Need help with PWM control of a shift register (74HC595) using an ATtiny85
So basically i want to use pwm on a shift register (74HC595) and because i dont have much room to play with i want to use the attiny85 as the microcontroller
I took "inspiration" from these two codes and fused it together
PWM through a 74hc595 shift register
Realistic LED Flickering Flame Effect using an Arduino (description)
//https://www.youtube.com/watch?v=OxSUIeZs2d8
This is the code for the arduino that worked flawless:
 * Name    : PWM Control of Shift Registers
 * By      : Joseph Francis
 * Open Source
 * Date    : 20 Nov, 2009
 * Version : 1.0
 * Notes   : Code for using a 74HC595 Shift Register PWM
#include <TimerOne.h>
//-- Update the TICKER_MAX and _STEP to 16 16 or 32 8 or 64 4 for performance vs colors available
#define TICKER_MAX 64
#define TICKER_STEP 4
bool signal = false;
bool an = false;
bool trans;
int signalPin = 7;
//Registerpins
int sr1 = 0;
int sr2 = 1;
int sr3 = 2;
int sr4 = 3;
int sr5 = 4;
int sr6 = 5;
int sr7 = 6;
int sr8 = 7;
//Ticker Registerpins
int TICK = 0;
//-- May have to tweak the timer based on number SR's
int timerDelay = 350;
//--- Pin connected to ST_CP of 74HC595
int latchPin = 10;
//--- Pin connected to SH_CP of 74HC595
int clockPin = 13;
//--- Pin connected to DS of 74HC595
int dataPin = 11;
//--- Used for faster latching
int latchPinPORTB = latchPin - 8;
//number of multiplex - set to zero for no multiplexing in this example
int groundMax = 0;
//number of Shift Registers - set to 1 for this example
int srcount = 1;
//--- ready for 10 SR's
byte srvals[] = {
  0, 0, 0, 0, 0, 0, 0, 0, 0, 0
int ticker = 0;
int groundAt = 255;
//--- setup for 10 SR's .. no multiplexing ...
// actually should be SR Count * 8 * multiplexing count (1 based) .. this is just an example for easy usage
byte srPins[80] = {
  0,
  0,
  0,
  0,
  0,
  0,
  0,
  0,
void pwmWrite(int port, byte val) {
  srPins[port] = val;
void iProcess() {
  int srtot = 8 * srcount;
  ticker++;
  if (ticker > TICKER_MAX)
    ticker = 0;
  int myPos = ticker * TICKER_STEP;
  groundAt++;
  if (groundAt > groundMax)
    groundAt = 0;
  int myLev = 0;
  for (int iSR = 0; iSR < srcount; iSR++) {
    byte currVal = 0;
    for (int i = 0; i < 8; i++) {
      myLev = 0;
      if (srPins[(i + (8 * iSR)) + (groundAt * srtot)] > myPos)
        myLev = 1;
      bitWrite(currVal, i, myLev);
    srvals[iSR] = currVal;
  latchOff();
  for (int iSR = srcount - 1; iSR >= 0; iSR--) {
    spi_transfer(srvals[iSR]);
  latchOn();
void latchOn() {
  bitSet(PORTB, latchPinPORTB);
void latchOff() {
  bitClear(PORTB, latchPinPORTB);
void setupSPI() {
  byte clr;
  SPCR |= ((1 << SPE) | (1 << MSTR));  // enable SPI as master
  //SPCR |= ( (1<<SPR1) | (1<<SPR0) ); // set prescaler bits
  SPCR &= ~((1 << SPR1) | (1 << SPR0));  // clear prescaler bits
  clr = SPSR;                            // clear SPI status reg
  clr = SPDR;                            // clear SPI data reg
  SPSR |= (1 << SPI2X);                  // set prescaler bits
  //SPSR &= ~(1<<SPI2X); // clear prescaler bits
  delay(10);
byte spi_transfer(byte data) {
  SPDR = data;  // Start the transmission
  loop_until_bit_is_set(SPSR, SPIF);
  return SPDR;  // return the received byte, we don't need that
  randomSeed(analogRead(0));
  pinMode(latchPin, OUTPUT);
  pinMode(clockPin, OUTPUT);
