Hello. I use a Uno with an Ethernet shield and a homebrew servo driver shield to open/close lens caps on my telescope Watch at http://astronomy.mdodd.com/images/lens_caps.mp4. A C#.Net app on my PC connects to the Uno via hardwired Ethernet, and sends commands and receives status using (I think) a socket.
This all works fine. I want to replace the Ethernet Uno with a WiFi Uno, so I bought an R4 WiFi, and have successfully gotten it to connect to my home WiFi network.
But I don't know what to do next to replace the Ethernet server code with WiFi server code. Below is bare-bones example code from the opertional Ethernet Uno, plus my R4 WiFi connection code. My question is in the loop() function -- what do I do next?
Thanks for any and all advice.
--- Mike
===== Working code for Ethernet shield =====
#include <SPI.h>
#include <Ethernet.h>
EthernetServer server = EthernetServer(9000);
Ethernet.begin(mac, ip, dnServer, gateway, subnet);
server.begin(); // start listening for clients.
} // END setup()
// if an incoming client connects, read the incoming bytes.
if (client)
{ // Read bytes from the client and execute the requested command.
char c = client.read();
switch(c)
case CMD_OPEN:
//...etc...
default:
} // END switch(c)
} // END if (client)
} // END loop()
===== Working code for R4 WiFi =====
#include <SPI.h>
#include <WiFiS3.h>
WiFi.config(myIP);
int status = WiFi.begin(ssid, pswd);
} // END setup()
// What do I need here to create a client and read
// characters, as in the Ethernet code?
} // End loop(()
