Need help with proper void setup
I am attempting to combine sketch 1 and sketch 2 into a single sketch 3. I am having difficulty getting past void setup. Sketch 3 compiles and uploads fine but wifi crashes when it runs.
sketch1:
#include <ThingSpeak.h>
#include <ESP8266WiFi.h>
const char* ssid = "netis_2_4G";
const char* password = "xxxxx";
// ThingSpeak information
char thingSpeakAddress[] = "api.thingspeak.com";
unsigned long channelID = xxxx;
char* readAPIKey = "xxxx";
char* writeAPIKey = "xxxxxx";
const unsigned long postingInterval = 120L * 1000L;
unsigned int dataFieldOne = 1;                            // Field to write temperature data
unsigned int dataFieldTwo = 2;                       // Field to write temperature data
unsigned int dataFieldThree = 3;                     // Field to write elapsed time data
unsigned int aField = 4;                             //Field to hold first constant of the thermistor calibration
unsigned int bField = 5;                             //Field to hold second constant of the thermistor calibration
unsigned int cField = 6;                             //Field to hold third constant of the thermistor calibration
// Global variables
// These constants are device specific.  You will need to get them from the manufacturer or determine them yourself.
float aConst = 0.001129148;
float bConst = 0.000234125;
float cConst = 0.0000000876741;
unsigned long lastConnectionTime = 0;
long lastUpdateTime = 0;
WiFiClient client;
Serial.println("Start");
connectWiFi();
// Read the constants at startup.
aConst = readTSData( channelID, aField );
bConst = readTSData( channelID, bField );
cConst = readTSData( channelID, cField );
    // Only update if posting time is exceeded
    if (millis() - lastUpdateTime >=  postingInterval) {
        float fahrenheitTemperature, celsiusTemperature;
        lastUpdateTime = millis();
        float readValue = analogRead(A0);
        float logR = log( 10000 * ( 1024 / readValue - 1 ));                 // Separate the calculation for simplicity and debugging
        celsiusTemperature = 1 / ( aConst + bConst * logR + cConst * pow(logR,3) ) - 273.15;   // Calculate the temperature in Celsius
        fahrenheitTemperature = celsiusTemperature * 9 / 5 + 32;
        Serial.println("ADC =  " + String( readValue )+ " Temp = "+String( fahrenheitTemperature ));
        write2TSData( channelID , dataFieldOne , celsiusTemperature , dataFieldTwo , fahrenheitTemperature , dataFieldThree , millis() );      // Write the temperature in F, C, and time since starting.
int connectWiFi(){
   WiFi.begin(ssid, password );
if (WiFi.waitForConnectResult() !=  WL_CONNECTED) {
 Serial.println("Error connecting to WiFi");
 while (true) {
    delay(1);
    ThingSpeak.begin( client );
  float readTSData( long TSChannel,unsigned int TSField ){
  float data =  ThingSpeak.readFloatField( TSChannel, TSField, readAPIKey );
  Serial.println( " Data read from ThingSpeak: " + String( data, 9 ) );
  return data;
// Use this function if you want to write a single field
int writeTSData( long TSChannel, unsigned int TSField, float data ){
  int  writeSuccess = ThingSpeak.writeField( TSChannel, TSField, data, writeAPIKey ); // Write the data to the channel
  if ( writeSuccess ){
    Serial.println( String(data) + " written to Thingspeak." );
    return writeSuccess;
//use this function if you want multiple fields simultaneously
int write2TSData( long TSChannel, unsigned int TSField1, float field1Data, unsigned int TSField2, long field2Data, unsigned int TSField3, long field3Data ){
  ThingSpeak.setField( TSField1, field1Data );
  ThingSpeak.setField( TSField2, field2Data );
  ThingSpeak.setField( TSField3, field3Data );
  int writeSuccess = ThingSpeak.writeFields( TSChannel, writeAPIKey );
Sketch 2
#include <math.h>
int pinOut = 8;
double Thermistor(int RawADC) {
 double Temp;
 Temp = log(10000.0*((1024.0/RawADC-1)));
 Temp = 1 / (0.001129148 + (0.000234125 + (0.0000000876741 * Temp * Temp ))* Temp );
 Temp = Temp - 273.15;
 Temp = (Temp * 9.0)/ 5.0 + 32.0;
 return Temp;
  pinMode(8, OUTPUT);
  int val;
  double temp;
  val=analogRead(0);
  temp=Thermistor(val);
  Serial.print("Temperature = ");
  Serial.print(temp);
  Serial.println(" F");
  if (temp >= 150){
    digitalWrite(pinOut, LOW);
  else {
    digitalWrite(pinOut, HIGH);
Adding the following to sketch 3 is what seems to crash wifi: (pinMode(8, OUTPUT);)
I have been adding code in increments so I can be aware of what may break things.
Here is what I have for sketch 3 so far: (see attachment)
sketch3.txt (4.09 KB)
The part causing the crash .... Have a look at where your semicolon is located.
That was my fault, trying to encapsulate the line for reference.
Here is exactly how sketch 3 has it:
pinMode(8, OUTPUT);
According to what I can find on esp12e problems, it has something to do with the serial.println command.
Some proof of that would be extremely useful.
I found my answer here: There is no pin 8....
In ESP-12E NodeMCU, all digital pins can be called with a number. Here is the list:
static const uint8_t D0 = 16;
static const uint8_t D1 = 5;
static const uint8_t D2 = 4;
static const uint8_t D3 = 0;
static const uint8_t D4 = 2;
static const uint8_t D5 = 14;
static const uint8_t D6 = 12;
static const uint8_t D7 = 13;
static const uint8_t D8 = 15;
static const uint8_t D9 = 3;
static const uint8_t D10 = 1;
The sketch works after changing to a listed pin number