  pinMode(dataPin, OUTPUT);
  // Project 9 - LED Fire Effect
  pinMode(signalPin, INPUT);
  digitalWrite(latchPin, LOW);
  digitalWrite(dataPin, LOW);
  digitalWrite(clockPin, LOW);
  setupSPI();
  Timer1.initialize(timerDelay);  // Timer for updating pwm pins
  Timer1.attachInterrupt(iProcess);
  pwmWrite(sr1,255);
  pwmWrite(sr2,255);
  pwmWrite(sr3,255);
  pwmWrite(sr4,255);
  pwmWrite(sr5,255);
  pwmWrite(sr6,0);
  pwmWrite(sr7,0);
  pwmWrite(sr8,0);
void allTo(int val, int delayval) {
  for (int i = 0; i < srtot; i++) {
    pwmWrite(i, val);
    if (delayval > 0)
      delay(delayval);
void allOff() {
  allTo(0, 0);
void allOn() {
  allTo(255, 0);
  //check if signal for thruster bootup is there
  if (digitalRead(signalPin) == HIGH) {
    signal = true;                                //set boolean (virtual switch)
    signal = false;
  if (signal == true) {                            //if signal is there
    if (an == false) {                             //and if it hasnt been boot up before
      delay(200);
      for (int i = 255; i > 0; i--) {              //boot up animation
        pwmWrite(sr1, i + 25);
        pwmWrite(sr2, i);
        pwmWrite(sr4,i+13);
        pwmWrite(sr5,i+40);
        delay(25);
        pwmWrite(sr1, random(i) +10);
        pwmWrite(sr2, random(i) +8);
        pwmWrite(sr4, random(i) +9);
        pwmWrite(sr5, random(i) +10);
        delay(random(10));
        an = true;
        //blink leds 3,3333333%
        if (TICK >= 34){
        TICK = 0;
        pwmWrite(sr6,0);
      else{
        TICK++;
        delay(1);
        if (TICK == 20){
          pwmWrite(sr6,255);
        if (TICK == 22){
          pwmWrite(sr6,0);
        if (TICK == 32){
          pwmWrite(sr6,255);
        if (TICK == 27){
          pwmWrite(sr7,255);
        if (TICK == 30){
          pwmWrite(sr7,0);
        if (TICK == 30){
          pwmWrite(sr8,255);
        if (TICK == 33){
          pwmWrite(sr8,0);
      pwmWrite(sr1, random(100)+0);               //booted up animation
      pwmWrite(sr2, random(100)-1);
      pwmWrite(sr4, random(100)-3);
      pwmWrite(sr5, random(100)-2);
      delay(random(30));
      //blink leds 6,6666666%
      if (TICK >= 68){
        TICK = 0;
        pwmWrite(sr6,0);
      else{
        TICK++;
        delay(1);
        if (TICK == 40){
          pwmWrite(sr6,255);
        if (TICK == 44){
          pwmWrite(sr6,0);
        if (TICK == 64){
          pwmWrite(sr6,255);
        if (TICK == 53){
          pwmWrite(sr7,255);
        if (TICK == 60){
          pwmWrite(sr7,0);
        if (TICK == 60){
          pwmWrite(sr8,255);
        if (TICK == 67){
          pwmWrite(sr8,0);
  if (signal == false) {                          //if theres no signal
    if (an == true) {                             //and thrusters were booted up before
      for (int i = 0; i < 255; i++) {             //boot down animation
        pwmWrite(sr2, i);
        delay(25);
        pwmWrite(sr1, random(100) + 0);
        pwmWrite(sr2, random(100) + 0);
        pwmWrite(sr4, random(100) + 0);
        pwmWrite(sr5, random(100) + 0);
        delay(random(10));
        an = false;
         //blink leds 3,656126%
      if (TICK >= 37){
        TICK = 0;
        pwmWrite(sr6,0);
      else{
        TICK++;
        delay(1);
        if (TICK == 22){
          pwmWrite(sr6,255);
