Need help with phototransistor and a IR diode
I have obtained a awesome sketch that runs a 2 lane slot car timer. The problem is I have a Tinkerkit LCD that enables a 4 wire serial port hook up as the illustrations I have attached shows.
I am also using two NTE3037NPN-Si Phototransistors, and there matching counter parts NTE3029b IR diodes, as the switches that sense when the cars pass through the light gantry. The Phototransistor has a Collector, emitter, and a base electrode. I am not sure what the base prong is for and I am uncertain if the coding will sense the signal the way it is written.
I am in way to deep for the knowledge I have with coding and IR sensors so I am reaching out for help from the exsperts. I will be very thankful for anyones help or suggestions..
Code I have is as follows
[quote]
#include <[color=#CC6600]LiquidCrystal[/color].h>
[color=#7E7E7E]/*[/color]
[color=#7E7E7E]VERSION 0.3 [/color]
[color=#7E7E7E]-Added Green LED For Best Round[/color]
[color=#7E7E7E]*/[/color]
[color=#7E7E7E]// PIN CONFIGURATION[/color]
[color=#CC6600]LiquidCrystal[/color] lcd(12, 11, 5, 4, 3, 2);
[color=#CC6600]int[/color] laserPin = 13;
[color=#CC6600]int[/color] buttonPin1 = 7;
[color=#CC6600]int[/color] buttonPin2 = 8;
[color=#CC6600]int[/color] speakerPin = 9;
[color=#CC6600]int[/color] ledPin1 = 0; [color=#7E7E7E]// red [/color]
[color=#CC6600]int[/color] ledPin2 = 1; [color=#7E7E7E]// red[/color]
[color=#CC6600]int[/color] ledPin3 = 10; [color=#7E7E7E]// green[/color]
[color=#7E7E7E] States // The central state the timer is in[/color]
[color=#7E7E7E] [/color]
[color=#7E7E7E] 0 = pause;[/color]
[color=#7E7E7E] 1 = countdown;[/color]
[color=#7E7E7E] 2 = running;[/color]
[color=#CC6600]int[/color] state = 0;
[color=#CC6600]boolean[/color] displayLastRound = [color=#CC6600]true[/color];
[color=#CC6600]boolean[/color] running = [color=#CC6600]false[/color];
[color=#CC6600]int[/color] lightLevel = 0;
[color=#CC6600]long[/color] lastHit = 0; [color=#7E7E7E]//time of the last hit in the barrier (absolut)[/color]
[color=#CC6600]boolean[/color] lock; [color=#7E7E7E]// locks the light barrier while a car is passing. The look is removed as soon the car left the lightbeam and the roundTreshold time has passed[/color]
[color=#CC6600]long[/color] lastRound = 0; [color=#7E7E7E]// time of the lastround (absolut)[/color]
[color=#CC6600]long[/color] bestRound = 0; [color=#7E7E7E]// time of the bestround (relative)[/color]
[color=#CC6600]int[/color] roundNr = 0;
[color=#CC6600]int[/color] laserTreshold = 10;
[color=#CC6600]int[/color] roundTreshold = 300; [color=#7E7E7E]// minimum time that has to pass before a new round is counted[/color]
[color=#7E7E7E]// Absolut time for pressing buttons[/color]
[color=#CC6600]long[/color] lastPress1 = 0;
[color=#CC6600]long[/color] lastPress2 = 0;
[color=#7E7E7E]// LED Timer[/color]
[color=#CC6600]long[/color] timeLEDGreen = 0;
[color=#CC6600]void[/color] [color=#CC6600][b]setup[/b][/color]() {
  [color=#CC6600]pinMode[/color](laserPin, [color=#006699]OUTPUT[/color]);
  [color=#CC6600]pinMode[/color](buttonPin1, [color=#006699]INPUT[/color]);
  [color=#CC6600]pinMode[/color](buttonPin2, [color=#006699]INPUT[/color]);
  [color=#CC6600]pinMode[/color](speakerPin, [color=#006699]OUTPUT[/color]);
  [color=#CC6600]pinMode[/color](ledPin1, [color=#006699]OUTPUT[/color]);
  [color=#CC6600]pinMode[/color](ledPin2, [color=#006699]OUTPUT[/color]);
  [color=#CC6600]pinMode[/color](ledPin3, [color=#006699]OUTPUT[/color]);
  [color=#7E7E7E]// set up the LCD's number of columns and rows: [/color]
  lcd.[color=#CC6600]begin[/color](16, 2);
  lcd.[color=#CC6600]setCursor[/color](0, 0);
