Need help with non delay timing
Here is a snippet of code where I am trying to shutdown a neopixel stick so it goes off one led at a time. I want to be able to control the speed of the sequence with an interval. I can't seem to get the timer to work though. Looking for help.
/************************* Shutdown and helper functions ****************************/
unsigned long lastBarMillis_on = 0;   // bargraph on tracker
const int pd_interval = 100;     // interval at which to cycle lights (milliseconds).
void bargraph_shutdown(int currentMillis) {
  if(currentMillis - lastBarMillis_on > pd_interval){
  // save the last time you blinked the LED
    lastBarMillis_on = currentMillis;
    for (int i=7; i>-1; i-- ){//Bargraph power down sequence
    barGraph.setPixelColor(i,0);
    barGraph.show();}
    safety=false;}}
Post all your code.
If currentMillis is to contain what it sounds like, it should be of type unsigned long and not int.
There's a lot of code, but currentMillis is just holding the value for millis
 // get the current time
  int currentMillis = millis();
Here is what I have, but still does not use the delay to shutdown each pixel:
void bargraph_shutdown(unsigned long currentMillis) {
    barGraph.show();}
    safety=false;}
grogking:
Read reply #1 again. Especially the second sentence.
DangerToMyself:
If you notice the post just above yours, I have made that change. It still doesn't work.
In the code which you haven’t shown, is the function bargraph_shutdown() called once per shutdown, or is it called at regular intervals? In the function, there is no timing element in the loop which has the comment “ Bargraph power down sequence”, so it will go from 7 to 0 in a fraction of second.
Incidentally, it unusual to pass a value of millis() into a function. Instead, you can just test millis() directly in the function.
6v6gt:
It's called once per shutdown.
So, you expect the code to block until shutdown is complete. Given that, please explain why you are trying to convert it to a non-blocking function by not using delay().
grogking:
My appologies. Too much Killian's. I'm surprised my reply was even close to coherent.
Too much Killian's.
No such thing. You've been drinking too much if you even consider that such a thing is possible.
PaulS:
And I was just thinking how appropriate his choice of screen name was.