        if (TICK == 24){
          pwmWrite(sr6,0);
        if (TICK == 35){
          pwmWrite(sr6,255);
        if (TICK == 29){
          pwmWrite(sr7,255);
        if (TICK == 33){
          pwmWrite(sr7,0);
        if (TICK == 33){
          pwmWrite(sr8,255);
        if (TICK == 36){
          pwmWrite(sr8,0);
      for (int i=255; i>0; i--){
        pwmWrite(sr1,i+1);
        pwmWrite(sr2,i);
        pwmWrite(sr3,i+2);
        pwmWrite(sr4,i+1);
        pwmWrite(sr5,i);
        delay(5);
         //blink leds 16,6666666%
      if (TICK >= 170){
        TICK = 0;
        pwmWrite(sr6,0);
      else{
        TICK++;
        delay(1);
        if (TICK == 100){
          pwmWrite(sr6,255);
        if (TICK == 110){
          pwmWrite(sr6,0);
        if (TICK == 160){
          pwmWrite(sr6,255);
        if (TICK == 133){
          pwmWrite(sr7,255);
        if (TICK == 150){
          pwmWrite(sr7,0);
        if (TICK == 150){
          pwmWrite(sr8,255);
        if (TICK == 167){
          pwmWrite(sr8,0);
      pwmWrite(sr1,255);
      pwmWrite(sr2,255);
      pwmWrite(sr4,255);
      pwmWrite(sr5,255);
      for (int i=0; i<255; i++){
        pwmWrite(sr3,i);
        delay(1);
    } else {                                            //booted down animation
      pwmWrite(sr1, 255);
      pwmWrite(sr2, 255);
      pwmWrite(sr3, 255);
      pwmWrite(sr4,255);
      pwmWrite(sr5,255);
      //blink leds 100%
      if (TICK >= 1020){
        TICK = 0;
        pwmWrite(sr6,0);
      else{
        TICK++;
        delay(1);
        if (TICK == 600){
          pwmWrite(sr6,255);
        if (TICK == 660){
          pwmWrite(sr6,0);
        if (TICK == 960){
          pwmWrite(sr6,255);
        if (TICK == 800){
          pwmWrite(sr7,255);
        if (TICK == 900){
          pwmWrite(sr7,0);
        if (TICK == 900){
          pwmWrite(sr8,255);
        if (TICK == 1000){
          pwmWrite(sr8,0);
And this is the code for the attiny. I just switched out the pins. Thats the only difference.
 * Open Source
 * Version : 1.0
bool an = false;
bool trans;
int signalPin = 4;                                //Physischer Pin 3
//Registerpins
int sr1 = 0;
int sr2 = 1;
int sr3 = 2;
int sr4 = 3;
int sr5 = 4;
int sr6 = 5;
int sr7 = 6;
int sr8 = 7;
int TICK = 0;
int latchPin = 0;                                 //Physischer Pin 5
int clockPin = 2;                                 //Physischer Pin 7
int dataPin = 1;                                  //Physischer Pin 6
int groundMax = 0;
int srcount = 1;
byte srvals[] = {
int ticker = 0;
int groundAt = 255;
byte srPins[80] = {
  0,
  0,
  0,
  0,
  0,
  0,
  0,
  0,
  srPins[port] = val;
void iProcess() {
  ticker++;
    ticker = 0;
  groundAt++;
    groundAt = 0;
  int myLev = 0;
    byte currVal = 0;
      myLev = 0;
        myLev = 1;
  latchOff();
  latchOn();
void latchOn() {
void latchOff() {
void setupSPI() {
  byte clr;
  delay(10);
  setupSPI();
  pwmWrite(sr1,255);
  pwmWrite(sr2,255);
  pwmWrite(sr3,255);
  pwmWrite(sr4,255);
  pwmWrite(sr5,255);
  pwmWrite(sr6,0);
  pwmWrite(sr7,0);
  pwmWrite(sr8,0);
    pwmWrite(i, val);
    if (delayval > 0)
      delay(delayval);
void allOff() {
  allTo(0, 0);
void allOn() {
  allTo(255, 0);
    signal = false;
      delay(200);
        pwmWrite(sr2, i);
        pwmWrite(sr4,i+13);
        pwmWrite(sr5,i+40);
