Need help with receiving sms
hello everyone,
i' ve connected a gsm shield to an arduino mega and i want to send sms from my phone and control the relay which is connected to mega. The arduino receives correctly the first sms and can control the relay, but when i send another sms id doesn't work.
this is the code i am using:
 char inchar;
 int relay_1 = A9;
 int relay_2 = A10;
 pinMode(relay_1, OUTPUT);
 pinMode(relay_2, OUTPUT);
 digitalWrite(relay_1, LOW);
 digitalWrite(relay_2, LOW);
 Serial1.begin(19200);
 delay(3000);
 Serial1.println("AT+CMGF=1\r");
 delay(200);
 Serial1.println("AT+CSMS=1\r");
 delay(200);
 Serial1.println("AT+CNMI=2,2,0,0,0");
 delay(200);
 if(Serial1.available() >0)
    delay(10);
    inchar=Serial1.read();
      if (inchar=='0')
       if (inchar=='#')
             if (inchar=='0')
             else if (inchar=='1')
                 digitalWrite(relay_1, HIGH);
       delay(10);
             if (inchar=='0')
                 digitalWrite(relay_2, HIGH);
 Serial.println("AT+CMGD=1,4");
   //Serial.println("AT+CMGR=1\r");
   //delay(4000);
Is there a problem in the loop which i can not see?. The format of the messages are supposed to be like 0#xx, where the two last digits (xx) are 0 for close and 1 for open the first and the second relay.
Thank you in advance.
I'd suggest you might put some Serial.print() on another serial port - so you can see what the modem is doing.
The +CMT: message returns a lot more content than just your 0/1 character.
There are many examples here and other places - but I'm glad to see that you avoided the String class !!
