So i am making 2 laser tag guns for a school project and when my attempt at using lasers and photoresistors didnt work i found this tutorial that used IR and arduino IBM Developer I assembled 2 guns and uploaded the code provided however the guns did not recieve signals from one another. From what I understand this is because in order to avoid a gun recieving it's own signal they made it ignore it. Thus they both ignore the same signal. So would it work for me to change the signal of one gun and what it ignores. If so what would I have to change and to what. The reason i posted theis is because I'm really new to coding and the arduino and dont have the time to learn before my project due date in a few days. Any help/advice would be greatly appreciated.
Cheers
* Giving Credit where Credit Is Due
* Portions of this code were derived from code posted in the Arduino forums by Paul Malmsten.
* You can find the original thread here: http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1176098434
* The Audio portion of the code was derived from the Melody tutorial on the Arduino wiki
* You can find the original tutorial here: http://arduino.cc/en/Tutorial/Melody
int sensorPin = 2; // Sensor pin 1
int senderPin = 3; // Infrared LED on Pin 3
int triggerPin = 4; // Pushbutton Trigger on Pin 4
int speakerPin = 12; // Positive Lead on the Piezo
int blinkPin = 13; // Positive Leg of the LED we will use to indicate signal is received
int startBit = 2000; // This pulse sets the threshold for a transmission start bit
int endBit = 3000; // This pulse sets the threshold for a transmission end bit
int one = 1000; // This pulse sets the threshold for a transmission that represents a 1
int zero = 400; // This pulse sets the threshold for a transmission that represents a 0
int trigger; // This is used to hold the value of the trigger read;
boolean fired = false; // Boolean used to remember if the trigger has already been read.
int ret[2]; // Used to hold results from IR sensing.
int waitTime = 300; // The amount of time to wait between pulses
int playerLine = 14; // Any player ID >= this value is a referee, < this value is a player;
int myCode = 1; // This is your unique player code;
int myLevel = 1; // This is your starting level;
int maxShots = 6; // You can fire 6 safe shots;
int maxHits = 6; // After 6 hits you are dead;
int myShots = 0; // You can fire 6 safe shots;
int myHits = 0; // After 6 hits you are dead;
int maxLevel = 9; // You cannot be promoted past level 9;
int minLevel = 0; // You cannot be demoted past level 0
int refPromote = 0; // The refCode for promotion;
int refDemote = 1; // The refCode for demotion;
int refReset = 2; // The refCode for ammo reset;
int refRevive = 3; // The refCode for revival;
int replySucc = 14; // the player code for Success;
int replyFail = 15; // the player code for Failed;
pinMode(blinkPin, OUTPUT);
pinMode(speakerPin, OUTPUT);
pinMode(senderPin, OUTPUT);
pinMode(triggerPin, INPUT);
pinMode(sensorPin, INPUT);
randomSeed(analogRead(0));
for (int i = 1;i < 4;i++) {
digitalWrite(blinkPin, HIGH);
playTone(900*i, 200);
digitalWrite(blinkPin, LOW);
delay(200);
Serial.println("Ready: ");
senseFire();
senseIR();
if (ret[0] != -1) {
playTone(1000, 50);
Serial.print("Who: ");
Serial.print(ret[0]);
Serial.print(" What: ");
Serial.println(ret[1]);
if (ret[0] >= playerLine) {
if (ret[1] == refPromote) {
// Promote
if (myLevel < maxLevel) {
Serial.println("PROMOTED!");
myLevel++;
playTone(900, 50);
playTone(1800, 50);
playTone(2700, 50);
} else if (ret[1] == refDemote) {
// demote
if (myLevel > minLevel) {
Serial.println("DEMOTED!");
myLevel--;