  lcd.[color=#CC6600]print[/color]([color=#006699]"Arduino"[/color]);
  lcd.[color=#CC6600]setCursor[/color](0, 1);
  lcd.[color=#CC6600]print[/color]([color=#006699]"Laser Lap Timer  "[/color]);
  [color=#CC6600]delay[/color](1500);
  lcd.[color=#CC6600]print[/color]([color=#006699]"Christoph &"[/color]);
  lcd.[color=#CC6600]print[/color]([color=#006699]"Peter Halang    "[/color]);
  [color=#7E7E7E]//Serial.begin(9600);[/color]
[color=#CC6600]void[/color] [color=#CC6600][b]loop[/b][/color]() {
  [color=#CC6600]if[/color](![color=#CC6600]digitalRead[/color](buttonPin1)){
    button1Pressed();
  [color=#CC6600]if[/color](![color=#CC6600]digitalRead[/color](buttonPin2)){
    button2Pressed();
  [color=#CC6600]switch[/color] (state){
  [color=#CC6600]case[/color] 0:
    statePaused();
    [color=#CC6600]break[/color];
  [color=#CC6600]case[/color] 1:
    stateCountdown();
  [color=#CC6600]case[/color] 2:
    stateRunning();
[color=#CC6600]void[/color] didFinishRound(){
  [color=#CC6600]if[/color](roundNr > 0)lastRound = [color=#CC6600]millis[/color]()-lastHit;
  [color=#CC6600]if[/color] (bestRound == 0){
    bestRound = lastRound;
  [color=#CC6600]if[/color] (lastRound < bestRound){
    timeLEDGreen = [color=#CC6600]millis[/color]()+1000;
  lastHit = [color=#CC6600]millis[/color]();
  lock = [color=#CC6600]true[/color];
  ++roundNr;
[color=#CC6600]void[/color] statePaused(){
  [color=#CC6600]digitalWrite[/color](ledPin1, [color=#006699]LOW[/color]);
  [color=#CC6600]digitalWrite[/color](ledPin2, [color=#006699]LOW[/color]);
  [color=#CC6600]digitalWrite[/color](ledPin3, [color=#006699]LOW[/color]);
  [color=#CC6600]digitalWrite[/color](laserPin,[color=#006699]LOW[/color]);
  lcd.[color=#CC6600]print[/color]([color=#006699]"Press right   "[/color]);
  lcd.[color=#CC6600]print[/color]([color=#006699]"button to start"[/color]);
[color=#CC6600]void[/color] stateRunning(){
  [color=#7E7E7E]//switch laser on[/color]
  [color=#CC6600]digitalWrite[/color](laserPin,[color=#006699]HIGH[/color]);
  [color=#7E7E7E]//mesasure light[/color]
  lightLevel = [color=#CC6600]analogRead[/color](0);
  lightLevel = [color=#CC6600]map[/color](lightLevel, 0, 900, 0, 255);
  lightLevel = [color=#CC6600]constrain[/color](lightLevel, 0, 255);
  [color=#7E7E7E]//Serial.println(lightLevel);[/color]
  [color=#7E7E7E]// react to light[/color]
  [color=#CC6600]if[/color](lightLevel < laserTreshold){
    [color=#7E7E7E]//digitalWrite(ledPin,LOW);[/color]
    lock = [color=#CC6600]false[/color];
  [color=#CC6600]else[/color]{
    [color=#7E7E7E]// digitalWrite(ledPin,HIGH);[/color]
    [color=#CC6600]if[/color] ([color=#CC6600]millis[/color]()-lastHit > roundTreshold && lock == [color=#CC6600]false[/color]){
      didFinishRound();
  [color=#7E7E7E]// We have'nt finished the first round[/color]
  [color=#CC6600]if[/color](roundNr == 0){
    lcd.[color=#CC6600]setCursor[/color](0,0);
    lcd.[color=#CC6600]print[/color]([color=#006699]"Standby...      "[/color]);
    lcd.[color=#CC6600]setCursor[/color](0,1);
    lcd.[color=#CC6600]print[/color]([color=#006699]"                "[/color]);
  [color=#7E7E7E]// Display the time and best / last round[/color]
    displaySecondLine();
    displayFirstLine();
  [color=#7E7E7E]// turn off all LED[/color]
  [color=#CC6600]if[/color] (timeLEDGreen > [color=#CC6600]millis[/color]()){
      [color=#CC6600]digitalWrite[/color](ledPin3, [color=#006699]HIGH[/color]);
[/quote]
Here are the data sheets for the sensors I am using
nte3037.pdf (77 KB)
NTE3029B.pdf (24.5 KB)
Please post your code without all the HTML markup, it's too hard to read as it is.
