I am trying to input values to an array which get printed simultaneously, and later, after all values of array have been inputted, the array is printed.
On running this, the arduino is not waiting for me to input data, except it just continously keeps on printing "Your array is 0".
Any help would be appreciated
Here's my code
byte incomingByte[7]; // for incoming serial data
Serial.begin(9600); // opens serial port, sets data rate to 9600 bps
// send data only when you receive data:
for(int i=0; i<7;i++)
while (Serial.available() ) {
// read the incoming byte:
incomingByte[i] = Serial.read();
Serial.print(incomingByte[i]);
for(int i=0;i<7;i++)
Serial.print("Your array is");
Serial.println(" ");
aarg:
It just returns the number of characters that are available. There is no mystery to it.
I understand. But what I want the processor to do is, to wait till I input the first byte, then print then first byte, then wait till I input the second byte, print the second byte and so on. After 7 inputs, I want the processor to print the whole array together.
The first time a while loop is initiated, the test is performed. If the test fails, the entire block is skipped. So the code block of a while loop may never run. That is what is happening to you while the program loops and waits for you to send a character.
aarg:
I understand the problem now. But how do I make the processor wait till new values are inputted?
Spend some time with this an see if you can explain it.
static int i = 0;
// incomingByte[i] = Serial.read(); // These two lines save and show ASCII digit characters
// Serial.println( (char) incomingByte[i]);
incomingByte[i] = Serial.read() - '0'; // These two line save and show numeric values
Serial.println(incomingByte[i]);
i++;
if (i == 7) {
i = 0;
Serial.println("Your array is");
for (int j = 0; j <7; j++)
// Serial.print((char) incomingByte[j]); // This shows the ASCII codes as digit character
Serial.print(incomingByte[j]); // This shows the numeric value
mansimar01:
Hi!
I am new to Arduino programming language.
Here's my code
