Need Help with program
My son is making a robot for his school project and it works fine however now the robot has to stop once the demastration is done. it must go for 30 seconds minimum.
if you could help m e put code in for the robot to time out at 60 seconds would be awesome
Thanks so much.
#include <NewPing.h>
#include <Servo.h>     //Inclue Servo Library
#include <NewPing.h>   //Include NewPing Library
Servo leftServo;       //Create Left Servo object
Servo rightServo;      //Create Right Servo object
#define TRIGGER_PIN  6   //Trigger pin of Ultrasonic sensor connected to pin 6
#define ECHO_PIN     7   //Echo pin of Ultrasonic sensor connected to pin 7
#define MAX_DISTANCE 100 //The maximum distance we want the sensor to look for is 1m
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE);  //Create Ultrasonic sensor object
unsigned int time;            //Variable to store how long it takes for the ultrasonic wave to come back
int distance;                 //Variable to store the distance calculated from the sensor
int triggerDistance = 30;     //The distance we want the robot to look for a new path
int fDistance;                //Variable to store the distance in front of the robot
int lDistance;                //Variable to store the distance on the left side of the robot
int rDistance;                //Variable to store the distance on the right side of the robot
  leftServo.attach(9);        //Left servo connected to pin 9
  leftServo.write(90);        //Write the neutral position to that servo
  rightServo.attach(8);       //Right servo connected to pin 8
  rightServo.write(90);       //Write the neutral position to that servo
  scan();                                //Get the distance retrieved
  fDistance = distance;                  //Set that distance to the front distance
  if(fDistance < triggerDistance){       //If there is something closer than 30cm in front of us
    moveBackward();                      //Move Backward for a second
    moveRight();                         //Turn Right for half a second
    moveStop();                          //Stop
    scan();                              //Take a reading
    rDistance = distance;                //Store that to the distance on the right side
    moveLeft();
    delay(1000);                         //Turn left for a second
    moveStop();                          //Stop
    lDistance = distance;                //Store that to the distance on the left side
    if(lDistance < rDistance){           //If the distance on the left is smaller than that of the right
      moveRight();                       //Move right for a second
      moveForward();                     //Then move forward
    else{
      moveForward();                     //If the left side is larger than the right side move forward
  else{
    moveForward();                       //If there is nothing infront of the robot move forward
void scan(){
  time = sonar.ping();                  //Send out a ping and store the time it took for it to come back in the time variable
  distance = time / US_ROUNDTRIP_CM;    //Convert that time into a distance
  if(distance == 0){                    //If no ping was recieved
    distance = 100;                     //Set the distance to max
  delay(10);
void moveBackward(){
  rightServo.write(180);
  leftServo.write(0);
void moveForward(){
  rightServo.write(0);
  leftServo.write(180);
void moveRight(){
  leftServo.write(0);
void moveLeft(){
void moveStop(){
  leftServo.write(95);
Take a look at the "blink without delay" example.
Mark
thanks Mark :slight_smile: I'll look at that and get back to you.