        delay(25);
        delay(random(10));
        an = true;
        if (TICK >= 34){
        TICK = 0;
        pwmWrite(sr6,0);
      else{
        TICK++;
        delay(1);
        if (TICK == 20){
          pwmWrite(sr6,255);
        if (TICK == 22){
          pwmWrite(sr6,0);
        if (TICK == 32){
          pwmWrite(sr6,255);
        if (TICK == 27){
          pwmWrite(sr7,255);
        if (TICK == 30){
          pwmWrite(sr7,0);
        if (TICK == 30){
          pwmWrite(sr8,255);
        if (TICK == 33){
          pwmWrite(sr8,0);
      delay(random(30));
      if (TICK >= 68){
        TICK = 0;
        pwmWrite(sr6,0);
      else{
        TICK++;
        delay(1);
        if (TICK == 40){
          pwmWrite(sr6,255);
        if (TICK == 44){
          pwmWrite(sr6,0);
        if (TICK == 64){
          pwmWrite(sr6,255);
        if (TICK == 53){
          pwmWrite(sr7,255);
        if (TICK == 60){
          pwmWrite(sr7,0);
        if (TICK == 60){
          pwmWrite(sr8,255);
        if (TICK == 67){
          pwmWrite(sr8,0);
        pwmWrite(sr2, i);
        delay(25);
        delay(random(10));
        an = false;
      if (TICK >= 37){
        TICK = 0;
        pwmWrite(sr6,0);
      else{
        TICK++;
        delay(1);
        if (TICK == 22){
          pwmWrite(sr6,255);
        if (TICK == 24){
          pwmWrite(sr6,0);
        if (TICK == 35){
          pwmWrite(sr6,255);
        if (TICK == 29){
          pwmWrite(sr7,255);
        if (TICK == 33){
          pwmWrite(sr7,0);
        if (TICK == 33){
          pwmWrite(sr8,255);
        if (TICK == 36){
          pwmWrite(sr8,0);
        pwmWrite(sr1,i+1);
        pwmWrite(sr2,i);
        pwmWrite(sr3,i+2);
        pwmWrite(sr4,i+1);
        pwmWrite(sr5,i);
        delay(5);
      if (TICK >= 170){
        TICK = 0;
        pwmWrite(sr6,0);
      else{
        TICK++;
        delay(1);
        if (TICK == 100){
          pwmWrite(sr6,255);
        if (TICK == 110){
          pwmWrite(sr6,0);
        if (TICK == 160){
          pwmWrite(sr6,255);
        if (TICK == 133){
          pwmWrite(sr7,255);
        if (TICK == 150){
          pwmWrite(sr7,0);
        if (TICK == 150){
          pwmWrite(sr8,255);
        if (TICK == 167){
          pwmWrite(sr8,0);
      pwmWrite(sr1,255);
      pwmWrite(sr2,255);
      pwmWrite(sr4,255);
      pwmWrite(sr5,255);
        pwmWrite(sr3,i);
        delay(1);
      pwmWrite(sr1, 255);
      pwmWrite(sr2, 255);
      pwmWrite(sr3, 255);
      pwmWrite(sr4,255);
      pwmWrite(sr5,255);
      //blink leds 100%
      if (TICK >= 1020){
        TICK = 0;
        pwmWrite(sr6,0);
      else{
        TICK++;
        delay(1);
        if (TICK == 600){
          pwmWrite(sr6,255);
        if (TICK == 660){
          pwmWrite(sr6,0);
        if (TICK == 960){
          pwmWrite(sr6,255);
        if (TICK == 800){
          pwmWrite(sr7,255);
        if (TICK == 900){
          pwmWrite(sr7,0);
        if (TICK == 900){
          pwmWrite(sr8,255);
        if (TICK == 1000){
          pwmWrite(sr8,0);
I get this error:
Using board 'ATtinyX5' from platform in folder: C:\Users\sbend\AppData\Local\Arduino15\packages\attiny\hardware\avr\1.0.2
Using core 'arduino' from platform in folder: C:\Users\sbend\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5
Detecting libraries used...
