Need help with project.
Hi, I need help modifying this code to make it print '' 4 times and then start a new line and print it 4 times again i need to print the '***' on 4 lines
Here is the code:
int sivunPituus;
int numStart = 0;
int numEnd = 4;
char star = '*';
if (numStart != numEnd) {
numStart++;
Serial.print(star);
TakahuoneenSami:
It sounds like you need a for() loop to iterate over how many lines you want and another for() loop to iterate over how many '*' you want on each line.
Two for loops.
Outer one running four times for the println(); inner one four times for the *.
Or even simpler:
Serial.print(F("****\n****\n****\n****"));
Don't know if that's the answer your instructor is looking for but it's doing what's asked for.
Thanks for the quick response.
