Need help with reading line by line - SD card
I need a little help to find a solution to this code:
code snippet:
            myFile = SD.open("test.txt");
              if (myFile) {
             // read from the file until there's nothing else in it:
          while (myFile.available()) {
            String req = myFile.readStringUntil('\n'); // myFile.readStringUntil('*');
            for (int i = 0; i <= req.length(); i++) {
              client.println(req[i]);
              client.println('\n');
             // close the file:
               myFile.close();
Browser output:
2 0 2 0 , 3 , 7 , 6 , 5 , 3 0 , 2 , 3 , n a n , n a n , 0 * 2 0 2 0 , 3 , 7 , 6 , 5 , 3 0 , 2 , 3 , n a n , n a n , 0 * 2 0 2 0 , 3 , 7 , 6 , 5 , 3 0 , 2 , 3 , n a n , n a n , 0 * 2 0 2 0 , 3 , 7 , 6 , 5 , 3 0 , 2 , 3 , n a n , n a n , 0 * 2 0 2 0 , 3 , 7 , 6 , 5 , 3 0 , 2 , 3 , n a n , n a n , 0 * 2 0 2 0 , 3 , 7 , 6 , 5 , 3 0 , 2 , 3 , n a n , n a n , 0 * 2 0 2 0 , 3 , 7 , 6 , 5 , 3 0 , 2 , 3 , n a n , n a n , 0 * 2 0 2 0 , 3 , 7 , 6 , 5 , 3 1 , 2 , 3 , n a n , n a n , 0 * 2 0 2 0 , 3 , 7 , 6 , 5 , 3 1 , 2 , 3 , n a n , n a n , 0 * 2 0 2 0 , 3 , 7 , 6 , 5 , 3 1 , 2 , 3 , n a n , n a n , 0 * 2 0 2 0 , 3 , 7 , 6 , 5 , 3 1 , 2 , 3 , n a n , n a n , 0 * 2 0 2 0 , 3 , 7 , 6 , 5 , 3 1 , 2 , 3 , n a n , n a n , 0 * 2 0 2 0 , 3 , 7 , 6 , 5 , 3 1 , 2 , 3 , n a n , n a n , 0 *
I have been playing around with a lot of different codes, but nothing seem to work for me.
I need it to be more readable, I think about to split it by " * ".
So it looks like:
So I can get every comma separated data, for building a nice website output.
But how - do I do it?
Any idea?
/jokerper
It seems that your real problem is that you are simply not sending the data to SD in the proper manner.
Strings are always a bad idea and quite unwarranted here. It is OK to just send the values and the commas in order.
Get rid of that useless “*”, and use
myfile.println(dadedah);
for the last item in the line.
The Dumpfile in the SD section of the examples should be all you need to retrieve it.
