I wrote this program myself, it is pretty easy to understand its use. :
#include <EEPROM.h>
bool writeSSID(String _SSID,String password,byte security)
byte ssid_length = _SSID.length();
byte password_length = password.length();
if(ssid_length < 1 || password_length < 8 && password_length != 0)
return false;
else if (ssid_length > 32 || password_length > 64)
return false;
EEPROM.write(0,ssid_length);
EEPROM.write(1,password_length);
char ssid[ssid_length];
char password_[password_length];
_SSID.toCharArray(ssid,ssid_length);
password.toCharArray(password_,password_length);
for(int i = 2,n = 0;i <= ssid_length;i++, n++)
EEPROM.write(i,ssid[n]);
for(int i = ssid_length + 2, n = 0;i <= password_length;i++, n++)
EEPROM.write(i,password_[n]);
EEPROM.write(2+password_length+ssid_length,security);
return true;
// index 0 = ssid,index 1 = password,index 2 = security
String readSSID (byte index)
String output[3];
byte ssid_length = EEPROM.read(0);
byte password_length = EEPROM.read(1);
char password[password_length];
byte security;
for(int i = 2;i <= ssid_length;i++)
ssid[i-2] = EEPROM.read(i);
password[n] = EEPROM.read(i);
security = EEPROM.read(password_length+ssid_length+2);
output[0] = ssid;
output[1] = password;
output[2] = security;
return output[index];
//for
if(writeSSID("TEEST","12345780",0))
Serial.println("Successfully Written to EEPROM !");
Serial.println("Failed to write !");
Serial.println("ssid : " + readSSID(0));
Serial.println("pass : " + readSSID(1));
Serial.println("Security Type : " + readSSID(2));
delay(5000);
Output :
ssid : TEESxB
pass : 12�!¹!ÌTEESxR
Security Type : 0
Security Type is working, since it was the easiest.
Seems like first 6 bytes in the EEPROM read fine, the jumbled data comes after that (with every password/ssid I’ve tried)
I would like if you guys would help me with the error in my logic. It’s my first time handling streams like this (never did this in higher level langs)
