need help with p.o.v section of slapped together tix clock
such a smartass
"any foreseeable problems doing it this way and just changing resistors to adjust led brightness?"
the brightness thing is ok, just gotta work on resistor values ... and if you look at the code i last uploaded.
each led is being turned off and on individually. therefore taking the current issue out of the equation ....i thought....
"Currently, when your code performs its flash() function, it is not overloading the pins because only 1 led is ever lit at once"
which part am i ignoring... if youre just going to be rude... why stop by a help request topic....
