I am working on using arduino to control one DC motor with an RC transmitter and receiver. When I use my code, I am able to control the forward and reverse motion of the motors via the RC transmitter.
However, it seems there is some sort of signal being constantly applied because the motors are always "whining" i.e. making a high pitched noise.
I would like to stop that from happening; perhaps via a deadband of sorts?
My setup is an arduino uno with an L298N motor driver board and one DC motor.
int enA = 10; // speed control for one motor
int in1 = 9; // motor signal pin
int in2 = 8; // motor signal pin
int ch2;
int move;
pinMode(2,INPUT); //ch 2 input from receiver
pinMode(8, OUTPUT);
pinMode(9, OUTPUT);
pinMode(10, OUTPUT);
analogWrite(in1, 0);
analogWrite(in2, 0);
ch2 = pulseIn(2, HIGH);
move = map(ch2,1200,1800, -500, 500); //center over zero
move = constrain(move, -255, 255); //only pass values whose absolutes are
//valid pwm values
/*What we're doing here is determining whether we want to move
forward or backward*/
{move=abs(move);}
if(move>0){digitalWrite(in1, HIGH);digitalWrite(in2, LOW);};
if(move<0){digitalWrite(in1, LOW);digitalWrite(in2, HIGH); };
analogWrite(enA, move); // pass the correct speed to enA based on the receiver input
