Need Help With Processing
Hello, i am fairly new when it comes to arduino and processing. I am having an issue getting a CSV file to populate with the data that is coming from arduino. How do I do I make it populate the CSV file?
I will provide both codes I am using below.
Arduino Code:
const int pwPin = 7;
//variables needed to store values
long pulse, mm, cm;
int sensorVals[] = {0};
  //This opens up a serial connection to shoot the results back to the PC console
  pinMode(pwPin, INPUT);
    //Used to read in the pulse that is being sent by the MaxSonar device.
  //Pulse Width representation with a scale factor of 147 uS per Inch.
  pulse = pulseIn(pwPin, HIGH);
  //1uS per mm
  mm = pulse/1;
  //change mm to m
  cm = mm/10;
  Serial.print(mm);
  Serial.print("mm, ");
  Serial.print(cm);
  Serial.print("cm, ");
  delay(1);
Processing Code:
import processing.serial.*;
PrintWriter output;
Table table;
Serial myPort;  // Create object from Serial class
String val;     // Data received from the serial port
void setup(){
// I know that the first port in the serial list on my mac
// is Serial.list()[0].
// On Windows machines, this generally opens COM1.
// Open whatever port is the one you're using.
String portName = Serial.list()[1]; //change the 0 to a 1 or 2 etc. to match your port
myPort = new Serial(this, portName, 9600);
 table = new Table();
  table.addColumn("id");
  table.addColumn("mm");
  table.addColumn("cm");
  TableRow newRow = table.addRow();
  newRow.setInt("id", table.lastRowIndex());
  newRow.setString("mm","Distance 1");
  newRow.setString("cm","Distance 2");
  saveTable(table, "data/new.csv");
void draw()
  if ( myPort.available() > 0)
  {  // If data is available,
  val = myPort.readStringUntil('\n');         // read it and store it in val
println(val); //print it out in the console
Hi
From your description, I guess you want to merge your own code into the CSV processing code, right?
If cm and mm are the int value, try to add the following code
newRow.setInt("mm",mm);
newRow.setInt("cm","cm);
Once it all gets finished
call