Here is the code revised, Sorry
VERSION 0.3
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
int laserPin = 13;
int buttonPin1 = 7;
int buttonPin2 = 8;
int speakerPin = 9;
int ledPin1 = 0; // red
int ledPin2 = 1; // red
int ledPin3 = 10; // green
 0 = pause;
 1 = countdown;
 2 = running;
int state = 0;
boolean displayLastRound = true;
boolean running = false;
int lightLevel = 0;
long lastHit = 0; //time of the last hit in the barrier (absolut)
boolean lock; // locks the light barrier while a car is passing. The look is removed as soon the car left the lightbeam and the roundTreshold time has passed
long lastRound = 0; // time of the lastround (absolut)
long bestRound = 0; // time of the bestround (relative)
int roundNr = 0;
int laserTreshold = 10;
int roundTreshold = 300; // minimum time that has to pass before a new round is counted
long lastPress1 = 0;
long lastPress2 = 0;
// LED Timer
long timeLEDGreen = 0;
  pinMode(laserPin, OUTPUT);
  pinMode(buttonPin1, INPUT);
  pinMode(buttonPin2, INPUT);
  pinMode(speakerPin, OUTPUT);
  pinMode(ledPin1, OUTPUT);
  pinMode(ledPin2, OUTPUT);
  pinMode(ledPin3, OUTPUT);
  lcd.begin(16, 2);
  lcd.setCursor(0, 0);
  lcd.print("Arduino");
  lcd.setCursor(0, 1);
  lcd.print("Laser Lap Timer  ");
  delay(1500);
  lcd.print("Christoph &");
  lcd.print("Peter Halang    ");
  delay(1500);
  if(!digitalRead(buttonPin1)){
    button1Pressed();
  if(!digitalRead(buttonPin2)){
    button2Pressed();
  switch (state){
  case 0:
    statePaused();
  case 1:
    stateCountdown();
  case 2:
    stateRunning();
void didFinishRound(){
  if(roundNr > 0)lastRound = millis()-lastHit;
  if (bestRound == 0){
  if (lastRound < bestRound){
    timeLEDGreen = millis()+1000;
  lastHit = millis();
  lock = true;
  ++roundNr;
void statePaused(){
  digitalWrite(ledPin1, LOW);
  digitalWrite(ledPin2, LOW);
  digitalWrite(ledPin3, LOW);
  digitalWrite(laserPin,LOW);
  lcd.print("Press right   ");
  lcd.print("button to start");
void stateRunning(){
  //switch laser on
  digitalWrite(laserPin,HIGH);
  //mesasure light
  lightLevel = analogRead(0);
  lightLevel = map(lightLevel, 0, 900, 0, 255);
  lightLevel = constrain(lightLevel, 0, 255);
  // react to light
  if(lightLevel < laserTreshold){
    lock = false;
  else{
    if (millis()-lastHit > roundTreshold && lock == false){
      didFinishRound();
  if(roundNr == 0){
    lcd.setCursor(0,0);
    lcd.print("Standby...      ");
    lcd.setCursor(0,1);
    lcd.print("                ");
  else{
    displayFirstLine();
  // turn off all LED
  if (timeLEDGreen > millis()){
      digitalWrite(ledPin3, HIGH);
  else{
void stateCountdown(){
  lcd.clear();
  lcd.print("Ready             ");
  digitalWrite(ledPin1, HIGH);
  playNote('c',300);
  lcd.print("Set             ");
  digitalWrite(ledPin2, HIGH);
  playNote('c',300);
  lcd.print("Go             ");
  playNote('g',600);
  state = 2;
void displayFirstLine(){
  lcd.print("Rd");
  lcd.print(" ");
  lcd.print(roundNr);
  lcd.print(" ");
  lcd.print(millis()-lastHit);
  lcd.print("ms");
  lcd.print("                       ");
void displaySecondLine(){
  if(displayLastRound){
    lcd.print("Last ");
    lcd.print(lastRound);
    lcd.print("ms");
    lcd.print("                       ");
  else{
    lcd.print("Best ");
    lcd.print(bestRound);
    lcd.print("ms");
    lcd.print("                       ");
void button1Pressed(){
  if(millis()-lastPress1 > 800){
    lastPress1 = millis();
    displayLastRound = !displayLastRound;
void button2Pressed(){
  if(millis()-lastPress2 > 800){
    lastPress2 = millis();
    if (state == 0){
      state = 1;
    if (state == 2){
      roundNr = 0;
      bestRound = 0;
      lastRound = 0;
      state = 0;
void playTone(int tone, int duration) {
  for (long i = 0; i < duration * 1000L; i += tone * 2) {
    digitalWrite(speakerPin, HIGH);
    delayMicroseconds(tone);
    digitalWrite(speakerPin, LOW);
void playNote(char note, int duration) {
  char names[] = {
    'c', 'd', 'e', 'f', 'g', 'a', 'b', 'C'   };
  int tones[] = {
    1915, 1700, 1519, 1432, 1275, 1136, 1014, 956   };
  // play the tone corresponding to the note name
  for (int i = 0; i < 8; i++) {
    if (names[i] == note) {
      playTone(tones[i], duration);
Are you trying to run everything on the Tinkerkit (which works like a Leonardo according to the documentation), or are you running a sketch on a separate Arduino and trying to use the Tinkerkit just as a serial LCD? If you are just using the Tinkerkit as a serial LCD, do you already have it printing characters sent from a Arduino?