playTone(2700, 50);
playTone(1800, 50);
playTone(900, 50);
} else if (ret[1] == refReset) {
Serial.println("AMMO RESET!");
myShots = maxShots;
playTone(900, 50);
playTone(450, 50);
playTone(900, 50);
playTone(450, 50);
playTone(900, 50);
playTone(450, 50);
} else if (ret[1] == refRevive) {
Serial.println("REVIVED!");
myShots = 0;
myHits = 0;
myLevel = 1;
playTone(900, 50);
playTone(1800, 50);
playTone(900, 50);
playTone(1800, 50);
playTone(900, 50);
playTone(800, 50);
if (ret[1] == replySucc) {
playTone(9000, 50);
playTone(450, 50);
playTone(9000, 50);
Serial.println("SUCCESS!");
} else if (ret[1] == replyFail) {
playTone(450, 50);
playTone(9000, 50);
playTone(450, 50);
Serial.println("FAILED!");
if (ret[1] <= maxLevel && ret[1] >= myLevel && myHits <= maxHits) {
Serial.println("HIT!");
myHits++;
playTone(9000, 50);
playTone(900, 50);
playTone(9000, 50);
playTone(900, 50);
void senseIR() {
int who[4];
int what[4];
int end;
if (pulseIn(sensorPin, LOW, 50) < startBit) {
ret[0] = -1;
return;
who[0] = pulseIn(sensorPin, LOW);
who[1] = pulseIn(sensorPin, LOW);
who[2] = pulseIn(sensorPin, LOW);
who[3] = pulseIn(sensorPin, LOW);
what[0] = pulseIn(sensorPin, LOW);
what[1] = pulseIn(sensorPin, LOW);
what[2] = pulseIn(sensorPin, LOW);
what[3] = pulseIn(sensorPin, LOW);
end = pulseIn(sensorPin, LOW);
if (end <= endBit) {
Serial.print(end);
Serial.println(" : bad end bit");
ret[0] = -1;
return;
Serial.println("---who---");
for(int i=0;i<=3;i++) {
Serial.println(who[i]);
if(who[i] > one) {
who[i] = 1;
} else if (who[i] > zero) {
who[i] = 0;
// Since the data is neither zero or one, we have an error
Serial.println("unknown player");
ret[0] = -1;
return;
ret[0]=convert(who);
Serial.println(ret[0]);
Serial.println("---what---");
Serial.println(what[i]);
if(what[i] > one) {
what[i] = 1;
} else if (what[i] > zero) {
what[i] = 0;
Serial.println("unknown action");
ret[0] = -1;
return;
ret[1]=convert(what);
return;
void playTone(int tone, int duration) {
for (long i = 0; i < duration * 1000L; i += tone * 2) {
digitalWrite(speakerPin, HIGH);
delayMicroseconds(tone);
digitalWrite(speakerPin, LOW);
int convert(int bits[]) {
int result = 0;
int seed = 1;
for(int i=3;i>=0;i--) {
if(bits[i] == 1) {
result += seed;
seed = seed * 2;
return result;
void senseFire() {
trigger = digitalRead(triggerPin);
if (trigger == LOW && fired == false) {
Serial.println("Button Pressed");
fired = true;
myShots++;
if (myHits <= maxHits && myShots > maxShots && random(1,20) <= myShots) {
Serial.println("SELF DESTRUCT");
selfDestruct();
} else if (myHits <= maxHits) {
Serial.print("Firing Shot : ");
Serial.println(myShots);
fireShot(myCode, myLevel);
} else if (trigger == HIGH) {
if (fired == true) {
Serial.println("Button Released");
// reset the fired variable
fired = false;
void fireShot(int player, int level) {
int encoded[8];
for (int i=0; i<4; i++) {
encoded[i] = player>>i & B1; //encode data as '1' or '0'
for (int i=4; i<8; i++) {
encoded[i] = level>>i & B1;
// send startbit
oscillationWrite(senderPin, startBit);
// send separation bit
digitalWrite(senderPin, HIGH);
delayMicroseconds(waitTime);
// send the whole string of data
for (int i=7; i>=0; i--) {
if (encoded[i] == 0) {
oscillationWrite(senderPin, zero);
oscillationWrite(senderPin, one);
oscillationWrite(senderPin, endBit);
playTone(100, 5);
void oscillationWrite(int pin, int time) {
for(int i = 0; i <= time/26; i++) {
digitalWrite(pin, HIGH);
delayMicroseconds(13);
digitalWrite(pin, LOW);
void selfDestruct() {
myHits = maxHits+1;
playTone(1000, 250);
playTone(750, 250);
playTone(500, 250);
playTone(250, 250);
Duino_Tag_Full.pde (7.99 KB)