"C:\\Users\\sbend\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=attiny85 -DF_CPU=8000000L -DARDUINO=10607 -DARDUINO_attiny -DARDUINO_ARCH_AVR "-IC:\\Users\\sbend\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\sbend\\AppData\\Local\\Arduino15\\packages\\attiny\\hardware\\avr\\1.0.2\\variants\\tiny8" "C:\\Users\\sbend\\AppData\\Local\\Temp\\arduino-sketch-5D89230CFB2F73EADE499FEC1CE8397E\\sketch\\74hc595_attiny_test_v3.ino.cpp" -o nul
Alternatives for TimerOne.h: [TimerOne@1.1]
ResolveLibrary(TimerOne.h)
  -> candidates: [TimerOne@1.1]
"C:\\Users\\sbend\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=attiny85 -DF_CPU=8000000L -DARDUINO=10607 -DARDUINO_attiny -DARDUINO_ARCH_AVR "-IC:\\Users\\sbend\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\sbend\\AppData\\Local\\Arduino15\\packages\\attiny\\hardware\\avr\\1.0.2\\variants\\tiny8" "-Ic:\\Users\\sbend\\Documents\\Arduino\\libraries\\TimerOne" "C:\\Users\\sbend\\AppData\\Local\\Temp\\arduino-sketch-5D89230CFB2F73EADE499FEC1CE8397E\\sketch\\74hc595_attiny_test_v3.ino.cpp" -o nul
"C:\\Users\\sbend\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=attiny85 -DF_CPU=8000000L -DARDUINO=10607 -DARDUINO_attiny -DARDUINO_ARCH_AVR "-IC:\\Users\\sbend\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\sbend\\AppData\\Local\\Arduino15\\packages\\attiny\\hardware\\avr\\1.0.2\\variants\\tiny8" "-Ic:\\Users\\sbend\\Documents\\Arduino\\libraries\\TimerOne" "c:\\Users\\sbend\\Documents\\Arduino\\libraries\\TimerOne\\TimerOne.cpp" -o nul
Generating function prototypes...
"C:\\Users\\sbend\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=attiny85 -DF_CPU=8000000L -DARDUINO=10607 -DARDUINO_attiny -DARDUINO_ARCH_AVR "-IC:\\Users\\sbend\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\sbend\\AppData\\Local\\Arduino15\\packages\\attiny\\hardware\\avr\\1.0.2\\variants\\tiny8" "-Ic:\\Users\\sbend\\Documents\\Arduino\\libraries\\TimerOne" "C:\\Users\\sbend\\AppData\\Local\\Temp\\arduino-sketch-5D89230CFB2F73EADE499FEC1CE8397E\\sketch\\74hc595_attiny_test_v3.ino.cpp" -o "C:\\Users\\sbend\\AppData\\Local\\Temp\\arduino-sketch-5D89230CFB2F73EADE499FEC1CE8397E\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Users\\sbend\\AppData\\Local\\Arduino15\\packages\\builtin\\tools\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\sbend\\AppData\\Local\\Temp\\arduino-sketch-5D89230CFB2F73EADE499FEC1CE8397E\\preproc\\ctags_target_for_gcc_minus_e.cpp"
In file included from C:\Users\sbend\Documents\Arduino\74hc595_attiny_test_v3\74hc595_attiny_test_v3.ino:11:0:
c:\Users\sbend\Documents\Arduino\libraries\TimerOne/TimerOne.h: In member function 'void TimerOne::initialize(long unsigned int)':
c:\Users\sbend\Documents\Arduino\libraries\TimerOne/TimerOne.h:47:2: error: 'TCCR1B' was not declared in this scope
  TCCR1B = _BV(WGM13);        // set mode as phase and frequency correct pwm, stop the timer
Compiling sketch...
