Need help with preferences in 2.0
I had the old IDE set up to open a new sketch that I had written. I can’t seem to find a way to change the default new sketch.
Also, I have all of my libraries on a cloud drive so I can use them from multiple computers. The option to change the libraries location seems to be missing or I can’t find it because I’m old and can’t see. LOL
Thanks
Your topic has been moved to the dedicated IDE2.0 section of the forum.
As far as I know, the 'new' is hard coded.
Can't answer about the libraries.
AFAIKT the 'Sketchbook location' setting is still there in v2.0.0. I don't think there was a separate Library location setting?
The Arduino IDE developers are tracking the request to make this code easier to customize here:
For now, you can modify the File > New sketch by editing the file at this subfolder of the Arduino IDE installation:
resources/app/node_modules/arduino-ide-extension/lib/node/sketches-service-impl.js
The sketch is defined by the code that looks something like this:
        await (0, util_1.promisify)(fs.writeFile)(sketchFile, `void setup() {
`, { encoding: 'utf8' });
        return this.loadSketch(node_1.FileUri.create(sketchDir).toString());
