Need help with Nema 17, 5-pin joystick, easydriver and arduino uno
Hello,
I am trying to make a NEMA 17 bipolar motor move in both directions using a 5-pin joystick module, an easy-driver stepper driver and an arduino uno.
Please see below for code I am using and see attachment for the wiring diagram I am using.
I have it set up exactly like this but the motor still won't move, it just vibrates a bit.
Any help would be greatly appreciated.
Thanks!
#define step_pin 3  // Pin 3 connected to Steps pin on EasyDriver
#define dir_pin 2   // Pin 2 connected to Direction pin
#define MS1 5       // Pin 5 connected to MS1 pin
#define MS2 4       // Pin 4 connected to MS2 pin
#define SLEEP 7     // Pin 7 connected to SLEEP pin
#define X_pin A0    // Pin A0 connected to joystick x axis
int direction;    // Variable to set Rotation (CW-CCW) of the motor
int steps = 1025; // Assumes the belt clip is in the Middle
   pinMode(MS1, OUTPUT);
   pinMode(MS2, OUTPUT);
   pinMode(dir_pin, OUTPUT);
   pinMode(step_pin, OUTPUT);
   pinMode(SLEEP, OUTPUT);
   digitalWrite(SLEEP, HIGH);  // Wake up EasyDriver
   delay(5);  // Wait for EasyDriver wake up
/* Configure type of Steps on EasyDriver:
// MS1 MS2
// LOW LOW = Full Step //
// HIGH LOW = Half Step //
// LOW HIGH = A quarter of Step //
// HIGH HIGH = An eighth of Step //
   digitalWrite(MS1, LOW);      // Configures to Full Steps
   digitalWrite(MS2, LOW);    // Configures to Full Steps
  while (analogRead(X_pin) >= 0 && analogRead(X_pin) <= 100) {
    if (steps > 0) {
      digitalWrite(dir_pin, HIGH);  // (HIGH = anti-clockwise / LOW = clockwise)
      digitalWrite(step_pin, HIGH);
      delay(1);
      digitalWrite(step_pin, LOW);
      delay(1);
      steps--;
    while (analogRead(X_pin) > 100 && analogRead(X_pin) <= 400) {
      if (steps < 512) {
        digitalWrite(dir_pin, LOW);  // (HIGH = anti-clockwise / LOW = clockwise)
        delay(1);
        delay(1);
        steps++;
      if (steps > 512) {
        delay(1);
        delay(1);
        steps--;
    while (analogRead(X_pin) > 401 && analogRead(X_pin) <= 600) {
      if (steps < 1025) {
        delay(1);
        delay(1);
        steps++;
      if (steps > 1025) {
        delay(1);
        delay(1);
        steps--;
    while (analogRead(X_pin) > 601 && analogRead(X_pin) <= 900) {
      if (steps < 1535) {
        delay(1);
        delay(1);
        steps++;
      if (steps > 1535) {
        delay(1);
        delay(1);
        steps--;
    while (analogRead(X_pin) > 900 && analogRead(X_pin) <= 1024) {
      if (steps < 2050) {
        delay(1);
        delay(1);
        steps++;
Try longer delays. If you send the pulses to the stepper too fast then it doesn't have enough time to move. You'll find that a long delay works fine, but that limits the speed of the motor. There is some optimal pulse interval you'll find that achieves the maximum speed. An shorter delay than that will actually make the motor move slower and have less torque due to missing steps. This is actually not a fixed value. The minimum delay of the stepper starting from a stop or reversing direction is longer than the minimum delay when the motor is moving in the desired direction. This is why people will use acceleration; gradually decreasing the pulse interval until the maximum speed is achieved.
You need to ramp up step rates, not jump to full speed, the rotor of a stepper motor has inertia and will not respond to instant changes in speed.
The AccelStepper library is the first thing to look at - get some of the examples working with that first.
