need help with pushbutton
okay i'm pretty new at programming so i need help if you want to help if I like that very much
i would like to start a script and stop with a 1 pushbutton without resistor the script i want to start is
(and its not my code)
const int frontEchoPin = 7;
const int frontTriggerPin = 6;
const int leftEchoPin = 11;
const int leftTriggerPin = 10;
const int rightEchoPin = 9;
const int rightTriggerPin = 8;
const int motorL1 = 2;
const int motorL2 = 3;
const int motorR1 = 4;
const int motorR2 = 5;
volatile float maxFrontDistance = 25.00;
volatile float frontDuration, frontDistanceCm, leftDuration, leftDistanceCm, rightDuration, rightDistanceCm;
volatile float maxLeftDistance, maxRightDistance = 20.00;
// serial
// ultrasonic
pinMode(frontTriggerPin, OUTPUT);
pinMode(frontEchoPin, INPUT);
pinMode(leftTriggerPin, OUTPUT);
pinMode(leftEchoPin, INPUT);
pinMode(rightTriggerPin, OUTPUT);
pinMode(rightEchoPin, INPUT);
// motors
pinMode(motorL1, OUTPUT);
pinMode(motorL2, OUTPUT);
pinMode(motorR1, OUTPUT);
pinMode(motorR2, OUTPUT);
// front distance check
checkFrontDistance();
if (frontDistanceCm < maxFrontDistance) {
Serial.println("Too close");
checkLeftDistance();
delay(20);
checkRightDistance();
delay(20);
if (leftDistanceCm < rightDistanceCm)
moveRight();
else if (leftDistanceCm > rightDistanceCm) {
moveLeft();
else {
Serial.println("OK");
moveForward();
// left distance check
if (leftDistanceCm < maxLeftDistance) {
Serial.println("Left too close");
delay(20);
delay(20);
delay(20);
moveForward();
else if (leftDistanceCm < rightDistanceCm) {
moveRight();
// right distance check
if (rightDistanceCm < maxRightDistance) {
Serial.println("Right too close");
delay(20);
delay(20);
delay(20);
if (rightDistanceCm > leftDistanceCm)
moveForward();
else if (rightDistanceCm < leftDistanceCm) {
moveLeft();
void checkFrontDistance() {
digitalWrite(frontTriggerPin, LOW); //para generar un pulso limpio ponemos a LOW 4us
delayMicroseconds(4);
digitalWrite(frontTriggerPin, HIGH); //generamos Trigger (disparo) de 10us
delayMicroseconds(10);
frontDuration = pulseIn(frontEchoPin, HIGH); //medimos el tiempo entre pulsos, en microsegundos
frontDistanceCm = frontDuration * 10 / 292 / 2; //convertimos a distancia, en cm
Serial.print("Distance: ");
Serial.print(frontDistanceCm);
Serial.println(" cm");
void checkLeftDistance() {
digitalWrite(leftTriggerPin, LOW); //para generar un pulso limpio ponemos a LOW 4us
digitalWrite(leftTriggerPin, HIGH); //generamos Trigger (disparo) de 10us
leftDuration = pulseIn(leftEchoPin, HIGH); //medimos el tiempo entre pulsos, en microsegundos
leftDistanceCm = leftDuration * 10 / 292 / 2; //convertimos a distancia, en cm
Serial.print("Left distance: ");
Serial.print(leftDistanceCm);
void checkRightDistance() {
digitalWrite(rightTriggerPin, LOW); //para generar un pulso limpio ponemos a LOW 4us
digitalWrite(rightTriggerPin, HIGH); //generamos Trigger (disparo) de 10us
rightDuration = pulseIn(rightEchoPin, HIGH); //medimos el tiempo entre pulsos, en microsegundos
rightDistanceCm = rightDuration * 10 / 292 / 2; //convertimos a distancia, en cm
Serial.print("Right distance: ");
Serial.print(rightDistanceCm);
void moveBackward() {
Serial.println("Backward.");
digitalWrite(motorL1, HIGH);
digitalWrite(motorL2, LOW);
digitalWrite(motorR1, HIGH);
digitalWrite(motorR2, LOW);
void moveForward() {
Serial.println("Forward.");
digitalWrite(motorL1, LOW);
digitalWrite(motorL2, HIGH);
digitalWrite(motorR1, LOW);
digitalWrite(motorR2, HIGH);
void moveLeft() {
Serial.println("Left.");
void moveRight() {
Serial.println("Right.");
here's some code to demonstrate how to detect a button press.
#define butPin  A1
    pinMode (butPin, INPUT_PULLUP);
void
butPressed ()
    Serial.println ("button pressed");
    static bool butLst   = HIGH;
           bool but      = digitalRead (butPin);
    if (butLst != but)  {
        butLst = but;
        if (LOW == but)
            butPressed ();
    delay (10);     // to debounce button
you may want to simply toggle a flag that controls whether you do something instead of calling butPress()
if you change this line:
to this line:
void theSketch() {
then you can write a new loop() to turn it on and off.
const byte OnOffButton_DIPin = 12;
// In setup() put pinMode(OnOffButton_DIPin, INPUT_PULLUP);
// Wire the button between Pin 12 and Ground.
bool Running = false;
  if (digitalRead(OnOffButton_DIPin) == LOW) // Button Pressed
    Running = !Running;  // Toggle the flag
  if (Running)
    theSketch();
like this? thnx for helping me
// serial
// ultrasonic
// motors
void theSketch() {
if (Running)
theSketch();
delay(20);
delay(20);
moveRight();
moveLeft();
else {
moveForward();
delay(20);
delay(20);
delay(20);
moveForward();
moveRight();
delay(20);
delay(20);
delay(20);
moveForward();
moveLeft();
void moveLeft() {
void moveRight() {
multidays:
like this?
Nope. It looks like you put the new loop() function INSIDE the olde loop() function before renaming the old loop() function. You can;t define a function inside a function so the compiler would have told you that was incorrect. I intended you to put the new loop() function OUTSIDE the old loop() function (I would put it ABOVE, but BELOW would also work).
