Need help with my code!!
Hi, I am new to the arduino world and trying to write a code that should generate a ttl pulse to control an air pressure regulator. Basically, 1. The pulse should go high/low respectively turning the regulator ON/OFF. 2. The duration I'm looking at for these ON/OFF cycles is about 6 s. Any advice on how to structure the code would be hugely appreciated and helpful :).
Thanks in advance!!
Sounds like digitalWrite and delay. What part is holding you up?
Well I was hoping to run it on a loop for about 6 cycles(ON/OFF) ,give a 30s delay and run it for 6 cycles again(ON/OFF).
Ok. Sounds like a for loop with digitalWrite and delay and then another delay. What part is holding you up?
Ok Thanks! Will try this out and hope it works :).