"C:\\Users\\sbend\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=attiny85 -DF_CPU=8000000L -DARDUINO=10607 -DARDUINO_attiny -DARDUINO_ARCH_AVR "-IC:\\Users\\sbend\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\sbend\\AppData\\Local\\Arduino15\\packages\\attiny\\hardware\\avr\\1.0.2\\variants\\tiny8" "-Ic:\\Users\\sbend\\Documents\\Arduino\\libraries\\TimerOne" "C:\\Users\\sbend\\AppData\\Local\\Temp\\arduino-sketch-5D89230CFB2F73EADE499FEC1CE8397E\\sketch\\74hc595_attiny_test_v3.ino.cpp" -o "C:\\Users\\sbend\\AppData\\Local\\Temp\\arduino-sketch-5D89230CFB2F73EADE499FEC1CE8397E\\sketch\\74hc595_attiny_test_v3.ino.cpp.o"
c:\Users\sbend\Documents\Arduino\libraries\TimerOne/TimerOne.h:47:2: note: suggested alternative: 'TCCR0B'
  TCCR0B
In file included from c:\users\sbend\appdata\local\arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7\avr\include\avr\io.h:99:0,
                 from c:\users\sbend\appdata\local\arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7\avr\include\avr\pgmspace.h:90,
                 from C:\Users\sbend\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino/Arduino.h:28,
                 from C:\Users\sbend\AppData\Local\Temp\arduino-sketch-5D89230CFB2F73EADE499FEC1CE8397E\sketch\74hc595_attiny_test_v3.ino.cpp:1:
c:\Users\sbend\Documents\Arduino\libraries\TimerOne/TimerOne.h:47:15: error: 'WGM13' was not declared in this scope
c:\Users\sbend\Documents\Arduino\libraries\TimerOne/TimerOne.h:47:15: note: suggested alternative: 'WGM00'
c:\Users\sbend\Documents\Arduino\libraries\TimerOne/TimerOne.h: In member function 'void TimerOne::setPeriod(long unsigned int)':
c:\Users\sbend\Documents\Arduino\libraries\TimerOne/TimerOne.h:76:2: error: 'ICR1' was not declared in this scope
  ICR1 = pwmPeriod;
c:\Users\sbend\Documents\Arduino\libraries\TimerOne/TimerOne.h:76:2: note: suggested alternative: 'OCR1C'
  ICR1 = pwmPeriod;
  OCR1C
c:\Users\sbend\Documents\Arduino\libraries\TimerOne/TimerOne.h:77:2: error: 'TCCR1B' was not declared in this scope
  TCCR1B = _BV(WGM13) | clockSelectBits;
c:\Users\sbend\Documents\Arduino\libraries\TimerOne/TimerOne.h:77:2: note: suggested alternative: 'TCCR0B'
  TCCR0B
c:\Users\sbend\Documents\Arduino\libraries\TimerOne/TimerOne.h:77:15: error: 'WGM13' was not declared in this scope
c:\Users\sbend\Documents\Arduino\libraries\TimerOne/TimerOne.h:77:15: note: suggested alternative: 'WGM00'
c:\Users\sbend\Documents\Arduino\libraries\TimerOne/TimerOne.h: In member function 'void TimerOne::start()':
c:\Users\sbend\Documents\Arduino\libraries\TimerOne/TimerOne.h:84:2: error: 'TCCR1B' was not declared in this scope
  TCCR1B = 0;
c:\Users\sbend\Documents\Arduino\libraries\TimerOne/TimerOne.h:84:2: note: suggested alternative: 'TCCR0B'
  TCCR1B = 0;
  TCCR0B
c:\Users\sbend\Documents\Arduino\libraries\TimerOne/TimerOne.h: In member function 'void TimerOne::stop()':
c:\Users\sbend\Documents\Arduino\libraries\TimerOne/TimerOne.h:89:2: error: 'TCCR1B' was not declared in this scope
c:\Users\sbend\Documents\Arduino\libraries\TimerOne/TimerOne.h:89:2: note: suggested alternative: 'TCCR0B'
  TCCR0B
c:\Users\sbend\Documents\Arduino\libraries\TimerOne/TimerOne.h:89:15: error: 'WGM13' was not declared in this scope
c:\Users\sbend\Documents\Arduino\libraries\TimerOne/TimerOne.h:89:15: note: suggested alternative: 'WGM00'
c:\Users\sbend\Documents\Arduino\libraries\TimerOne/TimerOne.h: In member function 'void TimerOne::resume()':
