if I remove the timer0 related code, it just worked fine.
