Need help with project code
im crerating a power bank for iphone. its 3 solar panels wired to a battery. the battery is connected to the arduino nano every. and the i have a transmitter coil connected to the the nano on pin 9. this is the code
#include <Arduino.h>
// Pin definitions
#define TRANSMITTER_COIL_PIN 9
#define ON_OFF_SWITCH_PIN 6
#define BATTERY_VOLTAGE_PIN A0
// Battery thresholds
#define MIN_BATTERY_VOLTAGE 3.5 // Minimum battery voltage in Volts
#define MAX_BATTERY_VOLTAGE 4.2 // Maximum battery voltage in Volts
// Overvoltage and overcurrent thresholds
#define MAX_INPUT_VOLTAGE 5.5 // Maximum allowable input voltage in Volts
#define MAX_INPUT_CURRENT 2.0 // Maximum allowable input current in Amperes
// PWM settings
const int pwmPin = 9; // PWM output pin
int pwmValue = 128;  // Initial PWM duty cycle (adjustable)
// Function prototypes
void setup();
void loop();
bool isBatteryLow();
bool isBatteryFullyCharged();
bool isInputOvervoltage();
bool isInputOvercurrent();
    // Set PWM pin as output
    pinMode(pwmPin, OUTPUT);
    // Initialize pin modes
    pinMode(TRANSMITTER_COIL_PIN, OUTPUT);
    pinMode(ON_OFF_SWITCH_PIN, INPUT_PULLUP); // Use internal pull-up resistor
    // Adjust duty cycle as needed
    // For example:
    // pwmValue = 128; // 50% duty cycle
    // analogWrite(pwmPin, pwmValue); // Update PWM duty cycle
    // Check if the battery is low
    if (isBatteryLow()) {
        // Activate charging circuit (e.g., enable transmitter coil)
        // Deactivate charging circuit
        digitalWrite(TRANSMITTER_COIL_PIN, LOW);
    // Check if the battery is fully charged
    if (isBatteryFullyCharged()) {
        // Turn off charging circuit
    // Check for overvoltage or overcurrent conditions
    if (isInputOvervoltage() || isInputOvercurrent()) {
        // Handle overvoltage or overcurrent condition (e.g., disable charging)
        // You can also add additional actions like displaying an error message or blinking an LED
    // Delay for stability
    delay(1000); // Adjust delay as needed
bool isBatteryLow() {
    // Read battery voltage
    float batteryVoltage = analogRead(BATTERY_VOLTAGE_PIN) * (5.0 / 1023.0); // Convert ADC value to voltage
    // Check if battery voltage is below minimum threshold
    return batteryVoltage < MIN_BATTERY_VOLTAGE;
bool isBatteryFullyCharged() {
    // Check if battery voltage is above maximum threshold
    return batteryVoltage >= MAX_BATTERY_VOLTAGE;
bool isInputOvervoltage() {
    // Read input voltage
    float inputVoltage = analogRead(A1) * (5.0 / 1023.0); // Example: Read input voltage from A1 pin
    // Check if input voltage exceeds maximum allowable voltage
    return inputVoltage > MAX_INPUT_VOLTAGE;
bool isInputOvercurrent() {
    // Read input current
    float inputCurrent = analogRead(A2) * (5.0 / 1023.0); // Example: Read input current from A2 pin
    // Convert input current to Amperes (adjust conversion factor as needed)
    inputCurrent = inputCurrent / 1000.0; // Example: Conversion factor for 5V ADC range
    // Check if input current exceeds maximum allowable current
    return inputCurrent > MAX_INPUT_CURRENT;
Use code tags (the < CODE/ > icon above the compose window) to make it easier to read and copy for examination
In my experience the easiest way to tidy up the code and add the code tags is as follows
Start by tidying up your code by using Tools/Auto Format in the IDE to make it easier to read. Then use Edit/Copy for Forum and paste what was copied in a new reply. Code tags will have been added to the code to make it easy to read in the forum thus making it easier to provide help.
thanjs for the help
Thank you for adding the code tags
Do you have a question about it or your project ?
i just need others help with the code to see if thr code work for the project i listed above its a magasafe power pank that recharges with solar panels
Does it work for you ?
3 posts were merged into an existing topic: Cant upload code to nan every