c:\Users\sbend\Documents\Arduino\libraries\TimerOne/TimerOne.h:95:2: error: 'TCCR1B' was not declared in this scope
c:\Users\sbend\Documents\Arduino\libraries\TimerOne/TimerOne.h:95:2: note: suggested alternative: 'TCCR0B'
  TCCR0B
c:\Users\sbend\Documents\Arduino\libraries\TimerOne/TimerOne.h:95:15: error: 'WGM13' was not declared in this scope
c:\Users\sbend\Documents\Arduino\libraries\TimerOne/TimerOne.h:95:15: note: suggested alternative: 'WGM00'
c:\Users\sbend\Documents\Arduino\libraries\TimerOne/TimerOne.h: In member function 'void TimerOne::setPwmDuty(char, unsigned int)':
c:\Users\sbend\Documents\Arduino\libraries\TimerOne/TimerOne.h:105:13: error: 'TIMER1_A_PIN' was not declared in this scope
  if (pin == TIMER1_A_PIN) OCR1A = dutyCycle;
c:\Users\sbend\Documents\Arduino\libraries\TimerOne/TimerOne.h:105:13: note: suggested alternative: 'TIMER1A'
             TIMER1A
c:\Users\sbend\Documents\Arduino\libraries\TimerOne/TimerOne.h: In member function 'void TimerOne::pwm(char, unsigned int)':
c:\Users\sbend\Documents\Arduino\libraries\TimerOne/TimerOne.h:114:13: error: 'TIMER1_A_PIN' was not declared in this scope
  if (pin == TIMER1_A_PIN) { pinMode(TIMER1_A_PIN, OUTPUT); TCCR1A |= _BV(COM1A1); }
c:\Users\sbend\Documents\Arduino\libraries\TimerOne/TimerOne.h:114:13: note: suggested alternative: 'TIMER1A'
             TIMER1A
c:\Users\sbend\Documents\Arduino\libraries\TimerOne/TimerOne.h:122:2: error: 'TCCR1B' was not declared in this scope
c:\Users\sbend\Documents\Arduino\libraries\TimerOne/TimerOne.h:122:2: note: suggested alternative: 'TCCR0B'
  TCCR0B
c:\Users\sbend\Documents\Arduino\libraries\TimerOne/TimerOne.h:122:15: error: 'WGM13' was not declared in this scope
c:\Users\sbend\Documents\Arduino\libraries\TimerOne/TimerOne.h:122:15: note: suggested alternative: 'WGM00'
c:\Users\sbend\Documents\Arduino\libraries\TimerOne/TimerOne.h: In member function 'void TimerOne::disablePwm(char)':
c:\Users\sbend\Documents\Arduino\libraries\TimerOne/TimerOne.h:129:13: error: 'TIMER1_A_PIN' was not declared in this scope
  if (pin == TIMER1_A_PIN) TCCR1A &= ~_BV(COM1A1);
c:\Users\sbend\Documents\Arduino\libraries\TimerOne/TimerOne.h:129:13: note: suggested alternative: 'TIMER1A'
             TIMER1A
c:\Users\sbend\Documents\Arduino\libraries\TimerOne/TimerOne.h: In member function 'void TimerOne::attachInterrupt(void (*)())':
c:\Users\sbend\Documents\Arduino\libraries\TimerOne/TimerOne.h:143:2: error: 'TIMSK1' was not declared in this scope
  TIMSK1 = _BV(TOIE1);
c:\Users\sbend\Documents\Arduino\libraries\TimerOne/TimerOne.h:143:2: note: suggested alternative: 'TIMSK'
  TIMSK
c:\Users\sbend\Documents\Arduino\libraries\TimerOne/TimerOne.h: In member function 'void TimerOne::detachInterrupt()':
c:\Users\sbend\Documents\Arduino\libraries\TimerOne/TimerOne.h:150:2: error: 'TIMSK1' was not declared in this scope
  TIMSK1 = 0;
c:\Users\sbend\Documents\Arduino\libraries\TimerOne/TimerOne.h:150:2: note: suggested alternative: 'TIMSK'
  TIMSK1 = 0;
  TIMSK
C:\Users\sbend\Documents\Arduino\74hc595_attiny_test_v3\74hc595_attiny_test_v3.ino: In function 'void setupSPI()':
C:\Users\sbend\Documents\Arduino\74hc595_attiny_test_v3\74hc595_attiny_test_v3.ino:129:3: error: 'SPCR' was not declared in this scope
C:\Users\sbend\Documents\Arduino\74hc595_attiny_test_v3\74hc595_attiny_test_v3.ino:129:3: note: suggested alternative: 'EECR'
   EECR
C:\Users\sbend\Documents\Arduino\74hc595_attiny_test_v3\74hc595_attiny_test_v3.ino:129:18: error: 'SPE' was not declared in this scope
