I've been interested in Arduino and the whole electronics community for a while, but never can get anywhere. I have a friend who does canvas painting, and needs his paint to stay active by being constantly turned.
I have a couple ideas in mind of how to go about this project, but I need some pointers, as in what kind of motor I would need, etc.
Sorry if this is in the wrong forum category or if project is too basic
Basically I need to create a base that can hold a few dozen paint bottles, this base needs to rotate constantly. The total weight of the bottles is about 35lbs, what kind of motor would I use?
You will need a disk, supported by a ball bearing race (look for "Lazy Susan" in a home improvement store), that is wide and sturdy enough to hold the bottles.
The disk could be connected by a belt to a gearmotor shaft. Select a gear ratio so that the disk rotates at the desired RPM.
I would also use the Lazy Susan fixture for the turning part and the wooden disk mounted on the fixture. But I would add a rubber wheel to the motor and press it against the edge of the disk to make the disk turn.
You might spend a few words on just how turning bottles around on a disk will keep the paint active. It will certainly not be stirring the paint.
My ‘Can Shaker’ uses an Arduino
Nano and a powerful solenoid to, er, shake a can. Of anything, but spray paint was my objective. At a settable frequency and a settable duration (max 5 mins).
With a much larger holder I imagine it could be adapted to several cans. Their weight is obviously a major factor, not one I think you’ve mentioned.
And, of course, a regular motor could be an alternative to my ancient surplus solenoid, whose last incarnation was as a shoe stretcher a few decades ago.