C:\Users\sbend\Documents\Arduino\74hc595_attiny_test_v3\74hc595_attiny_test_v3.ino:129:18: note: suggested alternative: 'SPH'
                  SPH
C:\Users\sbend\Documents\Arduino\74hc595_attiny_test_v3\74hc595_attiny_test_v3.ino:129:31: error: 'MSTR' was not declared in this scope
C:\Users\sbend\Documents\Arduino\74hc595_attiny_test_v3\74hc595_attiny_test_v3.ino:129:31: note: suggested alternative: 'PSTR'
                               PSTR
C:\Users\sbend\Documents\Arduino\74hc595_attiny_test_v3\74hc595_attiny_test_v3.ino:131:19: error: 'SPR1' was not declared in this scope
C:\Users\sbend\Documents\Arduino\74hc595_attiny_test_v3\74hc595_attiny_test_v3.ino:131:19: note: suggested alternative: 'SM1'
                   SM1
C:\Users\sbend\Documents\Arduino\74hc595_attiny_test_v3\74hc595_attiny_test_v3.ino:131:33: error: 'SPR0' was not declared in this scope
C:\Users\sbend\Documents\Arduino\74hc595_attiny_test_v3\74hc595_attiny_test_v3.ino:131:33: note: suggested alternative: 'SM0'
                                 SM0
C:\Users\sbend\Documents\Arduino\74hc595_attiny_test_v3\74hc595_attiny_test_v3.ino:132:9: error: 'SPSR' was not declared in this scope
C:\Users\sbend\Documents\Arduino\74hc595_attiny_test_v3\74hc595_attiny_test_v3.ino:132:9: note: suggested alternative: 'ACSR'
         ACSR
C:\Users\sbend\Documents\Arduino\74hc595_attiny_test_v3\74hc595_attiny_test_v3.ino:133:9: error: 'SPDR' was not declared in this scope
C:\Users\sbend\Documents\Arduino\74hc595_attiny_test_v3\74hc595_attiny_test_v3.ino:133:9: note: suggested alternative: 'EEDR'
         EEDR
C:\Users\sbend\Documents\Arduino\74hc595_attiny_test_v3\74hc595_attiny_test_v3.ino:134:17: error: 'SPI2X' was not declared in this scope
C:\Users\sbend\Documents\Arduino\74hc595_attiny_test_v3\74hc595_attiny_test_v3.ino: In function 'byte spi_transfer(byte)':
C:\Users\sbend\Documents\Arduino\74hc595_attiny_test_v3\74hc595_attiny_test_v3.ino:142:3: error: 'SPDR' was not declared in this scope
C:\Users\sbend\Documents\Arduino\74hc595_attiny_test_v3\74hc595_attiny_test_v3.ino:142:3: note: suggested alternative: 'EEDR'
   EEDR
C:\Users\sbend\Documents\Arduino\74hc595_attiny_test_v3\74hc595_attiny_test_v3.ino:143:25: error: 'SPSR' was not declared in this scope
C:\Users\sbend\Documents\Arduino\74hc595_attiny_test_v3\74hc595_attiny_test_v3.ino:143:25: note: suggested alternative: 'ACSR'
C:\Users\sbend\Documents\Arduino\74hc595_attiny_test_v3\74hc595_attiny_test_v3.ino:143:31: error: 'SPIF' was not declared in this scope
C:\Users\sbend\Documents\Arduino\74hc595_attiny_test_v3\74hc595_attiny_test_v3.ino:143:31: note: suggested alternative: 'WDIF'
C:\Users\sbend\Documents\Arduino\74hc595_attiny_test_v3\74hc595_attiny_test_v3.ino: In function 'void setup()':
C:\Users\sbend\Documents\Arduino\74hc595_attiny_test_v3\74hc595_attiny_test_v3.ino:149:3: error: 'Serial' was not declared in this scope
C:\Users\sbend\Documents\Arduino\74hc595_attiny_test_v3\74hc595_attiny_test_v3.ino:149:3: note: suggested alternative: 'Stream'
   Stream
Using library TimerOne at version 1.1 in folder: C:\Users\sbend\Documents\Arduino\libraries\TimerOne
exit status 1
Compilation error: 'SPCR' was not declared in this scope
Can someone help me please? I honestly dont really know what i'm doing here and what i need to do to make this work.
Your code used low-level port and registers operations so it is incompatible with attiny.
is there any way to make it compatible?
